Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
I keep getting a f1 code need help fixing it - Whirlpool Cabrio WTW6600SBT Top Load Washer
  • 15,935 Answers
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
Error code f10 / f1 keep showing
error codes show for a reason - it needs a fix.
get the manual, find out what it is telling u, fix it, and it goes away
Jan 27, 2016 | Microwave Ovens
How do I fix my oven door keeps locking up and F1 comes up and starts beeping
Here is a detailed description of this error code. Your control can be rebuilt by fixyourboard.com. See article here on Kenmore/GE F1 Error Code: Oven Failure After Self Clean and F1 Errors
Aug 27, 2015 | Ovens
Our frigidaire stove or the oven is locked and it just keeps making this beep noise and the oven wont unlock so we really need help unlocking the oven and stoping the been noise thanks
The "F1" error code indicates a failure of the Electronic Oven Control or EOC circuit board. You may find the oven gets too hot, fails to respond to input or acts irregularly when the EOC is malfunctioning or broken. While this code usually indicates a need for repairs.
Read more: How to Troubleshoot a Frigidaire Oven F1 Code ' eHow.com http://www.ehow.com/how_10004808_troubleshoot-frigidaire-oven-f1-code.html#ixzz2EhW21T4n
Dec 11, 2012 | Ovens
Ihave a amana range getting F1 code and it keeps beeping what part do I need to order to fix this? I love this range except for that!! An dwher can I get the part or should I call a repairman? Help!!
F1 points to the ERC or electronic range control. There are three different variants of this model. Here is a site that distributes Amana parts. Please select your specific model.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=ACS7270
This is only a suggestion take it as you will. Good luck!
Jun 12, 2011 | Amana ACS7270 Electric Kitchen Range
The code F1 keeps blinking and I can't shut it off.
f1 means u have a leak on your machine and the water has triggered the flood switch underneath the lower drawer. if u need more help please reply.
Apr 27, 2010 | Fisher and Paykel DD605HSS 23 in. Built-in...
F1 code whirlpool
whirlpool F1 code - Appliance Repair Forum THERE IS A RECALL ON YOUR WASHER,CALL THE FACTORY AND GET IT FIXED FOR FREE
Dec 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
I keep getting an F1 error code on my top load Whirlpool Cabrio HE washer. I do what the manual says to do which is to hit the Pause/cancel buttom and then start....I continue to get the F1 error code for...
There is a recall for the Cabrio F1 error code issue. I had mine fixed for free. They will have to replace the control board. You will need to call 1-800-253-1301 and tell them that your Cabrio washer is having the F1 error code and you read on the internet that Whirlpool has been making repairs. Have your model number, serial number, and purchase date ready for the person on the phone. The guy that repaired mine also replaced the washboard at the bottom for free...just ask the tech about it when he is there.
Dec 07, 2009 | Cars & Trucks
KitchenAid KESS907 Electric Range E1 F1 Error Code
F1 E1, replace Electronic Range Control.
In other words, the controller board has failed.
Jan 29, 2009 | KitchenAid KDRS807SSS Dual Fuel (Electric...
My dishwasher keeps flashing F1 error message
The f1 code is caused moisture in the electronics part most likely in the door.see if there is any way that you can see where moisture might get in and plug that spot up. In the case of the f1 code when not using the dishwasher leave the door propped open to help dry out the electronics.
Nov 18, 2008 | Fisher Dishwashers
Keep getting an error code F1
I have a kenmore elite model 110.2703 and i keep getting
error code F1. help
Sep 14, 2008 | Washing Machines
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
50 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
