Question about Code-Alarm Code Alarm Transponder
Ford transit i have no ignition lights on dash the battery is ok its mreg 1995
    Problem Solver:
  • 11 Answers
Check your alternater and wiring, Gary G
Posted on Jul 23, 2010
  • 20 Answers
Check the fuses including 1's under the bonnet
Posted on Jun 12, 2010
    Champion:
  • 250 Answers
The wires in the ignition plug, they burn, cut em out and use large terminals
Posted on Sep 05, 2009
Got 2003 turbo diesel ford transit auto trans, I replaced both batteries n now when I go to start the van the Reds turn on n nothing, gear selector is no longer registerin n not a single click is made
If the dash lights do not come on:
The most common cause of this is loose battery connections. The battery is located underneath the driver's seat. Turn the ignition to the on position and slide the driver's seat forward. The battery is concealed with a plastic flap, remove the flap. Check the tightness of the two terminals while looking at the dash, if the dash lights up, then you know what the problem was. ·
If the dash lights are coming on and the vehicle makes no attempt to start:
The most common cause is the starter motor terminals. These can overheat and fuse. This type failure is very sudden and shows no warning signs. The only cure is a replacement starter motor.
May 19, 2015 | Ford Cars & Trucks
Mitsubishi pajero problems
You have to have your freewheeling valve and some switches on your transmission checked.
Mar 12, 2014 | Cars & Trucks
No ignition
i have a mk5 2.5 di ford transit 1997 my ignistion light does not come on checked relay and fuse both ok battery fully charged dont know what to do
Jan 08, 2014 | 2001 Honda Accord
Interior light fuse vh ford transit
Hi, In interior junction box - Fuse 10 Amp (red) number 72 - "Battery saver" fuse - that's the one
Mar 13, 2013 | Cars & Trucks
1995 taurus won't start
The dash lights coming on doesn't mean your battery is strong enough to turn the car over. That being said, I would lean towards the starter also. I would just have the battery chkd out before you go replacing other things just to be sure. Good luck to you.
Oct 22, 2012 | 1995 Ford Taurus
My battery light came on dash of ford transit connect,lights slowly dimmed dash lights slowly dimmed then van stopped.jump started to get home.battery is original 9yrs old do i need a new one?
first check connections on battery and alternator make sure tight clean and there is no damage or breaks also check belt is tight and not slipping or damaged the battery light can mean battery not charging or alternator not putting out a charge if a boost got u home i would lean towards alternator problem [have tested though as well as battery most auto stores usually offer this service for free ]
Jan 19, 2011 | Ford Transit Connect Cars & Trucks
I can't get my car to start, when i turn the key the car don't make any sounds, i check the battery, change the starter
The next thing i would check is the ignition switch itself. Turn the key to the on position, If the red warning lights on your dash don't light up (and your battery connections are clean), the ignition switch is bad. If they do light up, turn the key to the start position. The dash warning lights should turn off at this key position (most cars). If you're not sure, turn on the headlights. When you try to start the car, the lights should either dim (a lot) or turn off completely. If they do, your ignition switch should be ok. If not, the switch will need replacement.
Sep 02, 2010 | 1995 Ford Windstar
1995 ford escort- starter cranks all the time
Check voltage at trigger wire going to the solenoid. There should not be any voltage there except when the key is in start positon...if there is the ignition switch may be bad.
Jun 07, 2009 | 1995 Ford Escort
Ignition Lock Cylinder
There is a small button that can be pushed near the lock cylinder when the key is in the ignition and turned, the cylinder can be pulled out then.
Dec 10, 2008 | 1995 Ford Bronco
Code-Alarm Code Alarm  Transponder Logo
182 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
