Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Kitchenaide fridge side by side
My fridge is making cold water, but it is not making ice. The water doesn't appear to be getting through. Any suggestions????????
  • 1 more comment
  • Anonymous Nov 26, 2007
    Same problem here.
  • MrBrian Dec 03, 2007
    KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator is dispensing cold water, but is not making ice. Seems no water is getting to the icemaker.
  • Anonymous Feb 17, 2008
    The mold is completely dry. Last week I emptied the ice storage bin. From that point the water was shut off for 5 days. From that point on no ice.model no. ksrp22Fn
  • 35 Answers
Replace the module on the ice maker. Its the front square part on the IM remove the cover and you will see it. Always unplug before messing with electricity. If the IM is old replace the unit. The module could cost upto $75 or more. If you wwasn't getting good water flow you would replace the water valve.
Posted on Dec 09, 2007
The icemaker on my older kenmore side by side refrigerator doesn't make ice?
What you are probably dealing with is the little valve called (Water Valve) on the back of side of the refrigerator usually down low towards the bottom right hand side if you are facing the back of unit. Its the part that the water line run into and also will be a water line coming out of it going up the back of the fridge and goes thru into the freezer to the Ice maker in the freezer
Aug 08, 2012 | Kenmore Refrigerators
Ice maker is not working. doesn't appear that it's
There are many things that can go wrong with a Kenmore refrigerator ice maker. Your ice maker may be leaking. It may not make any ice at all, or the ice that comes out smells or has an odd appearance. The problem may have an easy solution, or it may require a technician's expertise. The troubleshooting tips in this article will minimally make you aware of what is likely the source of the problem. You may be able to fix the problem yourself and save a bundle.
When it Won't Make Ice
1 Get a thermometer and see how cold it is in there. If your freezer is fewer than 17 degrees F, it won't make ice. The freezer temperature setting may be too high or the thermometer is broken and not calibrated correctly. If adjusting the temperature fails to work, call a Kenmore technician.
2 Determine if your water fill spout in the freezer is plugged with ice. If so, no new ice can be made. Try clearing it out or melting the ice by running a hair dryer on it for a few minutes.
3 Turn your refrigerator around to look at the back side to see if water is getting to the water inlet valve behind the fridge. If the water is not properly connected, there's no water to make ice.
4 Use an ohm meter to test for coil continuity. If the ohm meter shows there is no continuity, then you will need to replace the water inlet valve.
Have a good day : )
Sep 03, 2011 | Kenmore Side by Side Refrigerator
What would cause the airflow to stop to fridge when freezer door is closed? (kenmore model 106)
Ice in the path of air flow to fridge. The freezer also kkeps the fridge cold via a fan that blows the cold air from feezer to fridge.
Aug 21, 2011 | Kenmore Refrigerators
My ice maker isn't getting water in to make ice. I can manually pour water into the maker, let it freeze, and get the maker to get the ice out, but no water comes in. GE model GSHS5KGX. Side by side...
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects theb you need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge.
Thank you for using fixya
Leo Ponder
Jul 26, 2011 | General Refrigerators
KitchenAid side by side refrigerator doesn't make ice, very slow trickle cold water in door. Removed automatic ice maker and removed ice in discharge tube and reinstalled same. Problem not resolved. ...
check for a kink in the plastic water delivery line. If line is kinked do not bother to streighten it out. Replace it. Once the line is weakened it could break and cause flooding. When reinstalling the line and moving fridge back into place ensure that the line is not bent or kinked.
May 10, 2011 | Kitchen Ranges
My GE side by side fridge/freezer is working, water dispensing ok, but not making ice. I switch off the fridge, than ice maker but still not making ice. I try all the hints from Manual but no luck. Water...
fill the ice maker with water manually, if you have ice in the bucket you know that the ice maker is working , after check the water valve if is opening , if it is replace main board
Jun 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Just Purchased a Whirlpool Fridge Side-by-side?
it will start making ice within 24 hrs you should be able to get water out the door but it wont be cold but it takes 24 hr for the box to get cold and stabilized
Dec 28, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
73 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
