Question about Olympus EVOLT E-500 Digital Camera
Shutter button freeze?
I use an external flash with my camera. It's set to "A". It will be working fine...sync up with the flash just fine...then seemingly out of nowhere, no matter how hard I press down on the shutter, it freezes and the camera WILL NOT let me take a picture. When looking through the view finder, the flash icon is blinking along with the aperture number. I just spent the last half hour searching through the menu options, trying various settings to resolve this and got nothing. Tried taking the battery out and putting it back in (on both the cam and the flash)...same issue continues.
I'll turn off the camera and not use it for a while, and when I go to use it again, it works just fine...for a while, then the shutter will "lock" and I can't shoot anymore.
I cannot figure out how to solve this.
    Problem Solver:
  • 15 Answers
Can it focus,if not then it will not let you take a photo
and when it is on M and the aperture and shutter speed don't match it also won't
Posted on Jun 29, 2009
I couldn't get the Nikon ML-L3 Remote Control to work on my Nikon D40x when I was using the external flash (SB-900). When I took it off, it worked fine. Is there a way to get it to work with the external...
Set the camera's release mode to one of the two remote modes. Quick-response remote mode fires the shutter when you press the button on the remote. Delayed remote mode gives you two seconds to hide the remote behind your back before firing the shutter.
To set the camera's release mode, press the button to bring up the information display. Press the button to put the cursor into the information display. Use the cursor keys to highlight the release mode (fifth item from the top along the right edge) and press OK. Use the cursor keys to highlight the desired mode and press OK.
Full details are in the manual in the "Release Mode" section (page 53 in my copy).
Oct 04, 2010 | Nikon ML-L3 Remote Control
How to make night photo canon 1000d but the image to be frozen?
If it's not too dark, you can try setting the ISO to 1600 or even 3200. The downside is, you'll got image noise at higher ISO (sensitivity of sensor/film).
The other alternative is using the flash. If you need to increase shutter speed beyond the capabilities of the on-camera flash in order to 'freeze' the moving subject, then use an external flash unit and set it on high speed sync.
Mar 13, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
When using external flash some are ok but some show movement, whats the best setting to use, ive tryed auto and manual, john
There is no single "best" setting, that's why the camera provides so many. It depends too much on the particular setting, the effect you're going for, and other factors.
If you're seeing undesired movement, that's an indication that the shutter speed is too slow. Using either Manual or Shutter-priority mode, set the shutter speed faster (being careful not to go faster than the maximum sync speed).
Feb 03, 2010 | Samsung GX-1S Digital Camera
Nikon D60 Digital SLR--Slow Shutter Speed
Your're probably using a flash with TTL disabled. So 1/200 is the highest sync possible with that kind of flash. Did you try removing the flash off the body and setting faster shutter speeds?
Apr 28, 2009 | Nikon D60 Digital Camera with 18-55mm lens
My sb 600 fires with the camera but it seems not illuminate
Definately a settings problem. The camera will only syncronize on one specific speed. Youe best bet is to use auto. For manual, you'll have to set the shutter speed at the sync speed.
Flash Sync Speed
  • up to 1/250 X-Sync Speed
  • up to 1/8000 FP High Speed Sync
  • Red-eye reduction
    Red-eye reduction with slow sync
    Rear-curtain sync
    Slow sync
    Front-curtain sync (normal) Flash Sync Modes
  • 1) i-TTL: TTL flash control by 1,005-pixel RGB sensor, built-in flash, SB-800, SB-600, SB-400: i-TTL balanced fill-flash and standard i-TTL flash
    2) AA (Auto Aperture-type) flash: Available with SB-800 used with CPU lens
    3) Non-TTL Auto: Available with Speedlights such as SB-800, 28, 27, and 22S
    4) Range-priority manual flash; available with SB-800 Flash Control
  • Mar 13, 2009 | Nikon Speedlight SB-600 TTL Flash
    The flash pictures are only half exposed, like drag on shutter
    Sounds like the shutter needs repair. Either the opening curtain is sticking or the closing curtain is not holding long enough. Another problem might be the camera's sync speed might be lower than 1/125 of a second. Many cameras use 1/60th or 1/90th of a second as their flash sync speed.
    Feb 02, 2009 | Ricoh KR-5 SUPER II 35mm SLR Camera
    Non-syncing Olympus FL-36
    Hey I have an E510 and an fl 36 flash unit and no problems for a year now.
    And no problems at all {knock wood]!
    Have you checked to see if all the flash pins are making contact?
    Normally I only turn my flash on after I put it on the camera and then turn the camera off and then on again to see if everything is ok. I remember the flash would not communicate with the camera on a shoot and after a while I realized that the flash was not all the way in the hot shoe. Fool around with the flash off the camera first and see the flash have modes that you have to set up if the mode is set in full manual that might be a problem. There is a button that you have to hold down for three seconds to get in the menu. My buttons are fine and have not faded any at all. I realize that the power button an the flash is hard to press on, I do hope I was of help .GOOD LUCK
    From Chris
    May 12, 2008 | Olympus FL-36 TTL Flash
    Photography
    set it in manual, and open up the aperture. Flash exposure is mainly affected by aperture, Also make sure your shutter speed is set at flash sync speed
    Feb 08, 2008 | Nikon Coolpix 8800 Digital Camera
    Maximum flash sync
    I have a 3000z, and have not noticed any problem with flash sync with even the fastest speed.
    Sep 13, 2005 | Epson PhotoPC 3100Z Digital Camera
    Olympus EVOLT E-500 Digital Camera Logo
    137 people viewed this question
    Top Olympus Cameras Experts
    Steven Wander
    Steven Wander
    Jerry Greenberg
    Jerry Greenberg
    Are you an Olympus Camera Expert? Answer questions, earn points and help others
