Problem:Printer stopped working ( does not make copy ). Status : Printer status window Interface has stopped or stopped working and was closed. What is wrong?
  • 1 more comment
  • trussinv Jun 26, 2009
    Dell photo all-in- one printer 966
    Computer DELL dimention 9200 ( XPS 410)
    Printer does not make copy from internet.
    Any info. when I would like to make copy - did not make it.
    Yes it is!
    Niko Ohtonen found the solution.
    He is very good PC technition.
    I am very happy to have him on line.
    Best regards,
    Vladimir, your new customer.
  • 13,433 Answers
Please post the brand and model.
Try pressing on the copy button on the printer, what happens?
Posted on Jun 25, 2009
  • Ekse Jun 26, 2009
    make a copy from the internet?
    Do you mean it you can't print a internet page? or anything from online?
  • Ekse Jun 26, 2009
    Lets solve the problem over a remote support connection - I will be able to see the screen and sort out the problem. Click on this link below:
    http://www.fastsupport.com/445886492
    above link will start the session, if the session doesn't start within a minute or two, use the manually download software link at the bottom and follow instructions.
Can 10GE Optical Interfaces of a Switch Work upon a Unidirectional Fiber Connection?
10GE optical interfaces of a switch cannot work upon a unidirectional fiber connection. A unidirectional fiber connection occurs between two 10GE optical interfaces when one interface is Down because the Rx fiber is removed, while the other interface is still Up because its Rx fiber can receive link_Up signals from the PHY layer.
A switch determines the status of a 10GE optical interface according to the IEEE 802.3ae standard. As defined in this standard, the MAC layer of a 10GE optical can send local_fault and remote_fault signals. A switch can determine the link status based on only the link status of the PHY layer or based on the link status of the PHY layer and the local_fault and remote_fault signals from the MAC layer.
On a Huawei switch, link status of a 10GE optical interface turns Up only when the link status of the PHY layer is Up and both the local_fault and remote_fault signals are 0. When two 10GE optical interfaces are interconnected and the Rx fiber on one interface is removed, this interface goes Down and the MAC layer of the interface generates a local_fault signal. Meanwhile, the local interface sends a fault signal to the remote interface through the Tx fiber. The remote interface receives the link_Up signal from the PHY layer and the remote_fault signal from the MAC layer. Therefore, the link status of the remote interface goes Down.
S2300 Switch Thunder link com
Jan 22, 2017 | Huawei Computers & Internet
Offline status
The most likely cause for this OFFLINE status on the PC is which interface is selected on the printer.
I think the printer defaults to Serial interface, so if you are using USB ensure you select the USB interface via the control panel on the printer, similarly if the connection is parallel ensure the parallel interface is selected.
If the connection is serial, ensure the cable is of the correct pin configuration and ensure the serial interface is set up correctly.
May 25, 2012 | TallyGenicom Tally 5040 Passbook Matrix...
I replaced the cartridge of my hp psc 1401, copied the test page that was automatically printed, but now I can't print anything. Copying works OK. I don't get an error message or blinking lights on...
what is the status of print job in the queue? whether it is showing printing or no status in the windows.
if the status is printing you delete all the print jobs and switch off and on .then try print something. if no status is there in the windows then you check whether the printer is off line .try make it online by right click on the printer icon then click on the use printer online.
Aug 10, 2011 | HP PSC 1401 All-In-One Printer
My printer is not printing anything. the status light isnt even on what should i do?
Does the "Status Monitor" in your printer display any errors?
Is the printer cover securely closed?
Is any of the LEDs in the printer flashing?
What happened just before the printer stopped working? Did you have a poer failure? Did you install new software or hardware or a Windows update?
Please, report back the status (ON, OFF, BLINKING) of the following LEDs:
TONER
DRUM
PAPER
STATUS
Apr 01, 2010 | Brother HL 5140 Laser Printer
Printer status window interface stopped working dell AIO 926
I know this sounds too simple, but get a new USB cord. I had the exact same problem and it was driving me crazy. I followed all the advice about uninstalling, reinstalling and updating multiple times and it never fixed the problem. Finally, my husband made the simple suggestion that maybe it was a problem with the connectivity of the USB cord. I didn't have much faith in it, but I bought a new USB cord and hooked it up - and I have never had a problem with the printer since then. My original USB cord (the one replaced) was the one that came with the Dell printer - perhaps there is a flaw in the cord somewhere. ?
Jan 16, 2010 | Dell 926 All-In-One InkJet Printer
Job Status Window Interface has Stopped Working. I am using Microsoft Vista and my printer is a Lexmark X5650!!!
cancel all the jobs in the quee.... reconnect the printer ....restart the system also ............. if status not changing reinstall the printer driver..........
Oct 30, 2009 | Lexmark X5650 ALL-IN-ONE PRINTER
Job Status Window Interface has stopped working.
The issue usually occurs if you are using windows xp drivers on a vista machine. It's strange that the error does not come up when printing from internet explorer 7.0.
There is a file on support.dell.com that you can run to remove any xp drivers and then run the vista installation file. that should take care of these error messages from the operating system.
you can copy and paste the following links to download and run the files :
Patch file to remove xp drivers:
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=224499
Driver for vista
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=203951
Feb 17, 2009 | Dell A960 All-In-One InkJet Printer
"printer Status window Interface has stopped working" Windows Vista, seems to be associated with Visual C
Had this problem with a Dell AIO 924 printer, searched everywhere for an answer and found one! - after uninstalling google sidebar and google chrome - not had a problem since :)
Apr 19, 2008 | Office Equipment & Supplies
43 people viewed this question
k24674
jasbo
jasbo
