Question about HP iPAQ H2210 Pocket PC
Would my ipaq freeze up because the battery is low
    Problem Solver:
  • 7 Answers
These pocket pcs are known for this problem as it has a slow processor.
depending what you are trying to do with it the best size to go for is 400 mh.
Posted on Aug 18, 2009
    Problem Solver:
  • 3 Answers
Maybe, because there is less power to power up the processor.
Posted on Jul 24, 2009
Have had a HP ipaq rx1950 for about 2 years and last month it has stopped charging the battery. I bought 3 batteries and each one does not charge. I put these batteries in another person's ipaq and...
its just 3 things.
1; battery
2: charge regulator on the device.
3: power pack
one is bad.
so its not battery, now its #2 or #3
seen the regulator is toasted
very common
why not buy as used spark same device, and mix part to get good
or ditch it and upgrade,
Mar 12, 2017 | HP iPAQ rx1950 Pocket PC
My HP iPAQ HW6910 keeps freezing. Sometimes it loads up to the main screen and then freezes after about 30 seconds, other times it gets as far as the windows loading screen and then most of the time it...
HP iPAQ week, wow.
let me guess , hp has no support now in this old thing and you need help.question 1: why use this thing,question 2, how much will you spend on this worthless broken thing? or buy parts, or batteries for it or 3 how much labor on such and old thing is warranted.?
May 29, 2017 | HP iPAQ hw6910 Smartphone
My hp ipaq 3950 freezed
press reset button with your stylus or take out the battery for a couple of minutes, put it back in and power on the device
Aug 21, 2009 | HP iPAQ H2210 Pocket PC
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
Hp ipaq 3715
Hopefully you can do a warranty repair, I'm pretty sure the main board is damaged since a hard reset should have taken you back to the factory defaults.
Dec 10, 2008 | HP iPAQ RX3715 Pocket PC
Battery charge goes off
Something got shorted or broken inside. It's a electronic failure. Your ipaq needs a new PCB board or get replaced.
May 05, 2008 | HP iPAQ HX2490 Pocket PC
HP iPAQ RZ1710 Pocket PC freezes on pin entry!!
If still freeze after the resets, then try to do a Hard Reset.
With this way you will restore your device at the default condition.
Take care to remove any external memory from iPAQ before to this and also have it
full charged.
The bad of this....you will loose everything stored at the internal memory of iPAQ.
The good this...your iPAQ would be alive again ;-)
To to a Hard Reset press at the same time the reset button+calendar button+today button.
Jan 10, 2008 | HP iPAQ RZ1710 Pocket PC
HP Ipaq 4155 not recognizing battery
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Nov 07, 2007 | HP FA162A for iPAQ 2215/4155 Keyboard
IPAQ 2795 freezes during boot up.
I had the same problem. Contacted HP customer service chat, and got the following answer that
solved the problem:
1. Remove the battery for 30 minutes.
2. Insert it again in the iPAQ.
3. Perform a clean reset on the iPAQ and at the same time charge the iPAQ.
To perform a clean reset please follow these steps:
Press and hold the Calendar button, the Power button, and the Messaging button.
While holding these buttons, use the stylus to lightly press the Reset button on the bottom of the HP iPAQ.
The problem can also be solved by getting a new battery, and performing the clean reset while charging (using the portable charger, not the cradle).
Nov 16, 2006 | HP iPAQ HX2795 Pocket PC
IPAQ freezing after hard reset on the 9am dental appointment screen
https://h30434.www3.hp.com/
ask hp so all can laugh.
this thing is 100% obsolete. now.
try new battery yet?
Aug 12, 2017 | HP iPAQ RZ1710 Pocket PC
HP iPAQ H2210 Pocket PC Logo
116 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
