I have a kenmore electric dryer model 66812 it was running and then just stopped and wont start again. I the breaker didn't kick and I can't find any signs of burnt wires or a fired board or part. Any ideas.
The dryer will not start with a broken door switch. Replace the
door switch if found defective.
Most dryers have a door switch actuator lever - when you close a
dryer door, it presses against the lever, which actuates the door
switch. If the lever is broken, the switch would not activate and
the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch
assembly and it is recommended to get the whole assembly since there
is almost no price difference between the door switch assembly and
just the lever. Check your model for more details.
Sounds like the operating thermastat may be bad letting it get too hot and causing the motor breaker to kick out . When it cools it will start again. Check all thermastats.
on the front of dryer open the door there should be a tag or on the rear where the cord goes into the dryer there should be a tag to tell you what the voltage is
should be a 250 volt plug and outlet to match
nema # plug-S42 AND THE OUTLET # 6-30 OR 6-50
Check the dryer breaker pair in the house electrical panel--Push OFF, then ON. Try operation, if still nothing, recheck breakers. If tripped again, there is a short to ground within the dryer--usually the heating element.
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
