Question about Intel D845GVSR Motherboard
Connecting monitor to gateway 400 vtx laptop
My husband disconnected the monitor from the board and I can't see where they snap back on.
  • 41 Answers
Hi Spratty,
You can fix this problem simply by pulling the computer out, then looking for a blue vertical port (if you don't have a graphics card) or a blue Horizontal port (if you do have a graphics card, which is usually located at the bottom of the computer.)
Count the pins on the cable then count the pins on the port.
The end of the monitor cable should be Male which are pins only and the port should be Female which are slots where the pins go.
Make sure that the sides of the cable matches the sides of the port (which is a upward angle)
If you have anymore problems please let me know,
Posted on Nov 18, 2007
I have a gateway FPD1975W monitor with a Gateway GT5482E computer. The monitor does not display the computer output - the blue power light blinks off and on steadily and every so often the monitor says...
From your description you have a power supply problem, usually caused by defective capacitors, sometimes they will bulge at the top indicating an open condition. If you decide to repair check the inverter board that powers the back lights behind the screen, because they are also prone to bad caps.
Feb 17, 2011 | Gateway FPD1975 19" LCD Monitor
Replacing laptop monitor. The new monitor
If it was not the right kind of LCD it may have blown the inverter (where the LCD connects and the cable going to the motherboard). You should order parts only from an authorized Gateway part reseller as advertised on the Gateway website. I have included a link to one such place below, where you can purchase a new inverter board and LCD screen if needed.
Good Luck,
Jan 31, 2010 | Gateway M-1628 Notebook
Gateway FHD2400 flickering / blinking / flashing on and off whether connected to laptop or not. Only had the monitor for about a year, and I've barely used it. I connect it to my Mac Powerbook, and after...
Open the monitor, examine the circuit boards. Look for small components that look like small cans, these are capacitors. If you see any that look bulged on top, then your problem can probably be solved by replacing these. Check out the following sites;
Follow the directions and good luck!
Jan 18, 2010 | Gateway FHD2400 24 in. LCD TV
Same issue with no words
This is usually caused by the cable between the monitor and computer being disconnected (or partially disconnected) or damaged. Video card failure on the computer can also cause this as well. If you have access to a laptop, or friends laptop, try plugging in the monitor to the laptop. If starts working correctly, then cable was unplugged or video card has failed in computer. Also check cable connection on back of monitor.
Aug 25, 2009 | Gateway FPD1975W 19" LCD Monitor
Wanting to disconnect laptop screen
it would be simpler just to use a usb keyboard and mouse and just use it as a desktop computer
Aug 01, 2009 | Computers & Internet
My Gateway 450ROG laptop/notebook has problems on start-up. Whenever you turn it on, the fan starts up, then the three lights blink and there is a tone heard immediately after that. But there is nothing...
Try hooking the Laptop to an external monitor like from your desktop pc,,you can see the connection on the back of the laptop,,When you do this, and you can see Windows on the Desktop monitor,,then this would indicate that your Back light on your Laptop screen may have burnt out .
Dec 02, 2008 | Gateway 450ROG Notebook
Monitor on a 400 vtx gateway
Check the output voltage of the invertor board , if its 150 volt (point of cold fusion lamp connection) then the drive electronics of the invertor board from the motherboard is damaging the new invertor boards which you are trying to replace. Check input to the invertor board it should be 5 Volts and 12 volts .
Apr 29, 2008 | Computers & Internet
Gateway 400 VTX tries to power up then shuts off no screen activity
bad power supply i would try 1st is it clean too doe sit get hot run a labtop cooler off ebay on it
Jan 06, 2008 | Dell Inspiron 8500 Notebook
Intel D845GVSR Motherboard Logo
44 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
