Question about Sewing Machines
Will you provide me a manual for mechanical zigzag singer 1247 for free? need it badly
  • cindelslippe Jun 25, 2009
    thanks. i just want to understand more my machine.
  • yadayada
    yadayada May 11, 2010
    not here
    Problem Solver:
  • 9 Answers
Go to sewingmanuals.com. You can pay for a download or a dvd for your model
Posted on Jun 30, 2009
Will not zigzag or decorative stitches. New to these newer plastic style machines Always used older steel machines. This was given to me my by my sister who used it very little. Could cam be broken?
Hmm, I'm wondering if it has been cleaned and oiled recently. Older mechanicals require frequent TLC. Consult your owner's manual for cleaning and maintenance instructions:
Is your sewing machine mechanical (ie, not computerized)??? CAUTION--if your machine is computerized, do NOT proceed with the following suggestions.
If it is mechanical, have you cleaned and oiled your machine recently? Most mechanical sewing machine failures are because they have not been adequately and routinely oiled, the old oil has solidified and frozen the mechanics. I recommend Bernina oil or liquid Tri-Flow Synthetic Lube (or similar good quality sewing machine oil) for mechanical machines--do NOT use 3-in-1, cooking oil, WD-40, or the sewing machine oil from your grandmother's sewing basket. (I am not associated with any Bernina dealer.)
If it is in fact frozen, pick up a bottle of liquid Tri-Flow Synthetic Oil at the hardware store. Oil one or two drops in every oil hole (see your manual) and also every place where metal rubs on metal. But DO NOT oil any plastic gears, rubber, or belts. If it is still stiff or frozen, direct a hot handheld hair dryer into the top and bottom mechanism of your machine. See if that loosens it up. You may have to repeat.
Once your machine is working again, place a drop or two of good sewing machine oil as directed above. Be sure to use a small brush to clean the lint and dirt out of your machine, especially around the feed dogs and bobbin area. (Caution: Compressed air will sometimes force the dirt and lint into areas that cannot be cleaned.) And continue to use good quality sewing machine oil to keep it running. Recommendation: every time you change a bobbin, after 8 hours of sewing, or every six months if it is not in regular use.
Dec 30, 2015 | Singer 6038 Mechanical Sewing Machine
I cannot get tight tension on zigzag underneath stitch on my singer 3221
There are a couple of things to check. First, did you thread with the presser foot UP, so that proper tension is applied to the upper thread? Is your bobbin correctly inserted, and is your bobbin case inserted evenly and correctly? Review your user's manual--if you don't have it, you can download it free at the Singer website.
If you have done these things, you may need to adjust your bobbin tension. First, run a line of straight and then zigzag stitches on a scrap of fabric and take a look. It helps to have two different colors of thread, with the fabric a third color. If one side of the zigzag looks fine and the other side looks like "chicken tracks," the chicken tracks side is too tight. In other words, you need to determine whether your bobbin tension needs to be tighter or looser.
You'll need a very tiny straight-slot screwdriver. Remove the needle plate--there are two screws in it--and remove the bobbin and then the bobbin case. On the side, there are two tiny screws. One is a Phillips--leave that one alone. The other is a straight-screw, and that one regulates the bobbin tension. The rule is "righty-tighty, lefty-loosey." Only turn it 1/4 turn, then reinsert and test. If you're on the right track, you should see at least a LITTLE improvement. DON'T do any more than that--if you don't do this carefully and systematically, you'll make things worse instead of better!
Jun 10, 2014 | Singer 2263 Mechanical Sewing Machine
Singer sewing machine needle moving to the side after it's in the fabric for a zigzag stitch
If you can grab the hand wheel and move it right and left, then it probably needs a plastic collar that goes next to the left upper shaft bushing.
If not then the cam timing needs to be adjusted.
Mar 13, 2014 | Kenmore 15516 Mechanical Sewing Machine
How to fix zigzag problem
Have you changed the needle and cleaned and oiled the machine per the instructions in the manual? Is the needle in correctly and fully up in the needle clamp?
Jan 07, 2014 | Singer 5050 Mechanical Sewing Machine
I need a manual for a Singer Zigzag 477
Singer manuals are available from their website.
Browse to http://www.singerco.com/accessories/instruction-manuals
and in the search field type in your model number, in this case, 477, then click "search".
Most manuals are free to download as pdfs.
Aug 01, 2011 | Sewing Machines
To learn how to do zigzag
singer.com has a free operation manual
go to the home page & in the search box put 3116,,the manual on the bottom is a free download
it will have the info you need
Nov 30, 2010 | Singer 3116 Simple
I lost my manual and would like to find one that is downloadable that isn't too expensive as I need to do a zigzag stitch and can't figure it out.
There's a free to download on available on the Singer website.
http://www.singerco.com/accessories/manuals.html
Just type in 1418 and click on Search.
On the next page just click on free download!
The model number changes to W1418 as the W means White.
Hope this helps!
Sep 13, 2010 | White Sewing 1418 Mechanical Sewing...
Singer machine needle won't do width in zigzag
It sounds like it needs lubrication on the needle bar frame and linkage.
Oct 01, 2009 | Singer 5050 Mechanical Sewing Machine
Sewing Machines Logo
88 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
