Question about Vehicle Parts & Accessories
Does chrysler sebring 07 model need bypass module
Do i need to buy an immobiler bypass to install a remote starter for my 07 sebring touring?
  • 53 Answers
Yes you will need a bypass,
Posted on Jul 14, 2009
Location of starter relay for a 2010 4 cylender touring sebring
The starter relay is called the starter solenoid and is located on the starter motor.
Sep 08, 2016 | 2010 Chrysler Sebring Touring
My remote starter for 2008 sebring starts but shuts off in about 10 sec
Is this an aftermarket remote starter? Is this a new install or has this unit worked in the past? It sounds suspiciously like the vehicle immobilizer system is shutting down the vehicle since it knows that the key is not in the ignition. Most aftermarket kits require "bypass module" to fool the immobilizer during the remote start running period. These can fail or reset and this can cause the symptoms you are having. If it is a factory remote starter, I'm at a loss unless theirs has a similar configuration and this can have the same issues.
Mar 13, 2015 | 2008 Chrysler Sebring
Fuel Rail Leak
Did did you change the o-ring at the fuel line to fuel rail connector? Do that before you change the fuel rail. According to an e-bay seller who is selling a used fuel rail from his salvage shop, the following fuel rails are interchangeable.
300 05-10 Fuel Injector; 2.7L and 3.5L
AVENGER 08-10 Fuel Injector; 2.7L
AVENGER 08-10 Fuel Injector; 3.5L
CARAVAN 08-10 Fuel Injector; 4.0L
CHALLENGER 09-10 Fuel Injector; 3.5L
CHARGER 06-10 Fuel Injector; 2.7L and 3.5L
JOURNEY 09-10 Fuel Injector; 2.7L
JOURNEY 09-10 Fuel Injector; 3.5L
MAGNUM 05-08 Fuel Injector; 2.7L and 3.5L
NITRO 07-11 Fuel Injector; 4.0L
PACIFICA 05-06 Fuel Injector; 3.5L
PACIFICA 07-08 Fuel Injector; 4.0L
SEBRING 04 Fuel Injector; Conv, 2.7L, from 07/30/03
SEBRING 04 Fuel Injector; Sdn, 2.7L, from 07/30/03
SEBRING 05 Fuel Injector; Conv, 2.7L
SEBRING 05 Fuel Injector; Sdn, 2.7L
SEBRING 06 Fuel Injector; (Conv, Sdn), 2.7L
SEBRING 07 Fuel Injector; (Sdn), 2.7L
SEBRING 07 Fuel Injector; (Sdn), 3.5L
SEBRING 08-10 Fuel Injector; (Conv, Sdn), 2.7L
SEBRING 08-10 Fuel Injector; (Conv, Sdn), 3.5L
STRATUS 04 Fuel Injector; Sdn, 2.7L, from 07/30/03
STRATUS 05 Fuel Injector; Sdn, 2.7L
STRATUS 06 Fuel Injector; (Sdn), 2.7L
TOWN & COUNTRY 08-10 Fuel Injector; 4.0L
Mar 04, 2014 | 2007 Chrysler Pacifica Touring
Starter isn't working
Immobilizer Systems are common in most vehicles today. That's remote starters should be installed professional installers. What's the year, make and model of your vehicle?
Feb 14, 2014 | Prestige Remote Start
Vehicle dies after remote start
remote starter not working properly, either it is not bypassing the security system or the tach signal to the module is not being recieved..
Nov 15, 2013 | 2008 Chrysler Town & Country Touring
Transponder for 2006 mitsubishi eclipse for remote starter
Yes, There are two Immobilizer bypass modules on the market that will work with your vehicle without having to sacrifice a key. Xpresskit offers the DBALL and PK9. Both require programming to function properly.
Sep 08, 2012 | Remote Starter with Keyless Entry
What does po513 engine code mean on a 2004 chrysler sebring?
It means that you have an invalid immobilizer key, or invalid skim key.
Do you have an aftermarket alarm that is remote start compatible? if so, the skim is reading that the car is starting without a key, but the alarm module is allowing it to start, bypassing the skim module.
It says in the owners manual that the skim key module is not compatible with remote start alarm systems. your alarm is bypassing the skim module. the problem with this is that someone can start your car without the key if they can get through the aftermarket alarm.
May 23, 2011 | Car Audio & Video
Can you program the cars key fob to start the car for as-tcbm remote start
The Audiovox ASTCBM is nothing more than an immobilizer bypass interface to be used with a remote starter unit. First, you need a remote starter. Then, you may or, may not need the ASTCBM, depending on the vehicle.
Jan 12, 2011 | ASTCBM Generic Factory Remote Start ByPass...
Immobiliser problem wrangler jeep
Ok well i assume you are trying to install a remote start/alram system. Her is all the info you should need to do so.
1. vehicles with gray keys have immobilizer system installed. If your vehicle is equiped with an immobilizer system a bypass module is required because you have sentry key immobilization. you can find this bypass module at Circuit City or Best Buy. The bypass module part number is 555cw but there is also a unversal module that can probly be used just ask the salesman selling you the module i belive the universal part# is 556uw. Now I will list your wire colors and locations for your vehicle
__________________________________________________________________________________
1. 12 volts - pink/blk - ignition harness
2. starter - yellow - ignition harness
3. ignition - blue - ignition harness
4. accessory - black/orange - ignition harness
5. second accessory - black/green - ignition harness
6. parking lights (+) - black/yellow - headlight switch
7. door trigger (-) - yellow - headlight switch
8. dome light supervision - use door trigger -
9. tachometer - gray - ignition coil
10 speed sense - white/orange - white plug, pin 27 PCM ( the PCM is on the passenger side firewall under the hood )
11. brake wire (+) - white/tan - brake pedal switch
Well thats about it. hope this helps
Luis
Dec 03, 2008 | Vehicle Parts & Accessories
Vehicle Parts & Accessories Logo
273 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
