WM2355CS LG Front Loading It will not drain
WM2355CS LG Front Loading It will not drain and makes a clicking noise when it tries, other than that the cycles work. We recently had some home renos done and I think a screw may have ended up in the closthes and through the machine. How do I take it apart to check?
  • 126 Answers
Remove lower front access door /panel.first you'll see a hose that you can drain the machine with .after draining remove pump cover and check for debris.make sure none of the impellers have broken. Hope this helps ,pleases rate my solution :)
Posted on Jun 26, 2009
Why won't my LG model WM2688HNM front load washer not drain? It spins and makes noise
sounds like a bad or clogged water pump but may also have to look the door switch which on some models wont allow it to spin or agitate? a bad motor coupler will not allow spinning or have bad weak spin cycle sorry cant be more specific by the way front loads tend to be a pain in the___ to work on good luck
Jul 26, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washer wont spin and makes a clicking noise
I have a LG front load and it won't spin or drain... Can u please help me
Jul 01, 2012 | LG WM1814CW Front Load Washer
My LG front loading washer makes a train noise during the rinse cycle. What could be the cause?
if it is right after the drain cycle; it then goes into a spin. It then starts to fill with water for the rinse while the tub is still turning. The water entering the tub while the tub is spinning, cleans the tub of soap and the water going through the holes in the tub are causing the noise. It is normal if only in the rinse cycle.
Aug 29, 2010 | Frigidaire GLTF1670A Front Load Washer
Lg tromm dryer making a thumping noise when running. What could this cost me to do myself or pay specialist to fix?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
ssgf
Feb 07, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Kenmore front loading washer won't drain or aggitate, just buzzes
take the front bottom panel off. inside there is a drain pump. you need to remove filter from drain pump its look like a knob. be careful because their is water inside your drain pump so use some big thing for water. clean your filter. put filter back tight. i hope will solve your problem.
May 23, 2009 | Kenmore 43142 Front Load Washer
LG TROMM washing machine can't open door
You need to unplug the machine, and drain the water from the drain hose, accessing the drain pump.
Once you access the drain pump also remove all obstructions in drain lines, this often fix teh problem.
If you do not have done anything similar before, then it is better to call the technician.
Jan 08, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
NO SPINNING NOR DRAINING LG TROMM SER.WD-12210DB 10kg
check your pump to make sure that it is clean there is a door on the bottom of the machine open it use the little hose to drain the washer in a bucket then twist the big cap and pull it out clean that trap
Dec 26, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Lg wm1832cw front load washer
One of 2 things may be causing the loud noise.  Either the rear bearing on the drum has failed and will need to be replaced (very expensive) or the drain pump has a bearing problem and is making a very loud noise when it is draining (not too expensive).  Either way, you will need a qualified LG technician to diagnose and repair the problem.
Jun 14, 2008 | LG WM-1832C Front Load Washer
Washing Machines Logo
490 people viewed this question
Top Washing Machines Experts
