Question about Dryers
LGN2000KQ1, how do I get front cover off to get to coils
    President:
  • 1,136 Answers
UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto.
If I can assist you further, please let me know.
Thanks
Vic
Posted on Jun 25, 2009
  • Berktown Apr 03, 2011
    Great reply, this helped me a lot. The only thing I would add is that there's also a white, plastic electrical harness connection that must be moved or disconnected in order to get the front panel out of the way. I found it was easiest just to put the small black plastic clip down through the hole that it's in, giving the wiring some slack.
Which coil pack fires 1 cylinder on 98 Toyota Avalon 3.0
The number 1 cylinder is located at the rear left of the engine, looking from front to back of the vehicle.
Feb 15, 2015 | 1998 Toyota Avalon
Cylinder 3 location on a 2004 gmc envoy
The coil pack will be numbered. Find coil #3 and follow the spark plug wire to the spark plug.
Jun 15, 2014 | 2003 GMC Envoy
Lgn2000kq1 starts a flame but then goes out
could be a bad thermostat,, check here to see what they look like and how to test them http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Jun 13, 2011 | Whirlpool Dryers
Ignition coils setup for 2004 lincoln ls v8 3.9 engine
COP Coils
cyl 1,2,3,4 on pass side-front to back
cyl 5,6,7,8 on driver side -front to back
Remove coil covers on top of valve covers, 7mm socket and wrench
7mm socket and one screw holding coil
Codes PO 301 to PO 308 are your coil locations.Last # is cyl.
You get all sorts of codes, ignore all but the 301.302,etc
If you get an ETC Failsafe or shut down,a coil is spiking the PCM and coming back on both sides of the TPS and putting it into Failsafe. Still just a really bad coil. You will get about two a year.
Aug 14, 2010 | 2004 Lincoln LS
I have a LGN2000KQ1 gas dryer and it won't heat up, what should I look for. It runs but doesn't heat up and dry the clothes.
check that you are getting gas and that the ignitor is sparking properly shut off the gas first remove the cover also get an amp meter hook the meter on one of the igniotr wires should read 3.3 amps if it is less then change the ignitor hope this helps
Jul 21, 2010 | Whirlpool LGN2000LWH Gas Dryer
Where is the coil pack located on lincoln ls v8 7
Driver side valve cover
7mm socket to remove coil covers and coil
1 thru 4 pass side
5 thru 8 drivers side
Front to back
Jul 12, 2010 | 2002 Lincoln LS
Where are spark plugs on 2004 kia optima and how do i get to them
if it is a 6 cylinder remove engine cover 4 ten mm bolts three are in front under coils then three are under intake if it is a four cyl remove plastic cover in center of valve cover they are under coils and i beleive there are 2 wires as well as 2 coils
Jul 22, 2009 | Kia Optima Cars & Trucks
Location of the coils on a 2002 xg350 eng.
take off engine cover and there will be three on the front valve cover and 2 10mm bolts on each coil pack holding them down
Apr 07, 2009 | 2002 Hyundai XG350
Taking off cover to clear coils????
Not sure what model you have but most slide out of their cabinet after removing the front plastic grill that holds vents. Front should snap loose, but be sure no screws hold front in place. As always use care and unplug while working on your unit. Take care not to wet electric controls or motor windings. Thanks
Jun 08, 2008 | Maytag M7Q08F2ACOM Air Conditioner
Dryers Logo
76 people viewed this question
Top Dryers Experts
