Question about Hayward 250kbtu Ng Pool Heater - Inground
Pool heater cabinet gets so hot it burned the wires
I have a hayward h250 heater. the pool water temp was 80 but the heater was so hot it was melting wires and melting the labels on the cabinet
  • richardkeese Jun 26, 2009
    Thanks for your input. Before start up this year i took the burners out and cleaned them and cleaned everything but the heat exchanger. the flames are strong and blue. The front of the heater box gets way too hot
    President:
  • Hayward Master
  • 1,378 Answers
That condition is from rollout of the burner flames. Check the underside of the heater top for a buildup of debris. Clean it if necessary. You may notice your heat echanger looks like a BBQ pit. If so it is sooted over and needs to be thoughouly cleaned before further use.
If you find this condition, you should also look at your burner tubes once the exchanger is cleaned and the heater is operating. Be sure the flames are nice and blue and 3 or 4 inches tall. If they are not, and especially if they are mostly yellow/orange, you need to do some more inspecting for what is messing up your combustion, which would have led to the soot.
Finally, if none of the previously mentioned conditions exist, consider wind pressure over the top of the heater. In windy areas and in certain installation conditions, you may needa high wind stack to provide positive drafting of exaust gas.
Posted on Jun 26, 2009
  • John Prohaska
    John Prohaska Jun 26, 2009
    Have the temp limit switches been bypassed? They are mounted on the wall behind the front panel, about in the center? Is there a roll out sensor along the bottom (it would look like the same type of switch as the limits on the wall)? When you removed the exchanger and cleaned it, did you notice the condition of the fire tile inside? Finally, once you cleaned the exchanger, could you see clearly through the fins?
    It has to be something forcing the gases/heat to back up or damaged fire tile. It would concern me that the limits are not tripping before the wires are burned. If all the above are in good condition, about the only other option would be to install a wind stack.
Haywood h250 ignition override
not advisable check for loose wires and safety circuit
Aug 03, 2014 | Hayward Pool Products Hayward H250 250k...
What does lo mean on my h250 hayward pool heater
LO standss for limit open. the most common cause is lack of adequate water flow through heater. other causes are high temp limits.
Jun 10, 2014 | Hayward H Series Pool & Spa Heater 400k...
Hayward H250 pool heater will not light
see if pressure switch full voltage both sides or hi limits
Apr 26, 2013 | Hayward Pool Products Hayward H250 250k...
Hayward h250 ed2 failure error code IF
ignition failure check gas source if ok check ignitor
Aug 03, 2012 | Hayward H-series Electronic Gas Pool...
Pf hayward error code on gas heater H250 IDPL1
check pressure switch if voltage both sides ok if not bad switch or clogged copper tube also check filters
Nov 16, 2011 | Hayward H-series Electronic Gas Pool...
Hayward H250 (millivolt) pilot won't stay lit
make sure the flame hits the thermo couple if so then replace it lows has them in the water heater section thermo couple gets hot makes millivolt signal then opens gas valve
May 08, 2009 | Hayward H Series Millivolt 250,000 Btu...
Hayward h250, wont heat
Sounds like it could be the flame sensor.
Apr 04, 2009 | Hayward H Series Electronic Ignition...
Hayward 250kbtu Ng Pool Heater - Inground Logo
445 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
