Question about Toro Lawn Mower With Toro Power Tools
Mower starts then it smokes
I put oil and gas in the mower - which I have for about a year. it started to smoke really bad! how do I correct this?
  • tmandink
    tmandink May 11, 2010
    Did you put oil in gas? If so drain gas , put gas and no oil in gas tank. If not could be head gasket. If it is 2 cycle oil and gas is mixed wrong.
  • 1,041 Answers
If you spilled any oil on the engine, it will smoke for a few good minutes until it burns off.
Or, you may want to check the air breather. It may be dirty.
Jim
Posted on Jun 26, 2009
  • Jim Parker
    Jim Parker Jun 29, 2009
    Did this solution solve the problem?
    Jim
I have a Briggs stratton 14 hp ohv I/c quiet model 287707. I had a guy change the oil & he put 10W30 synthetic oil in it. Now it smokes white smoke really bad. I think he put the wrong oil in
There is a very real difference between 30W and 10W30 oil. Whether it's synthetic or not probably doesn't matter. If you have the literature that came with the mower, it will tell you the recommended engine oil.
If they put in the wrong oil, they should make it right. You shouldn't have to pay twice for an oil change. It could be burning oil, since 10W30 is a lower viscosity than 30W. I would have them change it again, and see if it stops smoking.
Nov 24, 2014 | Garden
Have a troy bilt trimmer mower 5hp that is at least 10+ years old. very hard to pull start, when it does start it chugs about 5 seconds, and dies. like the spark plug really never gets it fired up. also...
you could have several problems with your engine . one it could be off timing it could have a sherd flywheel key or you could have a stuck ring or bad rings also a scored wall.. white smoke is oil if you have tipped it over you have to let the oil burn out of the cylinder if you believe its your plug take the plug out and clean it off with some gas and a soft wire brush and put it back in see what happens .
Nov 04, 2013 | Troy-Bilt Garden
John Deere LA110 riding mower has gas in the oil
Try stripping it down and having alook sounds like the piston ring has snapped and is pumping gas into the oil that would explain why the oil is coming out the the exhaust the black smoke is just oil burning up ou also might want to clean the carb alittle too.
Mar 19, 2012 | John Deere 22HP Hydrostatic 42" Riding...
Lawn mower running rough
adjust the carby. also u might want to replace the diaphragm in the carby. might work wonders
Mar 31, 2010 | Mtd LAWN MOWER PART # 791-180705 Assembly,...
Engine started smoking real bad, it still starts
Could be just a head gasket, also could be rings. Could also be oil in the gas or bad gas overall. Empty out the gas, change the oil, and try again. If it does the same thing take it to service shop.
Sep 29, 2009 | Poulan Pro " Pro" Self Propelled Mower
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Lawn boy 2 cycle that smokes
Check the air breather. Make sure it is clean.
If it is clean, you will probably need to replace the diaphragm. A bad diaphragm will cause black smoke and also cause the mower to run erratically.
Jim
Jun 21, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Billows of white smoke when Toro lawn mower runs
You overfilled the oil. If the mower runs, just go ahead and mow grass until it runs the oil out of the gas tank. Or you can empty the gas tank and fill with new gas. White smoke is not a serious problem. Only a hassle.
Jun 19, 2009 | Toro Lawn Mower With Toro Power Tools
Lawn mower engine runs rough and puts out white smoke
Pull the carburetor and clean it for staters.Be sure to change oil any little bit of moisture in the crankcase will let it smoke white by seeping by the valves and piston rings.Also put a little small amount of dry gas in the gas tank to rid all of the water that may have been left in the tank. I some of this will help you.
Mar 18, 2009 | Garden
Toro Lawn Mower With Toro Power Tools Logo
229 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
