Question about Dometic Rooftop RV Air Conditioner
Our rv air cond. won't cool inside our storage bldg. we have been told the air is too hot inside the building and the air cond can't condense and cool the feron is this true or is ther another cause for this problem
  • 1 more comment
  • herndon1257 Jun 25, 2009
    our rv is a 38 ft holiday rambler, it is stored inside a 20 ft wide and 70 ft long and 18 high. We have had the air cond recharged. what do we need to do about this.
  • herndon1257 Jun 26, 2009
    are we going to get another response to our question
    We would like a response to our second question
    Genius:
  • 1,341 Answers
If your a/c has sufficient ways to breathe in air then it should provide cool or cold air.There is no such thing that an A/C cannot provide what's it's meant to do base on the building being hot.You need to assess your a/c very well.Is everything working as it's meant to be..Is the compressor working etc..
Posted on Jun 26, 2009
    Sergeant:
  • 353 Answers
If the space is too large and not insulated the unit will not transfer the heat out fast enough
that is assuming that the unit is installed and running properly
if it is just sitting in the room it will not cool
12,000 btus per 600 square foot 12,000 btus = 1 ton
Posted on Jun 25, 2009
How many tons do I need to cool a bldg 20,000 sq. ft.
Determining the total tonnage to cool any building depends on the heat loss calculations. Points to include is the R rating of the insulation, the square footage of the windows and doors, How hot does it get in the summer? Also the materials the building is made of. ie. Steel. concrete, wood exterior walls.
Jan 26, 2015 | Heating & Cooling
The air coming from the air conditioner is not cold
First, power everything down! You will need to climb on top and remove the cover. Inside you will see the compressor, condenser grill, a contactor-relay and capacitor. Most likely it is either the capacitor or contactor-relay (70% probability) or the compressor (25%). If you see ice build up on the connections or on the condenser grill it could be that you are low on freon or have a leak in your sealed system.
If things look normal then I would go with the contactor-relay and capacitor. If things are iced up, you will need trained technician help. Most AC shops will work on it, but won't have the Dometic parts. An RV place will have the parts but you usually pay a premium price for the labor and service.
Aug 18, 2011 | Dometic Rooftop RV Air Conditioner
Rv ac throws the breaker when outside temp gets high, unit works fine at night when outside temp cools down
Clean evap and cond coils
Place hand on a/c if too hot during the day but cool at night
then freon is being restricted in the condensor
Cleaning coils may help days
Put a trickle of water on the condensor during the day for a test.
.If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 07, 2010 | Dometic Rooftop RV Air Conditioner
Not cooling
check the and see if the condenser fan is running. you will find it if you take the top off also check and see if the condenser coil is clean. if it is dirty or the fan under the top is not running it will cause the compressor to short cycle on limits or overload.
May 29, 2010 | Dometic Rooftop RV Air Conditioner
ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Mar 10, 2010 | Carrier Heating & Cooling
PART # 7330B730 SERIAL # 109734610 1997-TIMBERCREEK R.V.
most of the time the condenser coil is dirty and needs to be washed out. with it dirty the pressures are elevated and causes compressor to kick out on overload. try washing cond. coil first
Sep 12, 2009 | Dometic Rooftop RV Air Conditioner
Does not heat real hot or cool real cold . dometic duotherm penguin markings on 85 or so unit
Heat real hot? Is this a heat pump or do you have a heat strip installed. Get a regular thermometer and put it in the outgoing vents of the unit. Register the temperature there and then the outside temp. If it is cooling at 17 to 23 degrees below ambient temperature, the manufacturer says this is fine. Try cleaning the condenser out on the top of the rv. Gently hose the rear condenser out until all the dirt and grime is removed the unit. Try cooling again and see if it is better.
Jul 04, 2009 | Dometic Rooftop RV Air Conditioner
Rudd heatpump doesn't cool
Hi, Is the condenser fan running? If not, Check the circuit breaker inside the house and the quick disconnect at the condensing unit. Making sure the power is off, check for any bugs in the contactor. If it is running, check to see if there are any resets on a high pressure switch or control board in the condenser. Check the compressor capacitors and see if they are leaking oil or swelled up. are there any burned wires? Is the compressor hot? If the fan is running and the compressor is not hot it is probably off on Low Pressure and needs charged by a licensed Air Cond Tech. Hope I have helped. Let me know. kstfas
Sep 24, 2007 | Ruud Matching Split Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
46 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
