Fills with water, doesn't drain the overflows.
Fills with water but doesn't drain. appears to wash and spin but the water doesn't drain.
thanks
  • 686 Answers
Post the model number
Posted on Jun 26, 2009
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
LG WM210HW doesn't fully drain
Pull the drain boot that runs from the tub to the pump and check it for blockage. Post the results back to me.
Feb 03, 2013 | Washing Machines
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
Kenmore washer 90 series - 1/2 hour ago we replaced the coupler and clutch because it would not spin. Now, it spins great - if you manually set the knob to spin! It will not move through the cylcles...
the first thing to check is if the small appx. 3/8" diameter clearish rubber hose got disattached from the side of the outer tub espically if before replacing cluctch is didnt overflow
Aug 12, 2011 | Kenmore Washing Machines
My GE WCSR2090D top load washer has flooded our house in the past, and when looked at by a repair man he said nothing seemed wrong... so we continued to use it and it now leaks/floods only once in every...
You might have a partially clogged drain past your drain hose
(In the wall etc)
Thats overflowing behind the washer.
Watch the drain for a few washings and see if it overflows
It may be second or third or fifth load. Its hard to catch
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Sep 08, 2010 | General Electric WCSR2090D Top Load Washer
Washing machine overflowing
the valve on your inlet pipe may be faulty, have the valve checked or buy a new valve, not very dear, around $30 australian
May 30, 2009 | Whirlpool AWZ412 Front Load Washer
Kenmore 80 series washer doesn't stop filling up with water
Almost went and bought a switch until I widened by search for "kenmore washer 80 series overflow" and came up with this:
http://www.fixya.com/support/t1206464-kenmore_80_series_overflow
Turns out that a couple weeks ago, I had a really unbalanced load that probably shook off the tubing. Anyhow, saved me a trip to the supply store AND cost. Thanks to the original poster!
Feb 11, 2009 | Kenmore 22422 Top Load Washer
Over flowing on water discharge
This is not a fault with your machine.
The problem lies aquarely with the outlet pipe in the building plumbing. Very often there is a gradual build-up of grease in this pipe somewhere before the pipe gets larger to the main drain.
The first solution is to use a solid or liquid drain cleaner in that pipe - and leave it to work at least overnight.
Then fill a bowl with very hot water and Soda Crystals - basic washing soda.
Flush the pipe with a full bowlfull of this hot water (may need a large mouthed funnel)
Also a hosepipe from the hot tap to a pipe in the outlet will work.
Once clear - you shouldn't have anymore problems.
If you wish, you can wrap a polythene bag around the machine outlet, then force this into the wall drain pipe - to make a better seal. It's not ideal, but may help with pipes that are slow to drain.
Feb 01, 2009 | Kenmore Washing Machines
Model# 110 20902990 kenmore washing machine over flows
hi thanks for the question you could have a water valve problem how do you shut the water off by unplugging power cord or shutting off water supply if its unplugging the power cord you have a problem with water control switch or lint is caught in small plastic tube that goes to the water level switch check that could be no parts needed thanks the appliance doc
Sep 27, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing Machines Logo
53 people viewed this question
Top Washing Machines Experts
