Question about Ruud Matching Split Air Conditioner
AC is running but can't keep the temp down. Everything is brand new. AC unit is on shady side. New filter, no cloggs. No clog in drip pipe. Condinsation building up on pipes outside. Please help.
    Sergeant:
  • 340 Answers
If the big pipe out side is cold and sweating and the little one is warm to touch if it is hot to touch under charged. I would suspect insulation, or under sized unit
is their a 20f difference from supply air to return air the i would lean towards insulation. Tom
Posted on Jun 26, 2009
I have water drips from the filter on my dometic ac. Then when you change the settings or turn unit off it drains more water. I noticed a lot of condensation in the area of the coil foam housing
Sounds like unit is too small or there is too high of humidity. An A/C unit draws water out of the air as it absorbs the heat from the room. If the room is too big or there is too high of humidity the evaporator will freeze the moister and ice will build up then it will drip when turned off as the ice melts. As a fix, You can get a bigger unit, use a dehumidifier ( which works the same as A/C), or start the A/C at a warmer temp.and turn down gradually as air moisture disappears.
Sep 16, 2014 | Dometic Rooftop RV Air Conditioner
Where is the AC drain on NEW Jeep Liberty 2010 and newer
the FSM may cover this.
btw, my new jeep has this tube in a funny spot.
unlike any car if owned or restored (many in 50 years.)
the tube on my wrangler is near center of car, oddly
it must drip water or it IS CLOGGED. you are correct.
the water in the air must condense out and drip the the drain pan. then out. if it gets works the passengers feet and floor mats will soak in
condensate (pure water)
best way is to get under car (safely with real jack stands, never use a jack or bricks ever) and look. for the tube. its not easy but its there.
mine is very hard to see, in fact , it dripped in my face before i found it.
my 08 fsm
shows the Evap box rear has drain pipe and foamseal.
lower left bottom corner in photo.
prevention., there is a spray to buy that can kill fungus growth.
pull filters and spray down there.
sorry i dont have real fsm , for 2010
but mine does NOT show the tube path at all.
only the source of the tube.....
good luck.!!
Apr 22, 2014 | 2007 Jeep Grand Cherokee Overland
My ac unit is now after 3 weeks of use dripping water inwards(even with a 1/4" slope of the unit to the outside) is my drip pan overflowing?
Yes, your drip pan is overflowing, because the drain hole near the back of the unit is clogged. There are 2 ways to address this problem.
1. Look out side the house, under the unit and search carefully for the drain hole or drain tube. If it's a hole, clear it using something like a pipe leaner. It it's a tube, use 2 pipe cleaners twisted horizontally together and carefully run it up into the tubing in a push/pull motion. This will help dislodge any clogs.
2. If you're feeling really lucky, turn the unit OFF and unplug it. Straighten out a wire coat hanger leaving a little hook on one end. Remove the front cover of the AC unit and slide the coat hanger under all the mechanical parts into the drip pan. Sweep it around carefully in the drip pan. all the way to the back of the unit. Be careful not to get the little hooked end caught on anything, by keeping it flat against the drip pan. Doing this, may dislodge any clogs.
And finally, if you're in a high humidity area, increasing the tilt to 1/2" may help improve the drainage.
Hope this helps you unclog the problem.
Jul 20, 2011 | Heating & Cooling
I have a Weather King AC/Furnace in the attic that's dripping water into the drain pan. When we purchased our new house it came with this unit and it never dripped ater. Now, the water is dripping towards...
I assume it is dripping water when the AC is running. If you look at the attic unit, there should be a PVC pipe running from the unit - probably an insulated PVC pipe. This pipe probably goes across the attic to the edge of the house and drains outside. The drain pan may also have a drain pipe, but the one on the AC unit is the issue, and is probably plugged. Go outside and see if you can locate the AC drain pipe. See if the ground is wet below the pipe and if water is steadily dripping from the pipe (with AC running). If the pipe and ground are dry, the pipe is plugged. If you have a wet/dry vac, try connecting it to the drain pipe outside to see if you can **** the pluggage out. If you can get it clear, water should start dripping out of the pipe. This same thing happened at our house. I decided to cut the pipe in the attic, and add in a PVC isolation valve, tee, and water hose connection with plug, so I can valve out the AC unit from the pipe, remove hose connection plug, and hook up a water hose and flush the line to outside. Lowe's sells all of the PVC pipe fittings. The water pressure from the hose will always flush out the algae and crud to the outside of the house. I can also remove the plug and pour a cup of bleach down the drain pipe every couple of months to keep algae growth in check. I also cut out the trap (u-leg) from pipe in the attic and purchased a ready made trap a Lowes (the contractor who built our house had made a lousy homemade trap). I purchased a few PVC elbows and installed the trap on the drain pipe outside. By the way, our AC drain pipe comes out of our wall outside and drains near our outside unit. Our secondary drain pan drain pipe comes out outside from an eave on the side of the house. I don't know what you drain line looks like (it may have a port to add bleach, or some cleanout provisions, maybe not). If you choose to modify/improve it, then make a sketch of it, go to Lowe's and get the PVC parts you need + PVC pipe primer and cement. PVC cement dries fast. Remember, the pipe must flow downhill from you AC attic unit. You can use a regular wood saw to cut the pipe. I hope this helps you. You need to keep the drain line clear as algae will continue to grow in it. Pouring bleach in the line every month or two helps. You also need to check maybe once a month that the line is draining properly (check to see if dripping outside). You can get some serious water damage to your ceilings if the water backs up and overflows. I discovered that our drain line was plugged just in time as our drain pan drain line was also partially plugged and drain pan was about to overflow.
May 08, 2010 | Weather King 12AJA4201AH Air Conditioner
Air condioner climbs to 86 degrees
First check your coil behind the filter. If this coil iss clogged the unit will over heat and cause the compressor to shut down. It sounds as if either the evaporator coil (inside) or the condensor coil (outside) may be clogged. If the unit is icing up on the inner coil then that coil is clogged or low on freon. I would think it would be cloggged instead of freon problem. To clean this coil you can go to the hardware store and buy a can of coil cleaner and use it following the directions The outer coil you would have to remove a/c from sleeve and take the unit outside. Using a water house flush the condensor coil from the outside in to remove debris.. These coils should look like a brand new car radiator when you finished cleaning. Reinsert the a/c back into wall sleeve after letting the water evaporate from the unit as to not spill water through out the area. Good Luck
Dave
Aug 25, 2009 | GE AJCQ08ACB Air Conditioner
AC unit is running, but the house doesn't get cooler.
a/c is either on or off,there no in between.check air filters make sure they are clean.also keep in mind a/c will only bring temp down about 15 degrees from outdoor temp
Jun 23, 2009 | Honeywell Electronic Programmable...
Goodman Model CK60-1C with White Rogers mercury tube thermostat
The contactor on the outside unit is sticking and must be replaced. The inside unit cycles off and the outside continues to run causing the refrigerant lines to freeze up.
Jul 29, 2008 | Goodman CKL60AR60 Air Conditioner
Leaking water inside
Dear brians933,
If the air conditioner is window / wall mounted please make sure that it is tilted backwards about 3/8 inches. The front side should be upward and the out side portion of the AC downwards. If the drain pipe is blocked the water will leak inside. Please run a stiff wire or thin rod in the drain pipe and then **** the water out please donot blow in, the pipe is getting more blocked this way.
Hope this solve your problem.
Regards,
ramesh22
Jun 25, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Hotpoint MAC-130 air conditioner dripping water
You need to blow out the drain line where it hooks up to the pan and clean out the drip pan. It doesn't matter how clean you keep the filter, that's just to keep the evaporator coils clean, which is important in itself. But algae will grow in the drip pan if it is not tilted to drain correctly and will clog up the drain line. If you put a level on the top of the unit, the bubble should JUST BARELY break the line on the OPPOSITE side from the drain outlet on the pan. Hope this helps.
Jan 25, 2008 | Heating & Cooling
Water dripping (almost running) out of the left corner of air handling unit. Help???
You're correct in checking the drain pipe, because it's become blocked. The only trouble is, you're trying to clear the wrong end. The condensate water is spilling out of the air handler because that's where the pipe has a clog. These pipes usually have un-glued joints next to the air handler, for times such as this. If you can't pull them apart, you may have to cut the pipes and reconnect tham with fittings from the hardware store. (which is a normal procedure.) I usually use a wet/dry shop vac when repairing this problem, sucking out the clog & the water, then blowing out the line to where it drains outside. I've also used the clothes hanger technique to drag crud out of the air handler fitting. Hope this is helpful. ;)
Aug 10, 2007 | Ruud UAKA030 Air Conditioner
Ruud Matching Split Air Conditioner Logo
248 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
