Question about Viking VGSC306-4B Gas Kitchen Range
It takes too long for the oven to reach the desired temperature.
We have a Viking Professional Termal Bake range. It was converted from natural gas to propane and had no problems until this year.
    Problem Solver:
  • 15 Answers
Sounds like your ceramic ignitors have worn out - apparently they are to be replaced every 3-5 years. I had the same issue - oven took forever to het up.
I have two ingnitors in the larger oven & 1in the smaller one. Easy to replace (60$/each) - two wire and one screw each. The theory is when they fail to heat up properly the gas valve doesn't open fully, or won't open at all.
Also I'd clean the burners when in there ... mine corroded a bit and required brass wire brushing. There is a small horizontal cut ont the burner that goes one half the way around the burner that had 'filled in' (the cut is about the thickness of a piece of paper) which prevented the flame from moving to the opposite side of the burner - so essentially only one side of the burner lit.
Posted on May 24, 2010
  • 10,865 Answers
Here are two instances of when food "bakes poorly:"
  • When the item takes far too long to finish, you probably have a weak bake igniter. Often, you need to replace the igniter, but you may want to troubleshoot the oven's electrical system further to more precisely locate the defect.
  • When the temperature is consistent but too high or too low, the oven thermostat or sensor is either mis-calibrated or defective. If your oven uses an electronic temperature-regulating device, you may have an electric sensor in the oven instead of a mechanical thermostat. If the oven temperature is off by 30 to 40 degrees in this type of unit, you must replace the sensor.
    On many units with a mechanical thermostat, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Posted on Jun 25, 2009
Natural gas oven won't get hot and stay hot
Most likely the oven igniter has failed. Turn the unit to bake, the gas should come on within 35 to 60 seconds (at the most). If not, replace the bake igniter. DO NOT TOUCH THE BLACK PORTION OF THE IGNITER with your fingers, this is true for old and new.
Nov 19, 2012 | Magic Chef CGR3742 Gas Kitchen Range
My gas oven isn't heating up properly, is there
We were able to trouble-shoot our gas oven before calling the repair man. Our oven reached temperature but did not reheat when it cooled down. Our troubleshooting included taking out the storage drawer and looking at the underside of the oven near the valve.
First check if you can see the flame when the oven is on.
Use an oven thermometer in the oven to test if the oven gets to the desired temperature first. Does it get close to the desired temperature and stay near there for your entire bake time? If it does, you may need to adjust the thermostat setting. (This should be in your manual. Many Frigidaire manuals are available from their support site: http://www.frigidaire.com/Customer-Support/Videos--Manuals/ . )
Since our oven was reaching the set temperature and then not reheating, we had one person crawl under the oven and tap on the regulator when the oven needed to reheat. (We could see the ignitor spark.)
If the oven isn't heating at all, then the thermostat, the gas valve, controller or ignitor are suspects. Can you see the spark of the ignitor? Then it's probably not the issue. Similarly if you see the flame coming on several times during the bake cycle, it's not likely to be the valve. If you have a multimeter, you may be able to check the thermostat and controller for any breaks in the wire.
In our case, since the valve was failing, we ended up replacing the 10-year old range. (We looked at the price of a new range versus part and labor cost for the replacement. The part and labor was more than 50% of a new range.)
I hope this helps.
Apr 04, 2012 | Frigidaire Ovens
I have a gas Viking range. The oven burner ignitors light up and ignite the gas burners but quickly shut off - then go on again and off again- intermittently but frequently. This does not permit the...
Here is a test you can use to check the ignitors, Ignitor test. I also would like to you turn the thermostat knob slowly from the off position, When do you hear the click in the knob? You should hear it before the warm or lowest numbered setting on the knob. If you don't, replace the thermostat as it has failed. Need full model number to get you part.
Good Luck
Stay dry out there!!
Aug 28, 2011 | Microwave Ovens
One of the oven ignitors does not work
Most likely replacing the ignitor will fix it. I usually replace Viking ignitors with Maytag ones, part number 12400035 (you'll need splice wires and use included wire nuts to connect those, though). Those have a little shorter base, which does not affect anything. Replace both bake ignitors if you can, otherwise, one of the burners will ignite slower and shut off faster, resulting in uneven bake.
Jul 17, 2010 | Viking VGSC306-4B Gas Kitchen Range
The oven flame comes into the oven around the oven bake cover and all burners and broiler have a perfect flame. this is a brand new oven
Are you on natural gas or propane? If you are on propane did you have it converted form natural gas. Due to the difference in orface size you will be getting more gas flow then needed. If it was converted you need to contact the store and advise them it has a possible gas valve problem.
Jun 10, 2010 | Amana ARGS7650SS Gas Kitchen Range
Oven will not maintain temprature
This is a parts problem, I think called the burner ignitor. It is a pn oven part. We have had it in the past and are experiencing it again. We have had our stove for about 15 years, so I guess it is not too bad a problem, but not inexpensive. The oven is letting the gas be off too long between reignitions, so it does not maintain temperature. The first time we realized the probelem was with the Thanksgiving turkey (pink in the joints.)
We had to have the part replaced about 7 years ago and the part was about a $200 part plus service call. I am sure it more costly now. Hopefully you can get yours under warranty.
Dec 01, 2008 | Viking VGSC306-4B Gas Kitchen Range
Oven takes a loooong time to reach target temperature
sounds as if your bake igniter has gone bad, common issue witrh all gas ranges, part number 12400035 this will cure your problem, comes will everything youll need including instructions
Nov 24, 2008 | Maytag MGR5751AD Gas Kitchen Range
Viking VGSC306-4B Gas Kitchen Range Logo
811 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
