Question about Kenmore Washing Machines
90 series doesn't spin or wash ,motor is working .
  • 5,911 Answers
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria. Now...a washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price. Take note of your symptoms: 1. Washer fills, may or may not agitate, will not advance to the rinse cycle, and will NOT drain - lid switch. 2. Washer fills, does NOT agitate or spin, but WILL drain - motor coupling. If you still have questions, please let me know. I hope this infomration is helpful to you.
Posted on Jun 25, 2009
I have a Kemnore 90 series washer that wont spin the water pumped out, the motor spins but the agitator won't spin. My question would be is it worth fixing?
Hello, Thats sounds like a broken motor coulpler,when its broke it will sound as if its agaitating/spinning yet it doesn't. The coupler is fairly easy to replace and this video will show you to replace it. The part number fot the coupler is 285753A it could be picked up from your local appliance parts store for no more that $20.00 or you could order it online from; assuredparts.com apdepot.com appliancepartspros.com searspartsdirect.com repairclinic.com Gene
Aug 08, 2011 | Kenmore Washing Machines
My 90 series Kenmore washer spins but doesn't
The most likely problem is the drain pump.
Jun 26, 2011 | Kenmore Washing Machines
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore series 90 washer won't go into Spin
This is probably a bad drive coupler between the motor and the gearcase assembly.
Go here for:
Kenmore Washing Machine Parts
RepairClinic.com
appliance parts, help & more
Sep 20, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Series 90 washer. Will pump the water, does not spin
Replace the motor coupling between the motor and transmission its very easy if you tilt the machine back and remove the two screws holding the motor brackets.
Mar 28, 2009 | Washing Machines
Kenmore washer 90 series Washer will not spin
  • Check that the water supply valves are turned on
  • Inspect the filter screens
  • Test for overheating
  • Inspect the water pump
  • Test the water inlet valve.
  • Test the motor
Dec 11, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series washer will only spin with a couple of pieces of clothing in it, when I add more wet clothing it will not spin. If I take some cloths out it will then spin. When washer spins the water is...
Hi!
looks like you have a defective motor or a leaked load capacitor .....you need to get the motor rewired....or get a new motor for your washer..... have the capacitor checked....
but ya the issue is 1 of the 2....faulty cap/motor
Cheers!
Nov 12, 2008 | Kenmore 15864/15862 Top Load Washer
Intermittent spin cycle on Kenmore 90 Series washer
You may try the speed selection switch.....Ive had problems with these.
Jan 23, 2008 | Washing Machines
Washing Machines Logo
35 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
