Question about Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator
What di I DO ABOUT THE FROST BUILD UP ? - Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator
    Sergeant:
  • 163 Answers
If it's a frost free unit, then there is something wrong with the defrost cycle. Either a high limit temp switch is bad, the heating element, or the cycle timer. You can just unplug it for a time and defrost it manually like the old timers, but it's a little harder to do because the ice is inside the plastic lining of the interior of the refrigerator.
Posted on Jun 26, 2009
Why does my maytag mqf1656tew have ice build up on bottom shelf and where is the drain plug at. This is a frost free freezer
Frost Free means that it performs defrost cycles to keep the chiller plate or evaporator fins free of frost. Difficult to know where your frost is, but it can build up on anything this time of year. If your frost is on a part that provides the cooling, then it will need a service visit as the defrost timer is faulty.
Dec 11, 2016 | Maytag Refrigerators
Why haier freezer is beeping
Either way if you had the doors opened a lot, it should like you probably have frost build up preventing proper air flow. You'd need to pull everything out of the freezer and remove the lower back panel inside the freezer. If there is frost build up, you'll need to use a hair dryer to thaw all the frost out. The unit will continue to beep until the set temperature (0 and 38) are reached so that could take a while even after thawing out all the frost build up.
If removing panels sounds like more than you can handle, you can always unplug the unit for 24 hours and leave the doors open to allow the unit to defrost on it's own.
Oct 16, 2016 | Haier Freezers
How do you make a freezer frost free?
Frost free means that the evaporator coil will not accumulate a thick layer of frost. It will not prevent frost from accumulating on the walls of the freezer. To slow down the amount of frost build up inside the freezer, do not keep the freezer door open for any longer than necessary. The freezer door seal may be defective. This would allow moisture in that would freeze on the inside walls. A heater with timed intervals to come on is one way for a frost free feature. But this will not work for frost build up on the inside walls of the freezer. It would only melt the frost and then it would refreeze again.
Aug 31, 2015 | Frost Freezers
Frost build up Frigidaire FFHS2611LSO
Frost build up usually indicates an air leak - check your door seals and any part of the door for gaps. Also make sure the unit does not need to perform a defrost cycle.
Aug 19, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My coolers compressor has a frost build up on it and the temperature is at 50
start with checking the freon level. If too low, the txv will open and try to feed the evap. this can cause some overfeeding and give you some frost in some cases. It could also be a txv not feeding correctly. usually and overfeeding condition. causes frost build up on line and compressor and pressure in evap too high to remove the heat needed to properly cool. If a cap tube system, usually a sign of over charged or a real dirty condenser. In both cases, an evap fan, not properly working will cause a freeze up of the evap causing a high box temp and frost build up on the line and compressor.
Aug 14, 2010 | Nor-Lake KLF7766C Commercial Freezer
Runs constantly, freezer isn't cold enough, bottom of fridge is freezing
Do you have a heavy frost build up on the back wall of the freezer section toward the bottom. If you do your defrost heater has gone bad and will need to be changed. If you do not have frost build up the other problem would be with the evaporator fan or the main board. Let's hope for heavy frost build up.
Mar 09, 2010 | Hotpoint HSS25GFP Side by Side...
Side by side Admiral freezer that has frost
Check condensation drain line for a blockage.
May 13, 2009 | Admiral 26 cu. ft. Side-By-Side...
Frost build up in freezer/ very little cold air is blowing down to the bottom
HI thanks for your question. look to see if you can hear the fan motor running. if it is check for frost build up. if frost build up. its not going into the defrost cycle. thanks the appliance doc. please rate my answer. thanks.
Oct 08, 2008 | Kenmore 21.7 cu. ft. Top Mount...
Ice build-up
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
Hope this may help;
Regards,
VOTIT
Sep 22, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator Logo
190 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
