Question about Samsung HCJ552W 55" Rear Projection Television
Samsung HCJ552W Picture "expanded"
The picture on this tv has "expanded" and is cutting off about 1/2" on all sides. Does anyone know how to correct this?
  • jermz Jan 12, 2008
    picture starts off, about 2'' from the bottom and cuts off 2'' from the top
  • skamro Feb 09, 2008
    the picture has expanded 1/2 an inch all around How can i set it bk
    ? i have tried zoom but it did not work
  • 934 Answers
Change the aspect ration in the customer menu and take it out of zoom...
Posted on Nov 05, 2007
I have a samsung hcj552w rear projection tv. Every time the power goes out the tv will not turn back on unless I unplug it for a week or 2. When the power goes out then it comes back on just the red...
Replace the STK ICs,STK392-020 they are big black ICs and will have Part Number on them.Also CK the Low Ohm resistors in front of ICs. Mats Electronics has ICs 1-800-628-1118
Oct 29, 2010 | Samsung HCJ552W 55" Rear Projection...
Screen cuts off top of heads
Check the menu settings for the picture. You may be expanding the image to fill the sides, in the process, cutting the top and bottom.
Mar 10, 2010 | Samsung LN-S4051D 40 in. LCD Television
No digital reception with HD ready TV.
Someone did not explain to you what HDTV "Ready" means. It means you do not have a ATSC tuner in it to except over the air digital signal. The only way you will get digital reception is either from a HD Cable box with RGB outputs that plug into your RGB inputs, or being on Satellite connecting the same way. Seven years ago manufacturers never made it easy to understand and Salesmen only made it worse. So in short the term HDTV Ready meant it can, with a BOX.
Jun 13, 2009 | Samsung HCJ552W 55" Rear Projection...
Samsung HCJ552w CRT rear projection with a broken ASSY CRT-B.
not worth it, when you replace one, your saposed to replace all 3, otherwise the picture looks funny, probabily a 600 dollar repair
Jan 08, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
HCJ552W 55' samsung rear project....won't turn on
dear friend you have a power supply problem, get one of those cheap meters and open the set, look for a blown fuse, if they are ok wich i doubt, you have to call the repairman.
good luck
Oct 23, 2008 | Samsung HCJ552W 55" Rear Projection...
Samsung hlm507wx/xaa
Hi..your temp. sensor tells you when your lamp is too hot and could possible melt your engine. That is why your TV shuts down. It could be your lamp fan is not working or not working good enough to cool your lamp. You may need to replace it and very easy fix.
Mar 25, 2008 | Samsung HCJ552W 55" Rear Projection...
High def picture is cut off on the sides
I have a Toshiba 50HP15 PLasma flat screen TV. Its been working tone for 2 years now. All of a sudden without warningm the right 1/3 of tghe picture is missing and is black, where as the other 2/3rd of the picture is great picture and in HD. When I press DISPLAY on the remote control is says FULL 720p. When I press the Picture Size button on the remote the message NOT AVAILABLE come on. Anyone with suggestions. Thanks
Dec 27, 2007 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Picture has shifted to the left
This is a known problem. Panasonic sells a jig to correct it. I had the same problem and bought the jig for about $25. It plugs into a special port in the back of the tv behind a little door. You can read all about it here:
Aug 15, 2007 | Panasonic TH-42PD25U/P 42 in. Plasma EDTV
Samsung HCJ552W convergence out before warmup
If set has a few years on it, the convergence may be going out.
Jul 16, 2007 | Samsung HCJ552W 55" Rear Projection...
Samsung HCJ552W 55" Rear Projection Television Logo
Jerry Greenberg
Jerry Greenberg
