Question about Samsung HLM507W 50" Rear Projection HDTV
TV shuts off after 30 seconds.
I replaced the buld three months ago and the TV worked great, until the TV started to shut itself off ~30 seconds 'after' the screen lights up. The indicator lights suggest that the lamp has a fault or is burned out. The lamp has not burned out, so can you suggest what is the problem?
    Champion:
  • 205 Answers
Check chassis venting, sounds like thermal switch is tripping on top of light box.
Posted on Jun 28, 2009
TV shuts itself off after a couple minutes of being on.
One must be very careful of the quality of the replacement lamp. Many of the cheap 'deals' on the web for replacement lamps are substandard. I always recommend that replacement bulbs be the original manufacturers bulb.
Apr 30, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
I have a Hitachi PJTX100.....been using it for a year and a half and it has been flawless.....until recently....After about 30 minutes of use it shuts off....meaning the screen goes black and the actual...
i believe your problem is heat the bulb is getting hot and the air or fan is not working properly so when it hits temp it automatically shuts off check your fan air flow filters etc
Jan 10, 2009 | Hitachi PJTX100 Multimedia Projector
Sony WEGA Large Projection TV
I sounds like the projection bulb has failed. I think there is a red lamp on the front that lights up when the bulb fails however.
This sounds very similiar to what mine did when the bulb failed about 2 months ago. Once the buld fails the TV will shut itself down and keep doing that until the bulb is replaced.
Dec 17, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
TV picture fades, then shuts off
There are some components in the scan amplifiers, and or the power supply area that have become unstable. This can happen with age and use. It is impossible to make an accurate assessment without actually troubleshooting the set.
You need an experienced TV service tech that is strong on troubleshooting, has the service manuals, and has the proper set-up to work on your set. I would recommend the factory service rather than an independent service tech unless you know for sure that the independent service tech can handle this type of repair.
Considering the age of the model of set that you have, I would be looking at replacing it rather than fixing it. Because of the age of the set the reliability will be decreased.
Jerry G.
Jun 10, 2008 | Samsung TXF2899 28" TV
Toshiba 40H80 - Turns on . . . wigs out for about 30-seconds . . . shuts off.
A convergence problem is very commond. In most cases the convergence output amplifer IC's need to be replaced. This is not something you should do. Call a repair shop.
Apr 15, 2008 | Toshiba 40H80 40" Rear Projection...
TV Shuts off, Screen Problems
The problem could be the power supply, the flyback trasformer or simply a bad connection. A repair cost for this TV set could run any where from 75 bucks all the way up to 225 or so, depending on the problem. Good Luck
Apr 29, 2007 | Sony KV-32S40 32" TV
Open Questions:
Samsung HLM507W will not turn on Alright so here's the deal....I got this TV for free from a guy on craigslist. He said he couldnt get it to turn on. He replaced the lamp, it still didn't work, so he gave up and now I have it. First thing I did was try and turn it on... The TV powered up for about 5 seconds, and then the screen started to flicker all kinds of crazy colors, and it shutdown shortly after with all 3 lights blinking. I figured this probably has to do with the color wheel, so I bought a new one and popped it in. Once installed, the TV started right up, and worked for the entire duration of it being on (approx 7 hours). Now it will not turn on. Here's the startup sequence: -Push power -A couple of audible clicks, and both cooling fans energize. -Lamp does not turn on, and after about 45 seconds of having just the fans running, the TV cycles off and tries to power itself back on. -Rinse and repeat about 3 times total. -After the 3rd attempt, the TV shuts down completely and all 3 lights start blinking in front. -Pushing power does not do anything with the 3 lights blinking. TV must be unplugged and pplugged back in before sequence can be attempted again. Looking for a possible solution/troubleshoot technique. Checked the fuses and they are fine, triple checked all of the connections. Seeing as the lamp doesnt even attempt to energize, Im thinking it could be the ballast, but I'm trying not to dump money into something that might not fix the problem. Thanks for your help!
Jan 21, 2013 | Samsung HLM507W 50" Rear Projection HDTV
Samsung HLM507W 50" Rear Projection HDTV Logo
312 people viewed this question
Jerry Greenberg
Jerry Greenberg
