My Hoover Steam/Vac doesn't release any clean water when you pull the trigger. It will only release...
(More)
My Hoover Steam/Vac doesn't release any clean water when you pull the trigger. It will only release clean water to the upholstery attachment when that attachment is on. How do I get the steam/vac to release clean water to shampoo the carpet?
My mod4el 5881-900 leaks on or off. I checked the valve assembly. The rear button turns the flow on...
(More)
My mod4el 5881-900 leaks on or off. I checked the valve assembly. The rear button turns the flow on or off and the control rod lines up. The valve under the tank allows a steady flow to the pump. What should I check further? Mike Pirro mspirro@yahoo.com
