Question about Dometic RM2652 Refrigerator
Just had a new Dometic 2652 refrigerator installed today. Pulled in home and now the whole trailer blows the circuit breakers in the house. We ran in a week (a/c,micro, radio) before we had the new refrigerator installed. Now we can't run anything! Did they wire something wrong
    Sergeant:
    Champion:
  • 253 Answers
Hi
may be ur wires are short circuited so call ur dealer
Posted on Jun 25, 2009
Just bought a 5th wheeler and it had abrand new dometic fridge everything worked greatafter 10 min the fridge blew out some saiid it was thr conrtol board so I bought one at a tune of 129.00 installed ir and still no fridge a friend check all the basics for me before and after and still no cold in the cold box or anywhere else for that matter PLEASE any advice
Posted on Jun 14, 2012
  • Ron J fox Jun 14, 2012
    not running a cord it is (thecamper) to the park pedestal
    Problem Solver:
  • 6 Answers
Are you running an extesion cord? The outlet you are plugging into should be at least 30 amps. Try shutting everthing down and just plugging the trailer in...
Posted on Jul 01, 2009
The trailer did not have a air conditioner in it before the trailer place installed the new dometic air conditioner. The trailer year is a 1976 AMF Skamp. I told the trailer place that I wanted a 15000 btu...
You have too small a cord on it if it's heating up and then popping your breaker. The a/c has am amp rating on it's data tag, read it and then read the amp capacity of your breaker and the cord your using. If the a/c draws more than 80% of the rated amps for the cord and breaker then you need to find another way to power it up with a bigger cord and a bigger outlet. DO NOT just install a bigger breaker, it is sized for the wiring in your home and a bigger amp draw on that wiring could burn your house down.
Jun 17, 2011 | Dometic Rooftop RV Air Conditioner
Dometic RM 2652 Refrigerator/Freezer is not working. Light works, 110 and propane are fine. Are there steps in trouble-shooting problems with this refrigerator? No visible leak or obvious problem. It's in...
Dometic refrigerator lp gas electronic Model # 3662. Same problem. gas works fine and power is there. as lights on top of frig work.... not even trying to be cold. Same suggestions as 2652? How to bypass thermostat? and will try relay after... thanks.. Bob in Canada<input id="gwProxy" type="hidden" /><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden" /><!-- from fixya rte -->
Aug 02, 2010 | Dometic RM2652 Refrigerator
Own 2005 27.5' Wildwood Trailer with a Dometic a/c ducted unit. Last few times out it freezes up initially first few times (pocked circuit breaker once then I turned it off after few minutes second time)....
Don't block off any ceiling ducts and see what happens. If you've closed off any forced air ducts, the unit will freeze up, if too many are closed off. Also, if you shut unit off (compressor) give it 5 or 10 minutes before you turn it back on.
May 21, 2010 | Dometic Rooftop RV Air Conditioner
Dometic refrigerator RM 2652 is not working
The fridge needs a 12 volt DC source to operate properly, which should be connected at the back of the fridge, outside behind cover. Check all fuses in your fuse panel as well. The upper controls are powered by 12 volt DC system, and that's what tells the fridge what to do.. (battery or converter)
May 08, 2010 | Dometic RM2852 Refrigerator
Circuit breaker trips when turning unit on. only unit on circuit has triped on several circuits can find no shorts on wiring.
DOES IT BLOW THE BRAKER AS SOON AS IT TURNS ON OR DOES IT TAKE A FEW SECONDS. INSTANTLY WOULD MORE LIKELY BE A SHORT IF FEW SECONDS THE COMPRESSOR IS PROBABLY DRAWING MORE AMPS THAN THE BREAKER CAN HANDLE SO IT BLOWS. TRY TAPPING THE COMPRESSOR NEXT TIME YOU ATTEMPT A HOUSE CURRENT START UP. i HAVE A WINDOW AIR CONDITIONER THAT NEEDS TAPPED FOR STARTUP FOR THE SUMMER SEASON. GOOD LUCK
May 01, 2009 | Dometic RM2852 Refrigerator
Dometic R/M 2652 stopped working...burning smell and smoke
First of all any signs of burning on a circuit board means that a component has burnout in which case replacement will be required. Secondly depending on the colour of the stain , if its a dark colour the systems heaters are cooked in which case the cork insulation has melted the tare off and thats what you see on the floor. if its clear and oil based , the container has rusted and formed a leak ,in any of these scenarios its time to get a new one
Apr 27, 2009 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Problem
Check the flu at the back is clean
Oct 12, 2008 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
286 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
