Question about Panasonic PT-52LCX65 44" HDTV
How to unlock code for PT-52LCX66 panasonic - Panasonic PT-52LCX65 44" HDTV
SOURCE:
SOURCE: reset lamp counter on PT-52LCX66/PT
i aswell dont have PIP on remote but i found another way to fix....
hold the volume button ON TV - down and the 0 zero button on remote at same time :) just worked for me...
Posted on Jul 29, 2009
MNfisherman
  • 11896 Answers
SOURCE: my panasonic pt-52lcx66 it wont turn on what can i do myself
yes they do; They have glass fuses than have the thin wire running across on the inside. If the wire isn't running all the way across the fuse or is broken, then it is junk. If fuses is good, then power supply may be faulty which is quite common these days with newer electronics
Posted on Aug 27, 2009
johnnydiode
  • 647 Answers
SOURCE: The lamp hour meter needs to be reset for
This works for most Panasonics
Turn on Power
Pres and hold the "vol-" button on the front of unit and the "split" key on the remote together for over 5sec.
Screen should say " Lamp time was reset to 0"
Posted on Nov 12, 2009
tvtek
  • 1284 Answers
SOURCE: where do i locate lamp in my panasonic pt 52lcx66
The left speaker grill comes off then the lamp door will be behind there. Mind you if the lamp in your TV still works and you are changing it. Make sure that you let the TV cool down for a minimum of an hour before handling the old lamp. Also your lamp part number is TY-LA1001. Please take a moment to rate my answer. Thanks...
Posted on Nov 24, 2009
Testimonial: "Rite on thanx"
pabloloco
  • 2335 Answers
SOURCE: changed bulb on panasonic PT-52LCX66-k and cant reset timer.
I can help you reset the lamp timer for your Panasonic PT-52LCX66 Projection HDTV.
The buttons used are the TV's volume down and the remote's number 0.
Follow the steps in my Fixya Tip for the complete lamp timer reset procedure.
I hope that helps.
Posted on Apr 11, 2010
How do I replace the lamp and housing unit on my panasonic PT-52LCX66
You need a TY-LA1001 lamp assembly. Our Panasonic TV Lamp and Bulb Installation Guide shows how to change the lamp and has links to Panasonic Users Manuals.
[email protected]
Feb 11, 2011 | Panasonic PT-52LCX66 Projection Television
Tip
Panasonic PT-52LCX66 Lamp Timer Reset Models No. PT-52LCX66 / PT-56LCX66 /...
Models No. PT-52LCX66 / PT-56LCX66 / PT-61LCX66
Models No. PT-52LCX16 / PT-56LCX16 / PT-61LCX16
Here are the steps to reset the Lamp Timer for your Panasonic Multimedia Projection HDTV:
  1. Plug your Television in.
  2. Press the POWER button on the TV or the remote control.
  3. Press and hold the VOL- button on the TV, while holding the 0 button on the remote control for at least 5 seconds.
  4. When the reset procedure is complete, a confirmation screen will appear.
  5. Release the buttons and the LAMP indicator will go out.
Download the TYLA1001 Replacement Lamp Installation instruction guide here.
I hope that helps.
on Apr 11, 2010 | Panasonic PT-52LCX66 Projection Television
Tip
Panasonic PT-52LCX66 Manual Models No. PT-52LCX66 / PT-56LCX66 / PT-61LCX66...
Have you lost the Operating Instructions for your Panasonic PT-52LCX66 Projection HDTV?
Click here to download a digital, searchable copy of your users manual / owners guide.
I hope that helps.
How do I reset a lamp counter on a PT-52LCX66/PT TV?
I hope that helps.
Feb 20, 2010 | Panasonic PT-52LCX66 Projection Television
I NEED TO RESET LAMP TIMER PANASONIC PT52LCX66.
I can help you reset the lamp timer for your Panasonic PT-52LCX66 Projection HDTV. Follow these steps in my Fixya Tip for the complete lamp timer reset procedure.
I hope that helps.
Jan 27, 2010 | Panasonic PT-52LCX66 Projection Television
The lamp hour meter needs to be reset for Panasonic PT-52LCX66 Television. How do i reset it?
Turn on Power
Nov 12, 2009 | Panasonic PT-52LCX66 Projection Television
Need to reset the lamp time on my PT-52LCX66
To reset lamp timer in Panasonic PT-52LCX66..
Press and hold Volume Down button on TV front and press and hold 0 (zero) button on TV remote at same time for 6 seconds, a lamp reset message will appear on TV screen.
Thanks.
Sep 02, 2009 | Panasonic PT-52LCX66 Projection Television
How to change the bulb in my panasonic 52 inch model # pt-52lcx66 tv
I can help you change your bulb and reset the lamp timer for your Panasonic PT-52LCX66 Projection HDTV.
  1. Installation instructions for the TYLA1001 bulb are here.
  2. Follow the steps in my Fixya Tip for the complete lamp timer reset procedure.
I hope that helps.
Aug 22, 2009 | Panasonic PT-52LCX66 Projection Television
Changed bulb on panasonic PT-52LCX66-k and cant reset timer.
I hope that helps.
Apr 11, 2009 | Panasonic PT-52LCX66 Projection Television
Need bulb
Post your model number and I will post a link where you can get one at.
Apr 26, 2008 | Televison & Video
Panasonic PT-52LCX65 44" HDTV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
