Question about Tomtom GO 510 GPS Receiver
Tom tom go 510
Can not charge green light on but no screen? worked yesterday for 10 mins thought i needed to charge, but no screen after 2 hours charge still no screen
  • wallyway Nov 05, 2007
    Same problem, even plugged into external power, no screen. Tried taking out SD card and reinstalling, still nothing. Tried holding power button down for awhile and releasing, still nothing. Any suggestions? Is there a reset button I don't know about?
There is a reset button (hole) underneath by the plug-in bar. It is real small, you'll need a small paper clip straighten out
Posted on Aug 05, 2008
No screen Display !
the go 710 has a reset under the mount (see picture below) charge it up for a few hours, then get yourself a small paperclip and depress the rest for 15- 20 seconds.if it doesnt power up, press and hold the power button for up to 10 seconds.
if you need more help, just post back.
bill
Jul 08, 2010 | Tomtom GO 710 Car GPS Receiver
MY TOMTOM GPS NEED TO BE TO RESET
I will advice you reset the unit, this might help fix the abnormality with the white screen problem. follow these procedure to reset your tom tom gps.
Make sure your battery is charged before you begin. TomTom suggested allowing your device to charge for at least 2 hours before resetting it. Remove your device's SD card from the card slot.
Find the "Reset" pinhole button on the bottom of the device.
Hold the "Reset" button down for 10 to 15 seconds or until your device resets itself. You will need a flattened paperclip or another small metal object to reach inside the pinhole.
Power the TomTom back on and insert your SD Card. You have now reset your TomTom gps and this should fix the white screen problem.
Take care.
Jun 28, 2010 | Tomtom GO 510 GPS Receiver
My Tom Tom 510 will not turn on at all. I plug in the power supply and the green light comes on. I used it yesterday and this morning, and all was fine, tried using it 1 hour ago to travel home and...
try to reset
The Reset hole is hard to find, you need to first remove it from the mount, turn it upside down, and within the mounting base area of GO you will see two interface slots (currently only one is being used) and towards the front of the unit on the base you will see a little hole marked reset. This is just like soft resetting a Palm or Pocket PC, it requires something small like a paperclip, and nothing was supplied with GO to enable you to easily reset the device.
Nov 15, 2009 | Tomtom GO 510 GPS Receiver
Tom tom 1 will not switch on
Charge it through the computer using your USB cable for a good 2 hours and try switching it on again. It happened to me and it seemed to work fine after that.
Dec 13, 2008 | Tomtom GO 910 GPS Receiver
Charging the Tom Tom - unit shuts off with car charger plugged in
your rechargeable battery inside has a limited life and has to be replaced when this problem happens.
May 28, 2008 | Tomtom GO 510 GPS Receiver
TomTom go 510
COMMON PROBLEM SO FAR WITH THESE. IF STILL UNDER WARRENTY CALL TOM TOM THEY WILL REPLACE THE BATTERY UNDER WARRENTY
Feb 20, 2008 | Tomtom GO 910
GPS Won't Turn On
www.batteryship.com
look up tomtom 510 - or whatever model you have
Order the battery..........comes with manual and tools to fix it
only 20.95
it works
cheaper than sending it in!!!!!!
These are genuine replacement parts!!
Laura
Jan 30, 2008 | Tomtom GO 510 GPS Receiver
MY TOM TOM WILL NOT TURN ON. THE GREEN LIGHT IS ON, AND IT'S CHARGED. WHERE CAN I GO TO HAVE A PROFESSIONAL, REPAIR IT FOR ME RIGHT AWAY? I'M GOING ON A TRIP IN 2 DAYS. THANK YOU. VINCENTCOGNATO@AOL.COM
I solved this problem by finding an answer on the Tom Tom website. Using a paper clip end insert it on the reset button and press for at least 10 seconds. The reset button is difficult to find; it's located close to the connector at the base of the unit. It is an annoying problem as it happens without any rhyme or reason. I now carry a paper clip in the car!
Dec 19, 2007 | Tomtom GO 700 GPS Receiver
TOMTOM 510 not reading SD card
I did find out how to solve the problem. I can't remember exactly where I found the solution but I think it was on TOMTOM website. You have to connect to TOMTOM home and reinstall the application. I put the TOMTOM disc in the computer (which came with purchase) and reinstalled the program. Which I thought was weird as everything appeard to be fine with TOMTOM home). Anyway, it worked. Good luck.
Sep 30, 2007 | Tomtom GO 510 GPS Receiver
GPS Logo
60 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
