Question about Toshiba Portege R100 Notebook
The hard drive light does not come on and the computer won't boot up
  • James May 11, 2010
    Hello Is the power adapter working? Do you have a spare you can test this with? remove the battery from the laptop and reconnect-leave on charge for 2 to 3 hours and then try again. Do any lights flash or eliminate when you press the power button? // J
    Problem Solver:
  • 11 Answers
There could be three things with that, first of has you, a family member or friend been playing around with the bios, because they might of changed a setting for the laptop to boot off a CD not the hard drive, that,s worth checking.....or the hard drive has simply failed. or even the pins that read the hard drive have been bent or broken
Posted on Jun 26, 2009
Ntldr missing computer won,t start
Check or replace data cables to hard drive
Check in bios that drive select is set to auto.
Boot to windows dvd and repair windows start up.
Jan 22, 2014 | Abit KW7 Motherboard
My dell computer says PXE-E53, on RealTek PCIe FE Family Controller Seriies V1.19: No boot filename received and then says no operating system found
First go to bios by press f10 (or kay for your model of laptop )and
select main menu and check display cd dvd drive and hard drive in information.
select cd dvd or hard drive to first boot .set network as lower than hard drive.dell-bios-uefi.jpg
in this pic netework is high piority for boot up. but there are no network server to boot up. there was showed as no network device, pls select hard drive and select key for change setting.
Oct 29, 2017 | Dell Inspiron 1200 Notebook
Gateway mp8708 s/n t23691006485 showing disk error won't boot just shows disk error help me
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.
Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 20, 2012 | Gateway Computers & Internet
Toshiba 350b satallite laptop won,t boot up have power but no hard drive activity
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Mar 04, 2012 | Toshiba Satellite A135-S2386 Notebook
The laptop won't boot
probably the hard drive in your laptop is gone.
try booting ubuntu in live mode, so without installing it.
when the boot is completed, launch the tool gparted and see if it detects the hard drive: if it doesn't, you need to change the hard disk..
Jul 30, 2017 | Toshiba Satellite C655D-S5044 15.6" 2GB...
Dell Inspiron 600m: No Boot Device. I'm a computer
Have you tried resetting the BIOS defaults? In doing so, it will force IDE re-detection and often resolve vague boot issues.
Sep 11, 2011 | Dell Inspiron 600M Notebook
Hp dv5020us won't boot. upon power up I get some brief hard drive activity and fan noise. No blinking LED error codes. Caps and/or Num lock LED's do not light. Power LED will glow and HD...
step one, big battery out? skipped that?
step 2, a good power pack , that means 19vdc on those 2 pins.
bingo BIOS screen now work ,yes?
step 3, try an external VGA screen at the P15 VGA jack there
screens work now (BIOS first) yes/no?
remove DVD, drive
and all USB devices
there booting with only 1 memory stick. (got more?, try each 1 by 1)
black screens of *****'.
the lack of flash codes, Implies Power pack is dead. or CPU overheated, and selfshuts down. that fan going dead tells
me the power park is dead.
http://pcdied.com/#black-screens
May 01, 2017 | HP Pavilion dv5020us Notebook
Won't boot from dvd or hard drive, changed hard drives and still won't boot
Depends on what you mean by won't boot from DVD or Hard Drive,
it sounds like your boot order is what you're looking for help for.
To do this you need to get into your computers BIOS (or "Setup")
You can do this by rebooting the computer and the very very very first screen you see tells you how,
usually by pressing DEL or F2 or F10.
Without knowing the specific computer you're looking for help on I can only point you in the right direction however keep in mind the BIOS is for advanced users only and you can damage your computer by randomly changing settings.
What you're looking for though is usually called the Boot Order or Boot Sequence
You'll need to set whatever device you want to boot from higher on the list (usually with the up arrow or PgUp)
If you don't see your device on the boot list then it may not be detected due to failure.
May 31, 2011 | Computers & Internet
My desktop has an orange light no beep sounds when starting it won't boot up the back where ethernet plug goes is orange too the fan makes a burning smell also
Orange light usually means the harddrive or computer is processing and loading, But it can also mean that there is a problem with the hard drive. Start your computer and wait. If you see orange light it means its working to boot up, it might take a while, you might see your screen black for a while but eventually will work.
To fix this problem you need to upgrade more hard drive space, RAM memory and processor speed
Nowadays a computer should have a minimum of 2GB of RAM memory, at least 120GB of Space, and about 2.0Ghz of processing speed.
You can also buy great refurbished computers which are cheaper. Most of them come with 4GB of RAM memory, 250GB HD Space and 2.5Ghz processing speed.
May 24, 2011 | Dell Computers & Internet
Wont boot or make noise but lights are on
remove it from the case and put it straight into your computer using a spare power plug and cable. to see if you are doing it right check one of the other hard drives in the tower switch on and see if there is any diffrents if not then i am sorry to tell you it is caput
May 26, 2009 | Beyond Micro (BM120MD3U2) 120 GB USB 2.0...
Toshiba Portege R100 Notebook Logo
481 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
