Question about Whirlpool Calypso GVW9959K Top Load Washer
An abbreviation 'sf' appears on the washing machine everytime i run a laundry, and couldnt continue, what does sf mean or stands for?
  • 478 Answers
On certan models the "sf" stands for service filter
Posted on Jun 26, 2009
What does the abbreviation fm mean in a crochet pattern
fm is a dutch term used in crochet patterns meaning fastmaske
for US pattern means single crochet
for English pattern means double crochet
www,yarnover.net is the site for crochet abbreviations and it appears from other sites, that different countries have different meanings for crochet abbreviations
go google and type in--- meaning of fm in crochet abbreviations-- and there are many informative sites that will help you
Sep 24, 2016 | Sewing Machines
What does the abbreviation SKTPO in knitting stands for?
The abbreviation explanations should be included in your pattern instructions. Pattern designers sometimes use different abbreviations so it is best to refer to the included instructions.
This may help:
Patterns Posh Yarn Luxury hand dyed yarns from the UK
Apr 15, 2016 | Sewing Machines
Why is there an 'SF' code showing and continuous beeping from our Simpson encore 756
there are different sf codes for different faults. try googling the sf number fault to find problem.
May 25, 2014 | Washing Machines
Hitachi washing machine model SF-150GJX showing error F9. Any one knows what this means?
My washing machine hitachi SF-110LJS showing F9 ERROR
PLEASE HELP URGENT
Sep 07, 2012 | LG Washing Machines
SIMPSON 816 ENCORE WASHING MACHINE ERROR MESSAGE
Hello
Try running the washer through rinse/spin cycle,then normal cycle without any detergent.
SF is suds failure,or too much detergent or wrong type of detergent.You need to use H E type detergent.
This should clear the machine out.
Apr 01, 2011 | Electrolux Washing Machines
If you get the FL how do you get the door to open??
  1. Your Maytag Neptune washing machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
  2. Do
  3. Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
  4. FL
  5. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
  6. Sd
  7. The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
  8. PF
  9. The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
  10. Nd
  11. The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
  12. LO
  13. The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
  14. Lr
  15. The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional.
Dec 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
223 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
