Question about Runco CW-50mc 50 in. HDTV-Ready Plasma Television
Runco CW50MC problem with inputs.
I have a Runco CW50MC that I am having troubles with. When I hook up my HD cable box to the component input the picture just rolls and flickers and does not sync. This seems like a problem with the input. When I use a HDMI to DVI cable with the cable box, it works fine. When using the same cable (HDMI to DVI) my Playstation 3 does not work on same input. Any clue what the problem is? Do I need a scaler? Any suggestions would be appreciated
3 Suggested Answers
  • 14 Answers
SOURCE: on a runco cw50mc where
It doesn't. This is a "monitor". The best input for sat or cable TV is via the component (red, green blue) input or possible the DVI.
Posted on Feb 28, 2011
SOURCE: I have an DVI to HDMI cable running to my
Did you ever find a solution to this problem? I have the same model TV and I cannot get anything to display from a DVI video source. Anything "pure" HDMI like a DVD player, XBOX 360, or media streamer, work fine. I now have a PC connected to the TV. The PC has an HDMI port and works fine on 2 LCD TVs I have at home but not this one. I'm starting to think it's a wierd HDCP thing.
Posted on Sep 10, 2010
On a runco cw50mc where does the satellite cable hook up on the back?
Dec 01, 2010 | Runco CW-50mc 50 in. HDTV-Ready Plasma...
Runco DTV-5800-component to BNC connection problem
component cables have standard RCA fitting on the end. you can however but adapters enc to RCA. these work well are are readily available through eBay
May 04, 2010 | Runco DTV-5800 58 in. Rear Projection...
How do I connect to Sharp HDTV and Comcast cable
Your dvd recorder only has rca, red white yellow inputs it wont allow you to record in HD, although you can play your comcast box any hd, regular digital through and record. Hook up the comcast box if HD through preferably HDMI if not get one from comcast. The HD box is the only box that allow HDMI, component and regular RCA and some RF out. This way you can play HD to your set but also record through RCA or RF again will not allow for HD record unless its TiVo. Hope this helps
Jan 07, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
I just purchased a Sherwood RD 6513 reciever, I'm trying to connect a hd cable box (motorola dch 3200), dvd player (sony dvp ns710h) and a rca hd tv (l32hd41). I connected hdmi cords from both components...
Hi! I will be more than glad to assist you. I f you are going to hook up your cable box - motorola to the sherwood receiver, connect an hdmi cable to the back of the motorola cable box, there is only 1 hdmi output there, then connect the other end to the sherwood receiver on the hdmi input, then connect another hdmi cable to the hdmi output and the other end goes to your rca hd tv.
for the sony dvp, you have only one hdmi out, connect an hdmi cable to the back of the sony dvp if u have another spare. connect it to the hdmi input of the sherwood receiver. there is only 1 hdmi output at the sherwood, so u need to use a component cable to be connected at the back of the sherwood receiver component output then the other end goes to the component input of the hd tv.
if you dont have anymore hdmi cable to hook up your sony dvp, u can use component cable, the connection will goes like this, connect a component cable on the output of the sony dvp and the other end goes to the sherwood component input then connect another component cable to the component output of the sherwood and the other end goes to the rca hd tv on the component input.
I hope this will solve your concern, if you have any question, u can get in touch..
Aug 21, 2009 | Televison & Video
Input 6 - HD Input - Green Screen. Audio Only. No picture.
I am having a similar problem with the inputs. I have a cable box plugged in to cable antenna, DVD to video 6 using HDMI, Mac computer plugged in to video 7 - using HDMI (TV does not recognize this) and then Nintendo Wii hooked up to Video 1. My problem is that Sony only realizes 2 additional components like the video 1 (wii) and DVD on video 6, it does not play the other components. I have to niw manually switch the cables to have them work...
Aug 04, 2009 | Sony KDS-R50XBR1 50" HDTV
Samsung hlp4667 only get a picture with HD input.
is there anything else hooked up to your tv other than cable or satellite? if no other components (dvd, vhs, etc) then you will get a snowy screen because the other inputs are for other components that are hooked up. a picture is showing on the HD input because you have cables hooked into that input.
Mar 15, 2009 | Samsung Televison & Video
I'm simply looking for the most efficient way to hook up my HD-TV with HDMI inputs to both my cable box (with HDMI inputs) and my DVD player/recorder so that I can record from the TV I watch.  ...
The way you have it hooked up right now will not work unless you have a coaxial out on your cable box going to the dvd recorder. Even then, picture quality will be severely degraded. The best way to do it is to leave your cable box hooked up to your TV via HDMI and connect your dvd recorder to your cable box via component video if your dvd recorder has a component video input. If it doesn't, then just use the composite video input. That way your picture quality will be better and you will still be able to record with the TV off.
Jan 02, 2009 | Insignia 37" LCD Flat-Panel HDTV
How to get a high definition Picture??
Hi, first of all you need a high definition source. I'm not sure if your cable box is HD but lets take it as an example. The component leads which you are using isn't 'true' HD video quality, what you need is a hdmi cable from your source to your TV.
Your cable box maybe HD with a HDMI output, if it is then you need the lead to come out of the cable box into your tv's HDMI input using a HDMI lead. Then you switch your TV's source to the HDMI input and it then should be producing a HD quality picture, but to truly get the full HD experience you may want to subscripe to a HD channel or purchase a blueray player becasue most cable TV channels are upscaled to HD and the definition is not as good as on a blue ray disc or a true HD channel.
So in conclusion the cable and input you are using is not designed for HD input. I believe your TV is HD, check for HDMI inputs or DVI inputs.
Hope this explains your problem
Nov 28, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Colors out of Whack on HD input 4 only
May need higher quality component HD cables? Tried switching Blue on Red? Just some thoughts.
May 02, 2007 | Philips 60PP9202 60" Rear Projection...
Runco CW-50mc 50 in. HDTV-Ready Plasma Television Logo
250 people viewed this question
Top Runco Televison & Video Experts
Carlos Oliveira
Tom Chichester
Are you a Runco Televison and Video Expert? Answer questions, earn points and help others
