Question about HP Officejet J5780 All-In-One InkJet Printer
Any stack height of paper won't feed through - HP Officejet J5780 All-In-One InkJet Printer
    President:
  • HP Master
  • 1,996 Answers
Here is the HP support page that has instructions for this error. Also applicable may be this article, and here's your home support page.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jun 25, 2009
  • 17 Answers
SOURCE: Feed problem
You need to install a paper jam kit. These models are notorious for having feed problems due to the paper stack standing up. I get my parts from a company called "Parts Now!" and you can get this kit from them. The part number is KIT-FEED-1100-PNO. It requires some disassembly of the printer. HP used to provide a free "defect kit" which was very simple to install, but I cannot find a reference to it anymore. Hope this helps!
Posted on Apr 30, 2007
SOURCE: paper will not feed
My OfficeJet Pro K550 makes sounds like it is getting ready to pick-up the Paper but sounds stops and Printer goes back into the ready mode without printing.
Will you please give me some pointers????
Posted on Apr 08, 2008
  • 240 Answers
SOURCE: Entire paper stack jammed at feed chute entrance.
check at the rear part of your printer there a backdoor latch there..
open it..and you can get the jammed paper easily..
if there is a pieces of paper left..you can get it by force..
rid the paper into pieces and clean the rollers of your printer..
and restart you printer..
hope it helps..
Posted on May 24, 2009
SOURCE: My Lexmark X75 comes on and seems ready for
Gave up on you folks because I do not use credit cards and that seems to be required before I'm allowed to ask for assistance.
Thank you, anyway.
gramalee
Posted on Jan 23, 2010
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: Lexmark X85 won't feed paper. When trying to
    There could be something in the paper feeder that's blocking the paper path. Please follow steps below to identify and fix the problem:
    1. Remove the sheets of paper from the feeder.
    2. Grab a flashlight and look inside for any debris.
    3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
    4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
    5. Check the cartridge area for any obstructions/debris that could cause this error or problem.
    6. If cartridge area is clear, close the cover.
    7. Unplug and re-plug the printer into the power outlet to reset it.
    8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
    ns Serif"'>6. When the printer turns on, reinsert one cartridge first.
    7. Close the printer cover and check for any errors.
    8. If no error appears, reinsert the other cartridge. Close the printer cover.
    9. Replace whichever cartridge is causing the error to appear with a new cartridge.
    Posted on Aug 03, 2011
    First paper feed wheel at paper stack bin somt times will not feed paper into machine. The feed wheel hanges at a angle when the paper stack is down.
    Could be wear in the wheel. But you will find more answers at a Fixya category that more closely matches your product type. Experts here are for Cars and Trucks in this section.
    Sep 19, 2013 | Toshiba DP2570 Printer
    Tip
    Minimizing Paper Jamming in any printer
    When using any laser printer, monochrome or color machine, be sure to fan the paper before inserting into the paper cassette tray. The technique is simple. Holding a stack of paper in your hands, each hand on the short edge, flex the paper to create an arc in the stack. Then pinch down on the ends of the paper and straighten the arc out. You'll produce a bulge in the middle of the stack which creates an air space between every sheet in the stack. Now the paper will not cling and paper jams will not occur.
    The 2nd tip is to note which "direction" the paper is cut because feeding the paper in one side first may provide better traction than if you were to feed the other end in first. Paper has a grain and its lays down in one or the other direction.
    on Apr 04, 2010 | Office Equipment & Supplies
    Lexmark t614 manual feed how it works
    1. Push the lower release latch. The multipurpose feeder door drops open.
    2. Pull out the metal bar in the recessed area on the multipurpose feeder, far enough to accommodate the paper you will be using.
    3. Slide the paper width guide to the far right.
    4. Prepare the print material for loading:
        • Flex paper or fan envelopes back and forth. Do not fold or crease the paper. Straighten the edges on a level surface.
        • Hold transparencies by the edges and avoid touching the print side.
        • Fan the stack of transparencies to prevent jams.
        • Be careful not to scratch or leave fingerprints on the transparencies.
    5. Use the stack height limiter as a guide for stack height when loading print materials.
    6. Load one type of print material in the multipurpose feeder. Do not mix types.
    7. Slide the paper width guide over until it fits snugly against the side of the print material.
    If you need further assistance please contact Lexmark Technical Support.
    Aug 24, 2011 | Lexmark Optra T610 Laser Printer
    Paper feed problem
    Just open up the printer lid, don't be afraid, you won't break anything. Usually inkjet printers have a panel on the back aswell which you can open by twisting a big knob. It's there especially for unjamming paper. Also, make sure the paper in the tray is arranged in a neat stack and the things that keep the paper in place are tightly placed against the paper.
    May 03, 2011 | Office Equipment & Supplies
    Printer screen says NO PAPER FEED...when there is paper in the tray.
    'No paper feed' is different from 'No Paper' : it basically means that the printer cannot 'grab' a sheet of paper to feed it!
    Just remove and loosen the stack of paper from the tray and reinsert the stack making sure that the sides are not jammed hard against the guides.
    ps. For good measure, also check for any remains of previously jammed/torned print outs.
    Hope it helps!
    Jan 07, 2011 | Brother MFC255CW All-in-One InkJet Printer
    SOMETIMES FEEDS UP TWO OR MORE SHEETS WHEN IT SHOULD ONLY BE ONE
    many printers have a rubber or cork pad under the feed wheels to hold back all the sheets, except the top one. This one doesn't have that, so we'll try a couple other things.
    Pull the tray out and remove all the paper. If you're reusing old paper, that might be your problem. Assuming you have fresh, clean paper, take the whole stack, pinching it at one end, and bow the stack up in the middle. Now pinch the other end of the stack, relax the grip on the end you pinched before, and bend the stack the other way. Repeat.
    With every bend, the stack gets more slanted. Now hold one end of the stack and fan the other end to get air between all the sheets. Fan the other end the same way. The tiny layer of air you're creating between pages goes a long way in lubricating them, so they feed separately.
    Straighten the stack and put it back in the cassette. The blue "fences" at the sides should be touching both sides of the stack to provide a little friction and keep the feed straight. The back fence should hold the stack against the opposite end of the tray. (Your tray is slanted at the feed end. On models where that wall is vertical, you should have a 1 to 2 mm gap so the paper doesn't bind when it tries to lift.)
    Reinsert the tray and try it out.
    Dec 04, 2010 | Brother MFC 240C All-In-One InkJet Printer
    When i give print command the paper was jammed in printer.
    The following sections describe how to load media into the different input trays. CAUTION: If you try to print on media that is wrinkled, folded, or damaged in any way, a jam might occur. Priority feed slot The priority feed slot holds one sheet of media up to 163 g/m2 (43 lb) or one envelope, transparency, or cardstock. Load media with the top forward and the side to be printed facing up. To prevent jams and skewing, always adjust the side media guides before feeding the media. Back to top 150-sheet main input tray The input tray holds up to 150 pages of 75 g/m2 (20 lb) paper or fewer pages of heavier media of 25 mm (0.9 inches) or less stack height. Load media with the top forward and the side to be printed facing up. To prevent jams and skewing, always adjust the side and front media guides. NOTE: When you add new media, make sure that you remove all of the media from the input tray and straighten the stack of new media. This helps prevent multiple sheets of media from feeding through the printer at one time, reducing media jams.
    Also go to this link to do a Printer Cleaning
    Dec 03, 2010 | HP LaserJet 1020 Printer
    Problems with bypass tray taking too many peice of paper then jamming
    The tray is overfilled > Remove excess media from the tray.
    The paper exceeds the maximum stack-height indicator mark in the tray (trays 2 or 3) > Open the tray and verify that the media stack is below the maximum stack-height mark.
    The paper is sticking together > Remove the media, flex it, rotate it 180 degrees, or flip it over, and then reload it into the tray.
    NOTE: Do not fan paper. Fanning can create static
    electricity, which can cause paper to stick together.
    Dec 08, 2009 | HP LaserJet CP3505n Printer
    Will not feed paper of any size. No jams ever.
    clean the feed rollers with water and soft cloth.. try a stack of paper not a single loose sheet
    Aug 15, 2009 | Epson Stylus 1400 InkJet Photo Printer
    Feed problem
    Apr 29, 2007 | HP LaserJet 1100 Printer
    HP Officejet J5780 All-In-One InkJet Printer Logo
    66 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
