Question about Whirlpool GH7145XF Microwave Oven
Exhast fan seems jammed. When you try and run it you get a bad loud hummm like the motor is jammed. The fan had been noisy when running before, so wondering if it was loose before this.
  • 999 Answers
Noisy can indicate a bearing failing and it sounds like it finally siezed. Try spinning the fan by hand and run it again. It might need the bearings lubricated to get a little more life out of it.
Eric
Posted on Jun 26, 2009
Why isthe fan on my new panasonic Genius over the range microwave is noisy NN-SD277
Check to see if the vent is not jamming the motor. It could be something fell into the fan blabes. It could be a noiy motor and this would be a warranty issue.
Oct 11, 2014 | Panasonic "NN-SD277BR 2.0cuft, 1200 Watt...
GE microwave occasionally buzzes loudly.
make this test and fix it. God bless you
  1. MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
  2. Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
  3. Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
  4. Turntable motorA very common cause for a noisy microwave is a worn out turntable motor. This is a relatively easy repair and will put an end to the noise once replaced.
Nov 14, 2013 | Microwave Ovens
The oven has trouble ligting,and make,s a boom sound when lighting
Magnetron
If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
Enter your model number to see parts for your microwave.
Help me find my model number
Exhaust Fan Motor
If the microwave is loud when running the fan motor might be
Stirrer Motor
If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
Turntable Motor
If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Apr 02, 2013 | Microwave Ovens
Coleman EB15A - Buzzing noise from transformer area, no heat or fan
see this causes and proceed. God bless you
Magnetron If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
Exhaust Fan Motor If the microwave is loud when running the fan motor might be
Stirrer Motor If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
Turntable Motor If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Oct 18, 2012 | Microwave Ovens
Microwave made a loud grinding noise while heating a cup of coffee for 1 minute,now everything is shut off. We checked the curcit breakers all ok, and there is power going to it!
see this causes and fix it. God bless you
Oct 15, 2012 | Microwave Ovens
GE Microwave (JVM1860CD001) control board buzzes.
Oct 10, 2012 | GE Microwave Ovens
This oven works well but has ecently got very noisy Why.
The strapping on the exhaust fan break or come loose making the microwave oven very loud, unplug unit, remove top, [several screws] look over to the back right where the fan is located, check the strapping that they are tight and secure. Beware of lethal voltage when running.
Jun 03, 2012 | Sharp Microwave Ovens
The GE Spacemaker Microwave Oven model JVM1540 makes a loud fan noise whenyou turn it on. Sounds like the exhast fan but it not?
It sounds like from the description when it is running the noise comes from the magnetron, some microwaves are louder than others, but this could be an early sign the magnetron is going.
Mar 13, 2012 | Microwave Ovens
Noisy Exhaust Fan
check exhast fan fittings and clean the bush..
Nov 29, 2007 | Frigidaire PLMV169DC Microwave Oven
Whirlpool GH7145XF Microwave Oven Logo
114 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
