Question about 2wire (1000-400108-001) Router
Challenge please Help! Cant install the driver "code 10 problem with the installation"
I have a 2wire 1000 series usb conected to my pc.
I cant INSTALL the 2WIRE driver!!! every time windows detects the driver it installs it buy a message appears that says like "code 10 the device might not work properly due to a problem in the installation" PLEASE HELP! Ive reinstalled, redownloaded the driver and nothing works..
Note: the first two lights are green, and when I use my laptop which has a wireless connection it works perfectly. I know the problem is with my pc.
You do need a driver to install the USB It is here.
Posted on Apr 29, 2008
  • 2,961 Answers
You dont need a driver, open your web browser and type in the address bar and you will get into the router and add your settings manually, so long as your router is set up correctly
Posted on Nov 06, 2007
How to fix code 0000001C
Windows update install a driver but is not working, when i try to make a scan it says that it is not conected when is already conected. CanoScanLide 25
Jun 19, 2012 | Dell Inspiron M5110
I use 2Wire router and usb adapter. I switched
you dont need to install the driver for the 2wire, you just need to configure the computer to look for the 2wire, if unable to locate the 2wire from your computer, there is a problem on your 2wire it self
Jun 13, 2010 | 2wire (1000-100052-000) 802.11g/b Wireless...
I conected wireless adaptor to my pc but will not connect to internet
Hi Peter,
Check whether you have installed the Drivers for the Wireless Adapter,If not please install it and then check it
If you have any Clarification plesae feel free to contact us
Apr 03, 2010 | 2wire (1000-400108-001) Router
2Wire Help USB VISTA 64BIT
check for compatibility. The 2wire wireless adapter might not be compatible with your vista 64 bit
Sep 11, 2009 | 2wire (1000-100052-000) 802.11g/b Wireless...
I need help installing my 2wire wireless adapter card.
I used this one:
This document describes the procedure to install driver for the 2Wire Wireless USB Adapter under Microsoft Windows, and to run a wireless configuration program to configure your 2Wire Wireless USB Adapter to work with a 2Wire HomePortal or OfficePortal wireless gateway. These drivers work under Microsoft Windows 98SE, ME, 2000, and XP.
STEP 1 - Driver Installation
1. Make sure your 2Wire Wireless USB Adapter has not been connected to your computer USB port.
2. Double-click on the file to run WinZip Self-Extractor. The driver installation files will be placed in your hard disk in the C:\TWWUSB_TEMP directory
3. Connect your 2Wire Wireless USB Adapter to an available USB port in your computer. Windows Found New Hardware Wizard will startup.
4. Select the option to search for driver in specific location. Specify C:\TWWGUSB_TEMP as the location of driver.
5. Follow on-screen instruction to finish driver installation.
STEP 2 - Wireless Configuration
1. Run the program WirelessCfg.exe in the directory C:\TWWGUSB_TEMP. You can do so by clicking on the Windows Start button and select Run. The Windows Start button is typically at the lower left corner of the screen. Type in C:\TWWGUSB_TEMP\WirelessCfg.exe to launch the program.
2. Follow on-screen instruction to configure your wireless setting. Enter the serial number and encryption key as they are printed on the bottom of your 2Wire wireless gateway.
Sep 28, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
Hp photosmart 7850 doesn t make conection whit my hp pc
Do you have windows xp for os ???? If so deinstall your printer on your computer and disconnect your usb connection.
First install the driver by putting your cd in your computer...Some product will tell you when to connect your usb cable to your computer...if not, make sure your driver is correctly install. After, reboot your PC and plug-in your usb cable and power up your printer....
Mar 26, 2008 | Office Equipment & Supplies
My usb adapter (2wire 802.11g usb wireless adpter) is having problems.
you cant change the wep key on the upstairs pc unless you change it on the 2wire 1st. the pc wep key has to match whatever the 2wire has it set to. go to the 2wire router settings throught the downstairs pc that is working to be able to see what the wep key is set to, then when you get the key or set a new one enter that key into the upstairs pc.
Jan 08, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
2wire (1000-400108-001) Router Logo
170 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
