Anyway to remove agitaror to get stuck piece of fabric without tearing apart entire machine? Kenmore top loading washer
  • karensjobs Jun 26, 2009
    Hi, Thank you so much! Funny thing, in desperation while waiting for a response, I decided to try and fill it with water and start the agistator. As soon as I got about 3 inches of water into it, it looked like it freed up, so I gave a tug and the t-shirt came right out--what was leftof it, the agitator had made numerous holes in it, butat least it cameout. I have now done another load of junk clothes and included a couple painted up t-shirts and the washer worked just fine.
    But thanks again for the help, very clear and I think even the wife of an engineer (I'm the wife and daughter of engineers) could handle this on her own with your nice simple info.
    Appreciate your time!
  • 5,911 Answers
This is a simple procedure. Just follow these steps:
1. Remove the center post cap or fabric softener dispenser (if equipped) from the agitator by gently prying it off.
2. Under the center post cap locate the air gap plastic cap (if equipped) and remove.
3. Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4. Remove the upper portion of the agitator (called the "auger") by lifting straght up.
5. Remove the lower portion of the agititator by grasping the lower flanges near the bottom of the wash tub and pulling straight up.
This will expose the transmission shaft and anything that may be lodged under the agitator.
Reassemble in the reverse order of the instructions I provided. NOTE: Make sure you only tighten the agitator bolt until it is snug. Do not overtighten as this can break the agitator or restrict its movement.
If you have any questions, please let me know. I hope this helps you.
Posted on Jun 25, 2009
Kenmore 600 series fabric softener dispenser clogged
How do I make the waher Kenmore drop the fabric softener
Aug 25, 2012 | Kenmore 600 3.5 cu. ft. Top Load 110-2962...
My washer has a nasty funky smell-the machine works well, but I can't get rid of the smell. What do I do? I tried clorox and detergent and hot water wash x 2 - no luck!! Help
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the section for the basket and tub assembly's
When our washer had some major problems, we ended up tearing it apart a couple of times (including pulling the entire tub assembly). What we found was a major amount of gunk that built up over a number of years. It's possible that (depending on the age of your washer) you have the same problem.
In order to pull the tub to get under and clean it, see the following for how to remove the agitators, pump, motor, transmission, spin tube and basket.
(It sounds a bit complicated but it's not really that difficult.)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
You don't have to buy a special spanner wrench to remove the spanner nut. I've used a short 10" pipe wrench hooked over one of the tabs on the spanner nut, tap the handle with a hammer and it should loosen.
Also, don't directly hit the drive block with a hammer. Use a short piece of wood under the drive block and tap up on the wood.
As an aside, see the following Whirlpool Service Manual for top load direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Jun 07, 2010 | Kenmore 24032\24036 Top Load Washer
Does the fabric softener dispensar come apart?
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=7914776481dcf14414831964a8792e18
Depending on the model, your fabric softener may have a ring around its bottom. Push down or pull up the ring and the dispenser should pull straight up. It doesn't twist off.
Also see the following Sears site. It may have an on-line manual for your machine.
http://www.managemyhome.com/
Mar 20, 2010 | Kenmore 22422 Top Load Washer
Cloths coming out with large tears/holes in the fabric
Carefully check the clothes coming out of the washer before you put them in the dryer, so you can at least narrow the problem down to the washer or the dryer.
Then check back here.
Sep 11, 2009 | Kenmore 22642 Top Load Washer
How to pull apart fabric softener dispenser
MOST DON COME APPART SOME HAVE A BLUE RING PUT IT UP AND PULL THE SOFTERNER UP AND PUT IN THE WASHER RUN A LOUD SMALL AND HOT WATER AND LET IT CLEAN IT SELF IN THE WAHSER
Jan 20, 2009 | Kenmore 24032\24036 Top Load Washer
Several pieces of clothing stuck under agitator.
you can remove the agitator. there are 3 steps to this. 1.take off the top plastic part of the agitator. 2 remove secondary plastic piece from inside of agitator 3. there will be a 7/16 bolt inside and will be deep so you will need a long extension to reach it. hold the fins of the agitator and remove the bolt with a ratchet. once the bolt is out you will be able to lift the agitator up.
Jan 03, 2009 | Kenmore 22422 Top Load Washer
Washing machine agitator upper half not working I have a Kenmore Elite
Pull the fabric softener cap off, next pull the top cap off the agitator. Then remove the 7/16 bolt in the center of the agitator. Then you can remove the top part of the agitator.
Nov 09, 2008 | Kenmore 24032\24036 Top Load Washer
Fabric softner part
The machine will work fine without the fab softner piece. A new one can be ordered and you will be able to replace the broken one.
Any other questions please ask.
Thanks,
Bill
Oct 16, 2008 | Kenmore 24032\24036 Top Load Washer
A t-shirt is stuck under agitator/spinner thing. How do I lift off the spin assembly?
yes, remove the softener dispenser at the top of the agitator and there is a bolt there that is holding the agitator assembly. if you remove that bolt, the whole piece can be pull out and you can remove the clothe that was stuck in there.
tnx 4 using fixya,
drcool
Sep 06, 2008 | Kenmore 24032\24036 Top Load Washer
Clothing stuck inside at bottom of Washer.
This keeps happening to me too. Solution :The fabric softner cap has two bevels on the side if you place something in it the fabric softner top will come off. Under the that cap there is a bolt, losen the bolt and the agitator pulls up. Hope this helps, my problem is that the agitator moves back and forth while spinning and causes the close to get stuck. I don't know what is wrong if you can help let me know.
Jul 08, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
142 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
