Question about Refrigerators
Icemaker quit working - Refrigerators
    Sergeant:
    Champion:
  • 253 Answers
Check your cooling point if it is ok then get your compresser cheked
Posted on Jun 25, 2009
Floor was soaked with water then our icemaker quit working. what could be wrong
I had that happen and it turned out the cat had bitten through the water line that feeds water to the icemaker. Water had gushed out of the line onto the floor and since the icemaker couldn't get any new water to make ice with, it quit working. A clog, the line simply coming disconnected or a different kind of pet going after the line could also cause this problem. Luckily, a new line isn't expensive, and if you rub some habanero sauce on it, the cats and the rabbits both leave it alone.
Aug 31, 2012 | Kenmore Side by Side Refrigerator
Icemaker on LG LFD25860ST not working.
Sounds like the hot gas defrost solenoid is enegised. the contoller for this may be at fault.
Apr 17, 2010 | Refrigerators
Ice maker quit water line works intermittingly
icemaker quite? hire a new icemaker. industry joke sorry.
First things first, is it cooling ok? if yes then proceed.
im assuming it stopped making ice altogether, and not a matter of making ice but not dispensing.
If your ice bucket is located in the door itself, you have an electric eye icemaker system, which electronically determines if the bucket is full or not. this electric eye system, located on both side walls of freezer, consist of a transmitter board and a receiver board. you could have a problem with these boards, the icemaker itself, a bad water valve, or depending on the model year, a icemaker fill line that can get clogged with ice, but due to a faulty design, a fill tube heater must be installed.
if your bucket is not in the door, but located directly beneath the icemaker, then disregard the electric eye system info and the fill tube heater info as well.
Mar 01, 2010 | KitchenAid Superba Architect KSCS25INSS...
Water dispenser doesn't work
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Thank you for contacting Fixya.com
Aug 12, 2009 | Maytag 24 in. MDB5601AWS Stainless Steel...
Icemaker quit working after I cleaned the coils.
After checking the fill tube (line that fills the icemaker) to make sure it's not frozen , pour about 3/4 cup of water into the icemaker . If the icemaker dumps the water but doesn't refill , replace the water inlet valve . If the icemaker doesn't dump the ice , replace the icemaker . ALSO , make sure the fan which cools the compressor is working . Possible when cleaning the coils , a glob of lint or something , was sucked into the fan and blocked the blade from turning .
Aug 04, 2009 | Whirlpool ED5FTGX Side by Side...
My icemaker quit working. model GC5THEXNBOO
is it getting water in ice maker if yes then water valve is good. now is ice being mad in ice maker if so and it is not dumping out then it is the heater on the ice maker and needs to be replaced.............
Jul 29, 2009 | Refrigerators
ED25PQ quit making ice. Water dispenser still working
Pour about 1/2 cup of water into icemaker . If it harvests(dumps) then problem is the water valve.....if not , then icemaker is the problem .
Jun 26, 2009 | Whirlpool 25.2 cu. ft. Side-by-Side...
ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The water is not working, yet the icemaker still works
sounds like the water tank in back of refrig is freezing up ,,,,, turn temp down and allow 24 hours for it to make adjustments
Nov 30, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
103 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
