Question about Nintendo Wii Console
Won't turn on. NO lights, no power and I know the outlet is working.
Did you try to reset the power adapter? unplug the power from the wall........and everything from the wii.......wait 2 min then plug it all back in........it should work......hope this helps!!
Posted on Jun 27, 2009
Why won't my ml44t transformer turn the connected lights on or off?
1) Copy following link for installing and troubleshooting power pack
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
2) Test outlet for power.
Temporarily run extension cord from another outlet.
Connect wires to terminals a and b ... make sure no insulation is under screw plate.
44 watt power pack will operate 44 watts of low-voltage lights (12Volt).
If 300 watts of lights are installed on line, then lights probably will not light up.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 01, 2013 | Hardware & Accessories
Philips GC 2510 won't light up or heat up
If the iron doesn't heat, make sure power is on to the outlet,,test the outlet with desk lamp for to see if working. check the electrical cord, and check the thermostat + fuse inside replace if necessary.
Jan 25, 2013 | Philips GC 2510 Iron
ML600 won't turn off
The clock module for power pack is not sold separately.
Set timer to auto using override knob so lights are on, then plug power pack into cheap timer.
Check outlet with circuit analyzer.
Try connecting power pack to another outlet.
Copy following link for warranty information, tips to help power pack last longer, links to trippers, troubleshoot, etc.
Jul 15, 2012 | Malibu ML600TW - Low Voltage Power Pack -...
My TV won't turn on. It was fine this afternoon and when I tried to put in on tonight, nothing.
The key here is does the red power light come on? If not follow power cord inside to the fuse that is directly in line with the cord.
If other let me know.
Apr 23, 2012 | Hitachi 51F510 51" Rear Projection...
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
Hotpoint rvm1625sj01 no power
Hello
Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Oct 04, 2011 | Hotpoint RVM1625 Microwave Oven
Machine not turning on
1. Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
2. Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
3. Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
4. Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Hope i could help you.
Have a nice day : )
Sep 04, 2011 | Microwave Ovens
My printer won't turn on. I have tried turning everything off and back on but it still won't turn on.
There is only one way to find out if it is an issue with the printer or the Power cord or Power Adapter.
Normally every HP printer has 2 parts. One cord connects the Printer to an Adapter. the Adapter cord then connects to the Wall outlet.
Now that you have connected the printer to working outlet, Check after 10-15 mins if the Adapter ( black box ) is warm or cold. If the Adapter is warm and the green LED light on adapter is glowing, then it could an issue with the Cord or the Printer.
Try with another Adapter or power cord to diagnose.
For Other brand printers, there should be a power adapter ( black box ) and it should be warm when connected to wall outlet, if it is not warm then it is defective power adapter that you need to replaced. Else it is a problem with printer mechanism.
Regards,
Shawn
May 07, 2011 | Office Equipment & Supplies
Nintendo Wii Console Logo
211 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
