Question about Garmin nuvi 885T GPS Receiver
Nuvi 885 touch screen won't work
Device turned on, and showed password screen, but the touch screen does not respond to any touches. the device is less than 6 months old. very dispointing performance!
    Problem Solver:
  • 7 Answers
I had the same problem and Garmin's answer when I emailed them was...
"There are a few things I would suggest, first we need to updated your
system software (firmware) on the unit. To update your system software
(firmware), download the WebUpdater at www.garmin.com/webupdater.
After this program installs, your unit will need to be attached to the
computer via the USB cable. The WebUpdater will attempt to update itself
and then search for your GPS unit. The program should then recognize the
unit and you will just need to click next and follow the instructions to
update your unit. When the system?s firmware is updated, you will have
the option to update additional software that is present on your unit.
It is best to look at this list as well and check any firmware or GPS
update that are available on this page.
Once the selected updates have download to your device, please
disconnect it from the computer and allow the unit to complete start-up,
during which it will ?unpack? and install all the software updates
downloaded to it.
Secondly, you may want to try a master reset, but be advised that this
may delete your favorites. To back up your Favorites folder, you will
need to connect the nüvi to your computer with the USB cable. Open the
nüvi drive in MyComputer and then open the Garmin folder. Then open the
GPX folder and copy the CURRENT.GPX file to your desktop. If the
Favorites are deleted in the master reset, you can just go back in and
copy the CURRENT.GPX file back into the GPX folder in the nüvi drive.
To perform a master reset, with your nüvi powered off, press and hold
the lower right corner of the screen. Next, turn the power on. Continue
to hold the screen until it asks if you really want to erase all user
data. Select yes. The screen will flicker a bit and then start up like
it did when it was first turned on. Follow the directions to set time
and location. You will have to reacquire satellites by turning on your
nüvi and letting it sit somewhere in full view of the sky. This one time
acquisition may take up to 20-30 minutes. The unit may still ask if you
are indoors or if you are in Kansas. This is normal. Just answer No to
both questions. If you are on the map or satellite data screen, the
green bar at the top will now read "Locating Satellites." Make sure you
leave the nüvi out for the full 20-30 minutes. If you move it or turn it
off early the initialization process may not complete.
After completing the system software (firmware) and master reset, go out
and test the unit, if still having problems, let me know. If you have
any other questions, please email or call us at 1-800-800-1020 from
8am-6pm Central time, Monday through Friday (excluding Holidays)."
It worked for me
Posted on Jul 02, 2009
Touchscreen not responding
If the touch screen of your phone is not responding to touch then it means you have to calibrate the screen to get it working once again.
To calibrate your screen, be sure that the nuvi is properly charged, then you follow the steps below:
  1. Turn off your nuvi,
  2. Press your finger on the upper left corner of the touch screen,
  3. While holding your finger on the touch screen, turn on the nuvi.
  4. Continue to hold your finger on the screen for about 30 seconds until the calibration screen appears(white screen with touch dot),
  5. Then follow the on screen instructions.
That should do the job for you. hope this helps.
Jan 10, 2011 | Garmin nuvi 255W GPS Receiver
Touch screen not working
Try to remove the battery and insert it back into your gps device and turn it on. If the screen does not still work, then you need to reset the nuvi, by holding down the power button for about 15 seconds, then the unit will restart, that way the touch screen should respond. If it still does not work, then you need to calibrate the screen to get it to work. To calibrate the screen, follow the sreps below:
  3. While holding your finger on the touch screen, turn on the nuvi,
  4. Continue to hold your finger on the screen for about 30 seconds until the calibration screen appears (white screen with touch dot),
It might not work trying it once, so you have to try it over time till it works. Calibration is the last resort of all solutions, so if calibrating it does not do the work, then it means it a an internal problem.
Dec 25, 2010 | Garmin nuvi 650 GPS Receiver
My garmin nuvi 660 touch screen dosen't work
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
I have a garmin nuvi 660. the touch screen isn't working
  3. Touch Display.
Oct 24, 2010 | Garmin nuvi 650 GPS Receiver
Touch screen on my garmin nuvi 205 stopped responding
If the touch screen is not working properly, calibrate the touch screen.
Turn Nuvi off and then back on.
Slide power key to the right (lock). Hold your finger on the screen for about 30 seconds until the calibration screen appears.
Follow the directions on screen instructions
Oct 23, 2010 | Garmin nuvi 205 GPS Receiver
Touchscreen don't work..
If the Touch Sceen is not responding properly, calibrate the touch screen.. Turn the Nuvi off then back on Slide Power key to the right (lock) Hold your finger on the secrren for 30 seconds until the calibration screen appears Follow the on-screen instructions
Jul 30, 2010 | Garmin nuvi 255W GPS Receiver
Nuvi 760 powers on but the touchscreen will not work
Apr 25, 2010 | Garmin Nuvi 760 Handheld GPS Receiver
My garmin (nuvi 670) touchscreen does not respond to any touch
Apr 08, 2010 | Garmin 010-00358-00 GPS Receiver
Screen Acts likes its locked
Question: My nuvi 850, 855, 860, 865, 880, or 885 is freezing up or will not boot up past the Loading Maps screen.....
Answer: If your nuvi 850, 855, 860, 865, 880, or 885 is experiencing any of the following symptoms:
  • The touch screen is no longer responsive and the unit appears to be locked up
  • The unit will turn on however freeze at the point where it indicates that it is Loading Maps...
  • The unit takes five minutes or longer to be recognized by your computer as a mass storage device
A software update is now available for you to update your nuvi to correct these issues. Please use our WebUpdater program to install this update.
Please note: Due to this problem, it may take up to five minutes before your computer will recognize your nuvi as a mass storage device. This software update will correct this issue as well. //changed this line from 'solution1description.innerHTML' to use getElementById //to prevent FF warnings. They both appeared to work, but this is cleaner. solution = document.getElementById('solution1description').innerHTML; Last modified on: 12/21/2009
Feb 07, 2010 | Garmin nuvi 885T GPS Receiver
Nuvi 660 touch screen will not respond
on top of the device there is a lock slide switch, make sure its not on the lock symbol, other wise it will lock the screen touch feature.
Sep 27, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 885T GPS Receiver Logo
546 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
