Question about JVC DR-MV7 DVD Recorder/VCR
Universal Remote Code for DR-MV7
I was wondering if anyone knew whether or not the JVC DR-MV7 can be operated using a universal remote, if so, does anyone know where I can find the code? I've looked online and used the codes that came with the universal remote none of which work. The universal remote is an All-In-One Big Easy, model # URC-3300B02.
  • 1 more comment
  • Anonymous Jan 13, 2008
    same problem with jvc dvrm1 cant get a universal remote to work with the unit i tried all the jvc codes
  • Gina Frank Feb 02, 2008
    Same problem here. I can't find a code that operates this model JVC-DR-MV7
  • Frankie_tech Feb 07, 2008
    I have the same problem. Trying to get this unit to work with my DishNet
    remote control. I have tried all the JVC listed remote codes in DishNet guide book. None have worked. I have sent JVC emails asking for help on
    this problem. They have not responded.
SOURCE: JVC DR-MV7
Why are you using a CD-R? You need to use a DVD-R! Or DVD+R.
Posted on Dec 23, 2007
SOURCE: JVC TH-A30 remote code for universal remote RCA universal remote
The entire manual is available at www.safemanual.com. I jsut printed it out.
Posted on Jun 02, 2008
  • 10 Answers
SOURCE: remote control code for jvc tv
HERE IS SOME CODES FOR THAT TV 557 558 559 560
Posted on Jan 11, 2009
SOURCE: My JVC DR-MV7 will play
My JVC DR-MV7 will not accept any disc for playback. I insert a movie disc and it consistently rejects them. After about 15 to 20 attempts, sometimes it will stay and begin reading the disc. It also sounds like some internal components are encountering some resistance (moving parts inside?). Any ideas?
Posted on Jan 22, 2009
  • 1214 Answers
SOURCE: Need codes
Unit does not have a manual, but I did find this -
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Let me know if this works, and if not, I'll keep looking.
Posted on Feb 01, 2009
Universal remote control code
All universal remote controls do not contain all possible codes.
Dec 20, 2017 | JVC Televison & Video
I have two RCA remotes. 1st RCU 310 5538P. 2nd RCU 400 2420BB.
Remote Control Support - RCA ' Made for Moments
www.rca.com/support-remotes
RCARemote Control Support. Select your Type of Remote. Remote Code Finder ...RemoteProgramming. Cable/Satellite Receiver Codes. Select Your Provider.
RCA Universal Remote Control- Target Programming ...
www.thompsontv.com/rcarc.html
RCA Universal Remote Control-Programming Codes. ... Universal Remote. The remotemay already be set up to operate your brand of TV, VCR, or Cable Box.
Program an RCA Universal Remote Without a "Code Search ...
www.wikihow.com > ... > TV and Home Audio > Television
wikiHowHow to Program an RCA Universal Remote Without a "Code Search" Button. Do you have an older RCA universal remote that you want to use, but it lacks a ...
Jan 23, 2016 | RCA Televison & Video
I have a universal control and i don't have the codes for it to work the tv
    Remote Control Code List
    www.jumboremotecontrol.com/remote_control_code_list.html
    Jumbo Universal Remote Control ยท 8 Device ... Programing codes for the remote. If you do not see your device listed, you can use the code search feature to program the device into the remote. TV Codes ... JVC, 013,054,055,060,065,067,089.โ€ŽGuide to Programming the ... - โ€ŽDownload the Manual - โ€Ž8 Device Learning Jumbo ...
    What is the universal control remote code for a JVC television?
    www.ask.com > Technology > Television & Video
    JVC universal codes can also be found on the instruction sheet or manual guide that comes with the remote control or television set. If these universal codes do ...
    JVC Remote Codes
    remote-codes.findthedata.com/l/163/JVC-Remote-Codes
    A list of TV, HDTV, DVD, Receiver, Audio, Amplifier and and VCR remote codes forJVC. images for codes for universal remote control jvc
Jan 03, 2016 | JVC AV-32D305 32" TV
I lost the remote control, how can rewind the hsv tape. Thanks.
There should be a rewind button on the front of the main unit (usually indicated by either REW or 2 arrows pointing to the left), this should be next to the fast forward (again indicated by either F-FWD or 2 arrows pointing to the right) as well as PLAY and STOP - for the VCR. The only thing you would need the remote for is to set the clock and/or perform setup for the DVD player as well as timer recording. Try a universal remote which will make fast forward, play, stop, record (to VHS) and rewind easier.
Apr 11, 2011 | JVC DR-MV7 DVD Recorder/VCR
I lost my JVC remote control model DR-MV79B, This is a some kind of combo DVD/VCR. I tried a rca universal but didi'work
Each universal remote have certain code for each TV, read the manual for code, match the code with your JVC.
Feb 10, 2011 | JVC DR-MV79B DVD Recorder/VCR
Tv problem
Did you change the battery?
Jan 20, 2009 | Televison & Video
JVC code to set my remote
Brand codes for universal remotes are determined by the remote control manufacturer, so there's not really "a code for JVC" that anyone could tell you. You could try looking on the remote manufacturer's website to see if they have the information available. Or you could simply purchase another remote, and you'd have a fresh set of instructions.
Dec 14, 2008 | JVC AV27F476 27" TV
JVC DR-MV7 DVD Recorder/VCR Logo
91 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
