Ford Van air condtioner not working well
HI, I have a 1997 Ford Clubwagon/Econoline E150 and the air conditioner vents for the front dash do not put out very much cool (air no matter what speed the dash selector is set on). The Clubwagon actually has switches on the dash for the front & back of the van. The a/c works great for the rear, which I believe is on a different fan, but the a/c for the back vents comes out fast and cold!. But the front vents don't put out much air at all, and it stays the same no matter which fan speed is selected. I have replaced the Blower motor resistor for the front(no change), and checked the front blower motor itself (gave it 12 volts directly and it ran like a champ. Anyway, I think it might be the dash selector switch for the front a/c but I don't know how to get it out to check it or replace it. Can anyone help? Could the problem be something else? The 134a freon checks as full and the back vents push out cold air, but on this clubwagon the back has it's own condenser.
  • 30 Answers
Have you checked for a vacuum leak on selector switch or under dash? And al freon goes thru same a/c pump. Cold rear means you have cold front. check for vacuum leak
Posted on Jun 25, 2009
Had a similar problem with my 88. There is a vacuum line that ran across behind the passenger side dash that looked like it was plugged by the conversion company, but the plug fell off. This was causing an open line and a vacuum leak. I plugged it with a piece of shrink wrap and tape, worked great.
Wish the rear unit put out good air.
Posted on Jul 15, 2009
Heater doesn't work in 1995 ford econoline van.
I looked at e150, 5.0L engine.
Does the blower motor work? If so, does the engine reach normal operating temp? If so, are the heater hoses, hot? Circulation through heater core? Next, maybe a temp door under the dash has a problem?
Nov 30, 2016 | 1995 Ford Econoline
Front vents blows hot air and back vents blows cold air when air conditioner is on why?
Elaine, this problem is normally a blend door issue, Blend door actuator has to be replaced. Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Heater Blend Door Ford Truck Enthusiasts Forums
Heater Blend Door ActuatorsFor Ford E150 and E250
Ford blend door fix 15 minutes
http://www.factoryairtemp.com/Upload/Factory%20Air/documents/Tech%20Tips/FA4S%20356%20FORD'S%20BLEND%20DOOR%20ACTUATOR.PDF
Mar 13, 2016 | Worldwide 1997 Ford E250 Econoline 5.4L...
Dash lights quit working in my 1988 Ford Econoline E150 Conversion Van
The dash lights are fused. As Ford dosn't lable the fuse panel, you will have to look in the owner's booklet or look at the fuses to see if ones blown.
May 19, 2011 | Ford E-150 Cars & Trucks
Brake and turn signal lights stopped working on my 1996 Ford E150
You might have cut a wire or it could have broken or disconnected. Try tracing the wiring where you hooked up the trailer you may find one broken or disconnected.
Mar 26, 2009 | 1996 Ford Econoline
96' Ford E150 fuel pump reset switch
mine is on the passenger side in front of the front door under the dash with a small hole for acess
Mar 15, 2009 | 1995 Ford Econoline
97 Ford Econoline air conditioning and vent settings blowing hot
I know from experience that if the coolant is to low ( not just the freon levels in the compresor but the antifreeze/coolant level as well) the AC system will not cool and will blow hot. Check the coolant Antifreeze and freon levels, even with the Coolant being a little low my 1998 Ford E150 Van will blow hot. After you have ruled out of these possibilities and the chance it is the thermostat most likely the problem is what Ford calls the "Flap" it controls the air flow through the vent system when you switch from Heat to AC. When the Flap is working it closes off one systems air flow so as to not interfere with the current climate selection.
Feb 21, 2009 | 1997 Ford Econoline
Heating & Cooling Logo
320 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
