Question about Microsoft Windows Small Business Server (SBS) 2003 Premium Edition with Service Pack 1 (SP1) Upgrade Version for PC (5 Client/s) (T7501256)
While using "Adaptec SATA HostRAID Controller";configuring RAID 1, When choosing to "Rebuild array" error message: "Media Error happended during the data transfer. The array will not be optimal"
Check for the both drives to be identical.
ie. both the hard drives should be of same capacity, type and make
Posted on Jul 11, 2009
I have a Gen 8 Hp server with 5No 600GB HDD. The first two disk are mirrored, the other 5 are on raid 5. 1 of the 3 on raid 5 is flagging amber colour. How do I replace the HDD without losing Data?
Before replacing drives • Be sure that the array has a current, valid backup. • Confirm that the replacement drive is of the same type as the degraded drive (either SAS or SATA and either hard drive or solid state drive). • Use replacement drives that have a capacity equal to or larger than the capacity of the smallest drive in the array. The controller immediately fails drives that have insufficient capacity. In systems that use external data storage, be sure that the server is the first unit to be powered down and the last unit to be powered up. Taking this precaution ensures that the system does not, erroneously, mark the drives as failed when the server is powered up. Replacing drives The most common reason for replacing a drive is that it has failed. However, another reason is to gradually increase the storage capacity of the entire system. NOTE: In fault-tolerant configuration, hot-plug hard drives can be replaced when server is ON, but in case of a Non-hot-plug hard drive, it should be replaced when server is OFF. For systems that support hot-pluggable drives, if user replace a failed drive that belongs to a fault-tolerant configuration while the system power is on, all drive activity in the array pauses for 1 or 2 seconds while the new drive is initializing. When the drive is ready, data recovery to the replacement drive begins automatically. For systems that support non-hot-pluggable drives, if user replace a drive belonging to a fault-tolerant configuration while the system power is off, a POST message appears when the system is next powered up. This message prompts user to press the F1 key to start automatic data recovery. If user do not enable automatic data recovery, the logical volume remains in a ready-to-recover condition and the same POST message appears whenever the system is restarted. Automatic data recovery (rebuild) When user replace a drive in an array, the controller uses the fault-tolerance information on the remaining drives in the array to reconstruct the missing data (the data that was originally on the replaced drive) and then write the data to the replacement drive. This process is called automatic data recovery or rebuild. If fault tolerance is compromised, the controller cannot reconstruct the data, and the data is likely lost permanently. Time required for a rebuild The time required for a rebuild varies, depending on several factors: • The priority that the rebuild is given over normal I/O operations (user can change the priority setting by using HP SSA/ACU) • The amount of I/O activity during the rebuild operation • The average bandwidth capability (MBps) of the drives • The availability of drive cache • The brand, model, and age of the drives • The amount of unused capacity on the drives • For RAID 5 and RAID 6, the number of drives in the array • The strip size of the logical volume • Firmware versions of the Smart Array Controller and Hard Disk Drive • Presence of BBWC/FBWC CAUTION: Because data rebuild time may go upto the rate of 200GB/15 minutes, the system could be unprotected against drive failure for an extended period during data recovery or a drive capacity upgrade. When possible, perform rebuild operations only during periods of minimal system activity. When automatic data recovery has finished, the drive status LED changes from flashing green to solid green. If the drive status LED on the replacement drive changes to flashing or solid amber, the rebuild process has terminated abnormally. If an abnormal termination of a rebuild occurs, identify the cause and appropriate corrective steps. Abnormal termination of a rebuild If the activity LED on the replacement drive permanently ceases to be illuminated even while other drives in the array are active, the rebuild process has terminated abnormally. The following table indicates the three possible causes of abnormal termination of a rebuild. Cause 1: An uncorrectable read error has occurred. 1. Back up as much data as possible from the logical drive. CAUTION: Do not remove the drive that has the media error. Doing so causes the logical drive to fail. 2. Restore data from backup. Writing data to the location of the unreadable sector often eliminates the error. 3. Remove and reinsert the replacement drive. This action restarts the rebuild process. If the rebuild process still terminates abnormally: 1. Delete and recreate the logical drive. 2. Restore data from backup. Cause 2: The replacement drive has failed. Verify that the replacement drive is of the correct capacity and is a supported model. If these factors are not the cause of the problem, use a different drive as the replacement. Cause 3: Another drive in the array has failed. A drive that has recently failed can sometimes be made temporarily operational again by cycling the server power. 1. Power down the server. 2. Remove the replacement physical drive (the one undergoing a rebuild), and reinstall the drive that it is replacing. 3. Power up the server. If the newly failed drive seems to be operational again: 1. Back up any unsaved data. 2. Remove the drive that was originally to be replaced, and reinsert the replacement physical drive. The rebuild process automatically restarts. 3. When the rebuild process has finished, replace the newly failed drive. However, if the newly failed drive has not recovered: 1. Remove the drive that was originally to be replaced, and reinsert the replacement physical drive. 2. Replace the newly failed drive. 3. Restore data from backup. More Resources: • Click here for ProLiant Self Solve. • Click here for Creating and Managing Hard Drive Online Spare Technology. • Click here for 17xx Power-On Self-Test (POST) Errors and fixes. • Click here for HP Dynamic Smart Array RAID Controller User Guide. • Click here for HP Smart Array Controllers for HP ProLiant Servers User Guide. • Click here for HP Smart Array Controllers for HP ProLiant Gen9 Servers User Guide. • Click here for Configuring Arrays on HP Smart Array Controllers Reference Guide. • Click here for Array Configuration, Diagnostic, Storage Administrator and SmartSSD Wear Gauge Utility Software and User Guides.
Feb 15, 2017 | HP Computers & Internet
Dell Precision 670 RAID1 Install on Windows 7
The RAID configuration maybe setup in the BIOS settings.
Mar 31, 2012 | Dell Precision Workstation 670 PC Desktop
Enable RAID system
use this guide, this is fo the embedded sata raid controller that comes standar with the ml150 g5.
Enabling SATA RAID functionality in the BIOS Setup Utility: 1.Boot the server, and then press F10 to enter the ROM-Based Setup Utility (RBSU).
2.Go to the advanced tab.
3.Enter the IDE configuration or hard disk configuration.
4.Change the ATA/IDE configuration to enhanced or SATA controller 2 enhanced (if not available then use enabled mode).
5.Configure SATA as RAID or configure controller 1 as RAID.
6.F10 to save and exit.
7.Reboot the server.
8.During post f8 will now show up for the embedded SATA set up.
•Creating the RAID volume.
1.Enter the embedded SATA setup by pressing f8 during post.
2.Enter the array configuration utility.
3.Enter create array.
4.Create the raid volume as desired.
5.Save and exit.
i hope it helps you!!!
Aug 11, 2010 | HP ProLiant ML150 G5 Server
Hi. We have a ML110 server with RAID 5 (4x250gb HD SATA) in a Adaptec 2610SA. The RAID has 2 Arrays (#00 Operating System and #01 Data). We have tried to replace a failed HD and since then the Windows...
Did you make sure that your hard drive has been made into a "dynamic volume" instead to the usual "simple volume"? It has to be "dynamic" before your can put it into a RAID configuration. You will have to use your RAID Controller to create a dynamic volume or to make the hard drive part of a dynamic volume.
Aug 04, 2010 | Adaptec 2610SA (0H2052) Serial ATA...
Dell Poweredge 4300 will not boot up after cmos battery replaceme
Configure your System bios and reboot. Your Hard disk drive was not configured. Pl configure. it will work properly
Aug 22, 2009 | Computers & Internet
Not getting a drive letter from Compaq SCSI RAID setup
Did you see any new drives in the disk managemen screen? To get to the disk management, hold window key down and hit 'R', then type diskmgmt.msc and hit enter.
If you do see the drive in the lower half of the screen, you need to initialize the drive either as dynamic disk or basic disk. Then you need to add a new partition and format it.
Good luck.
Jul 04, 2009 | Compaq (128293B21) (128293-b21) SCSI...
Raid 1 problem
When you are booting your machine, notice the prompt to press keys to get into your RAID controller. Press them and get in. You have to tell it that you want to use that new drive to rebuild your array. You really wouldn't want it any other way. Then when you boot windows it will be able to rebuild it and the message should become one of happiness, given adequate time to rebuild.
Apr 21, 2009 | ASUS P5GD1-VM Motherboard
Microsoft Windows Small Business Server (SBS) 2003 Premium Edition with Service Pack 1 (SP1) Upgrade Version for PC (5 Client/s) (T7501256) Logo
122 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
