Question about Samsung SC-X300L Camcorder
External Lens Issue
I have the external lens for this camera (helmet cam) which plugs into the back of the camera, near the charger input. To use the external lens, when connected you start with the camera off and hold the button on the external lens. The camera will then turn on and use the external lens. I can get mine to start fine, but as soon as I move (likely the connection at the camera) the camera turns off and restarts in a normal video mode without use of the external lens.
I'm pretty sure the problem is with the connection between the two, but whether it is on the camera side or the lens side I cannot say. Any input?
Gryfox
  • 216 Answers
SOURCE: streaky display on camera mode and nothing on playback
This is most likely a defective CCD problem. While most manufacturers have advertised a service advisory for this problem, Samsung has not. Call them and suggest a defective CCD and they'll send you a mailing label for a warranty repair at no charge. 1-800-726-7864
Posted on Dec 12, 2006
  • 73 Answers
SOURCE: In Camera (Record) mode, does not show video at all, black screen
THIS IS YOUR CCD.. SAMSUNG IS VERY AWARE OF THIS BUT STILL CHARGES A ARM AND A LEG
Posted on Feb 23, 2008
hittin1
SOURCE: samsung s630 camera
okay.... Try this if lens is stuck out... look at the side profile of the lens... you should notice the it is not even.. the lens is probably stuck at a slight angle.. GENTLY force the lens to where it looks even... should fix the problem.... worked for me.
Posted on Feb 25, 2008
SOURCE: Samsung camera power-on problem and beeping
same problem! camera HAD been dropped....carefully pull up with a gentle twist on the 'tilted ' side.
thanks for the tip! camera works fine!!
Posted on Mar 31, 2008
SOURCE: Camera will not turn on sucessfully. Says "Turn Off and On Again"
This is not an elegant solution, but it seems to be working. (I might have read some one else mentioning it for another brand of Samsung camera). I hit the end of the camera where the attachment to the computer gets plugged in against the palm of my hand pretty hard about 6 times. Then I tried it and it worked! There is some logic there since it started having the problem right after I put it down on a soft surface from about three feet.(Ididn't really drop it, but tossed it there - gently, I thought - because my hands were full and I was starting to lose everything). In the future I will treat the camera a little more gently knowing that mechanism is somewhat easily knocked out of adjustment.
Posted on Mar 26, 2009
My camera will not turn on when I slide the lens cover switch and will not charge when plugged in.
When the battery is empty, you can't switch on the camera. Why does it not charge?
Could be the switch behind the lens cover does not work correct or not at all. Could be the power cord is not ok. Or the socket where the cord goes into the camera.
Can you try to charge the camera on an external charger and when it is charged, try switching on again.
Feb 13, 2014 | Optimus DS-5080 Digital Camera
Wont turn off-on
Taking out the battery, when a camera acts strange, is a good thing ONLY. be sure the camera is not busy saving pictures, because you could damage all pictures on the memory card.
I'm not sure the lens was out, when it was connected to the computer. Let us assume it was. Normally, the battery should be charged when the camera is connected to a USB connector on the PC. But not all USB connectors are perfect wired. And if you use a USB hub you can be sure the battery was not loaded. So as soon as the camera came from the PC it needed full power and could not get it.
Now you removed the battery, but before placing it back in the camera, please charge it on an external charger. When you place the charged battery, and the yellow light starts flashing again and won't stop quick, you could try to reconnect the camera to the computer and see what that brings. I would have switched off the camera, before I disconnected it from my PC.
Than the sand issue. If just a grain of sand is in the lens bellow, it could serious obstruct the lens from going back. If you can see the grain of sand, you could try to get it out. Very thin needle (or two?)
But if you can't see something, don't move the lens at all.
You could damage the gears in the focus and zoom mechanism.
I wish you luck with the camera.
Nov 11, 2013 | Samsung Digimax EX1/TL500 Digital Camera
Camera said battery exhausted when i went to take pic so I plugged it in to charge. light blinking but even though it looks like it is charging I cant turn it on to close lens
Normaly the lens would go in, as soon as the battery runs low.
Perhaps you should wait till you unpluged the camera.
Try to charge the battery in the external charger. Then after replacing the battery everything should work fine.
Nov 01, 2013 | Nikon Coolpix 5200 Digital Camera
Why is my camera say exhausted battery and will not take a charge?
The internal battery charger may have failed and is not charging your battery. External chargers are inexpensive. Buy one and charge you battery on that and see what happens. If the camera works with the externally charged battery, I would do nothing further. Why pay for a repair that you can live without? If that does not solve your problem, the camera may need to go in for repair.
Jan 23, 2012 | Nikon Coolpix S4000 Digital Camera (Pink),...
Lens will not retract, get a zoom error message. Tried plugging into charger and then turn it off nothing happened.
May be the lens are blocked
Clean the lenst external side( the cilinder)
Use a soft cloth or air compresed
try the following
1.- Turn OFF the camera
Softly PULL the lens
2,. Softly PULL the lens while Turn ON the camera
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 21, 2011 | Fuji Cameras
My Camera just lost power, the lens is still stuck out, the battery was full when i used it, I also tried plugging in the charger now to see if it will restore power but it hasn't.. What should I do?
hi
usually camera doesn't lose power with lens stuck out, there must be external cause. But you should check first battery which actually is good or not.(using multimeter or to different camera that use same battery.) second with good battery is any light blinks momentarily. If any light blink then cause come from lens most case. But nothing happen then main pcb or power control pcb is the problem. Good luck with you!
May 22, 2011 | Olympus T100 Digital Camera
My web cam is fuzzy can i fix it
If this is related to and external web-cam, the issue can be fix by turning the focus adjuster, located on top of the lens (round ring that goes around the lens). Turn around until it gets clear image.
Good Luck!!
Jan 12, 2011 | Computers & Internet
I have charged my camera but it will not stay on when turned on
you dont have explain exactly the problem.. if the problem turn on and off istantly this is shure a lens problem and you mst change the lens. if the camera turn on one two 3 minute and than turn off its probably that the camera dont charge the batterie. if the camera dont charge you can bypass the problem. you can buy on ebay a external charger for your batterie. if you search on ebay international seller you can find charger and batterie to a very good price. its possible to find two batterie and one charger to 10 sterl. so you have new batteries and a external charger. external charger is better as charge the battery in the camera. why i is nott so difficult that the batterie explode and ruine the camera. with a external charger this is not possible why you can ruine the charger that have a low cost but not the camera. i hope that i have help you. its possible that the camera dont charge its possible that the batterie dont mantain the charge.. its possible if the camera go on and go out directly that this is a lens error.. sorry foer my english
Aug 10, 2010 | Kodak EASYSHARE M1063 Digital Camera
Zoom error appears in viewfinder on FinePix S7000 and cannot take photos.. Please help
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Oct 02, 2009 | Fuji FinePix S7000 Digital Camera
Samsung SC-X300L Camcorder Logo
55 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
