Question about NEC LT170 Multimedia Projector
Nec lt170 projector has a picture problem- seems to be wavy
When I turn on my projector (dlp) the picture does this thing thats hard to put in exact words. The image kind of flashes dark and bright, but not all over, just in places. Sometimes the cycling of the flashing is fast, other times slow, and the places flashing change. It seems to stop doing this after 30 minutes or so, but sometimes will start again later. The bulb life is 2000 hour rated with only 600 hours used. I have removed the color wheel and cleaned it and also the pickup, but this didnt help a bit, only the picture is a tad brighter and clearer now :) But is still does this wavy, flashy, flickery thing. Put it this way, remember watching old black and white movies, when the screen kind of goes in and out, like using bad film? Thats it!
Ive tried turning off any other lights on the circuit my ppojector is on, but no help. It just started doing this a few weeks ago. Before then it was perfect. HELP ME!!!!
5 Suggested Answers
Marrie
  • 563 Answers
SOURCE: NEC LT170 diplays annoying line
Hi there
This is a common Mainboard failure - you'll have to get this repaired or replaced !
Must warn you that this is quite expensive
Posted on Apr 02, 2008
SOURCE: nec projector vt 660
Bulb is in correctly. Everything operating correctly. The picture being projected is yellow.
Posted on Oct 06, 2008
projdoc
  • 2237 Answers
SOURCE: Sometimes the NP50 lamp will come on, sometimes it
projectors really don't like hot and humid. they love cool and dry. if the colorwheel is failing, the lamp wouldn't come on. humidity+dust+intense lamp heat=coated components. such as the colorwheel glass, which is clear and coloered. fried dust will cause dimness. you'd have to send it in to nec.
Posted on Aug 20, 2009
AJIN G
  • 6694 Answers
SOURCE: I just bought a used
hi,
Possible problem is the faulty lamp cooling fan. Check the lamp cooling fan of your projector. if the RPM of fan is low then the lamp can get over heated. May be its has some problem.Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now u can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector.
i have added a video how to oil the fan for make it easy for you.
ok
Posted on May 08, 2011
My projector Nec model V300X after sometime the colour of the image starts changing and eventually turns discoloured what is the solution to this and what may be causing this
DLP projectors use a light tunnel called an engine. The bulb sends light through this part and the image is gathered from that process. Light engines wear out from heat. I am not able to get any service part info on that machine. You need to contact NEC or replace it.
Jan 23, 2016 | NEC Office Equipment & Supplies
Change the bulb on NCE v260X and I still have white snow flake when I turn it on
Have you adjusted the contrast and Keystone. A new bulb should be plenty bright. Maybe clean the lens. There is in some types of Projectors a color wheel inside this can become dusty. But not often if you keep the filters in place and clean them. This could cause a snowy picture as well. Hard to say without actually seeing the picture to say what the issue could be. But these are some of the stronger possiabilities.
Sep 30, 2014 | NEC NP-V260 DLP Projector
NEC WT610. projected image is backwards. Unable to maintain image from laptop
use the menu to change orientation of the projected picture
Jul 08, 2011 | NEC WT610 DLP Projector
NEC LT265 Multimedia Projector will turn on, but does not fire up
the bulb needs to be resetted after fixed or the other problem is that the bulb is not fixed.or the ballast is faulty. check out all the options 1 by 1 in the given link how to replace the colour wheel with diagram and procedure
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
how to replace the lamp in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
how to replace the ballast with diagram and procedure
http://www.consumermeet.com/entry/samsung-dlp-ballast.html
Mar 11, 2009 | NEC LT265 Multimedia Projector
Nec lt260
Clean optocoupler under pcb 4554B on color disc wheel.
Dusty on this part make not good sincronice with dlp panel.Good luck.
Jun 28, 2008 | NEC LT 260K Multimedia Projector
Nec picture turns megenta
I'm gonna take an educated guess and say this is a DLP projector. Sounds like the DLP wheel is slowing down causing blurriness and Magenta when the wheel stops. It probably needs a new color wheel. Call NEC and see if they have a bulletin or notice on this issue. If you're lucky, you might get a free new color wheel or replacement projector from them.
Jun 12, 2008 | NEC HT1100 Multimedia Projector
Hi there
Mar 28, 2008 | NEC LT170 Multimedia Projector
NEC LT170 Multimedia Projector Logo
222 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
