Question about Saeco Royal Cappuccino Espresso Machine
Brand new machine (1 day) - i find it hard (very hard) to slid out the Drip Tray. Is there a secret here?
  • andrewtsmith Jun 26, 2009
    Thanks bansheracer - useful information
  • 1,089 Answers
Hi
Lift the tray a little before pulling out. There are 2 locating pins that lock into the bottom of the machine. Push the drege drawer in with 1 finger, pushing on the right side of the drawer when replacing it.
Posted on Jun 26, 2009
How do i open water resovor on krups oblo coffee maker
See page 8
8
8
FIRST USE
Rinse water tank before first use.
Fill water tank with fresh, drinking water. insert
water tank to machine.
Switch machine on. Power button starts
blinking red while machine is heating up for
approx. 40 seconds. Afterwards power button
lights steady green and machine is ready.
40 sec
ON
Push selection lever to the "HOT" position.
Machine starts rinsing.
Open locking handle and insert empty capsule
holder. Close locking handle.
Place jug under outlet.
Push selection lever to the "COLD" position.
After approx. 60 seconds push selection lever
to the "STOP" position. Empty jug and refill
Make sure that the selection lever is in "STOP"
position. Then plug the power plug into a
mains power socket.
to the "STOP" position. Machine stops rinsing
and power button blinks red for about 5
seconds.
8
Place drip grid on drip tray. Then insert drip
tray at desired position of drip tray.
Then insert drip tray at desired position of machine.
Jul 02, 2017 | Krups Coffee Makers & Espresso Machines
Good morning, I have a major problem with my Imprezza z 5 , I have had it for over 6 years and love it. It makes the best coffee ever, I have the machine regularly serviced by the Perth WA (AUS) service...
The real problem is internal leakage which means the machine will have to be replaced. The service centre probably is well aware of this type of failure.
Jan 08, 2015 | Coffee Makers & Espresso Machines
Black & Decker CM1050B coffee maker, the drip misses the pot routinely
filter door(tray must be fully inserted(closed and the pot must be on center with the burner tray undernerath.. check to see that the funnel under the filtewr tray is on center with the pot lid..
Jan 08, 2014 | Black & Decker CM1050B
I have a cv615 Miele Coffee Machine. The water reservoir was not inserted properly and water leaked into the bottom of the machine (drip tray). We got the Water System Fault message, so we removed the...
just use your hair drier to dry out the remaining water.Before doing anything remember to unplug the device.Remove the tray and other such attachments and let it to dry by itself for a day or two.this should solve the problem.never plug in the device till then.
regards.
plz. rate this
Jul 04, 2011 | Microwave Ovens
New Royal Professional Machine has the workd Dregraw.miss can not use the machine what must I do to get started need help.
Hi
Dredge drawer is the big box on the bottom right. That is where the grounds are dumped. Remove the drip tray and pull the drawer out about half way. Push it back in with 1 finger on the right side of the drawer. That should clear the message. If it comes back on when you put in the drip tray, there is a section of the drip tray that can be removed to stop that. On the right side of the drip tray is a notch. Inside that notch is a thin piece of plastic. It curls up on the right side. Cut out the piece that curls up (just the piece that curls, about an inch). When you push in the drip tray that curl lifts the dredge drawer and knocks it out of position.
Jan 10, 2011 | Saeco Royal Digital Plus Coffee...
It says driptray full, but it isn't? Any ideas?
Wevhave had ours into the shop four times for the erroneous 'coffee grounds' and drip tray' emptying. They have changed the mother board, chip in the door and even looked at the head gasket and carburettor settings but can't find the source of the problem.
What we have found latelt (it's Christmas so everything is closed for a month) is if we leave it overnight without power, 3 out of 4 times it resets itself.
It's apain if it plays up during the day but mornings brings us a good cuppa more often than not.lesson-get a deLonghi next time, this Saeco brand is more trouble than they are worth.
Nov 28, 2010 | Gaggia Titanium Espresso Machine
How to remove drip tray
Hi
Lift up on the front of the drip tray and pull out the front. There are 2 locking pins on the bottom of the drip tray that lock into the machine, that is why you lift up on the front of the drip tray before you pull out.
Apr 20, 2010 | Saeco Royal Cappuccino Espresso Machine
Saeco Magic De Luxe type SUP012 r Water leakage into brew unit
HI
Your grind might be a little to coarse or you are not getting a full charge of coffee in the brew unit. Water is released into the drip tray when the brewing is over. If the grind is to coarse or you don't have enough coffee dossed into the brew unit, then there is more space for water and you get more water in the drip tray. Open the door and push the lever at the top center of the door towards the plus but not all the way. 1 click back from the plus(+) is fine. When the machine is grinding pull the handle toward you(smaller number). Now change the grind a little at a time, but don't make it too fine. That will cause a lot of problems later on that is hard to correct.
Jun 26, 2009 | Saeco Magic De Luxe Espresso Machine
Water hissing at back of brew unit after coffee made
I think you have to replace the steam valve.
Have you descale your machine regulary?
How old is your machine?
Maybe your boiler have to be replaced:-(
Jul 25, 2008 | Saeco Incanto Classic Espresso Machine
Hi, we have aa Saecco Cafe Grande an automatic Espresso Coffee machine. We purchased over 1 year ago from Future Shop. The machine only recentlly started to leak from the bottom, I did some...
Possible areas are the steam valve leaking or the boiler valve housing is leaking. I suggest Contact Saeco USA Inc. to located a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Apr 05, 2008 | Saeco Vienna SuperAutomatica Coffee...
Saeco Royal Cappuccino Espresso Machine Logo
49 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
