Question about Kenmore Freezers
My kenmore freezer model 25324082102 has an alarm going off and it appears that the food items are starting to defrost. I can't find my manual and I'm not sure what the alarm is for. Any assistance
Tech007
  • 63 Answers
SOURCE: Kenmore model 2539280412 upright freezer alarm keeps going off
might have a defrost problem check to see if it is building up with on the back panel if it is you need a defrost timer or limiter or heater or fan
Posted on Aug 29, 2007
buddymcl777
  • 67 Answers
SOURCE: THE ALARM LIGHT HAS COME ON HOW DO I RESET
When it is fixed and the temperature goes back down it will automatically go off.
If it's stuck trying unplugging for 10 minutes and then plug back in to reset. If it has a battery backup take out battery.
Inside the door near top there is sometimes instructions to hold the button for 3 seconds to reset or unlock controls (on modern Frigidaires and some Kenmores).
Posted on May 04, 2009
SOURCE: Can't get alarm to turn off while temperature stabilizes
My wife solved it for me :-) You turn the alarm off with a switch at the bottom. The alarm turns off, but the light stays red for another 4 hours. After that the red light goes off too, and you can turn the switch back on without the alarm going off, if the freezer is back to operating temp.
Posted on Aug 06, 2009
SOURCE: temp alarm on freezer alarming.
that's the same problem i incurred, i replaced the thermostat and the fan. seems to be working fine.
Posted on Feb 25, 2010
  • 6 Answers
SOURCE: My kenmore frostless 16 upright freezer alarms
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Posted on Jun 14, 2010
Fan on freezer won't com on but freezes food on
Hi and welcome to FixYa, I am Kelly.
There are 12 midelos that fall under the model number you passed. I will cite EV171NYMQ05 as a reference model number via this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5140769
The freezer fan should be on anytime the compressor is on. If there is an ice block built up on the evaporator coils it can lock the fan blade in place via the ice build up. Additionally... if the fan motor bearings are dry or coated with sludge this too can prevent the fan motor from operating. The fan motor is item 3 this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5140769&diagram_id=28174432#d28174432
Detail views:
http://www.appliancepartspros.com/Appliance-Parts/whirlpool-motor-evap-item-number-ap4539455.aspx
To check the can motor all that is required is a simple continuity check across the 2 connector wires. You should read under 480 ohms.
If you discover that the fan blades are encased in ice... do a manual defrost: (be ready to tend to a water mess)
1. By first unplugging the unit and then removing the freezer contents.
2. Direct an external fan into the freezer compartment for just over 2 hours.
3. Make sure the compartement drain funnel is clear of obstructions. Item 11 this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5140769&diagram_id=28158051#d28158051
After the 2 hour manual defrost period plug in the unit and test to see if the fan motor is running.
If it is running you may have an automatic defrost problem causing the ice build up. On a freezer the ice build up will start again if there is an automatic defrost problem in 3 - 5 days. Until the automatic defrost problem is corrected you will end up doing the manual defrost routine described above everytime you have improper cooling problems.
Components that can cause the automatic defrosting problems are
1. The defrost timer item 7 this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5140769&diagram_id=28257341#d28257341 Because it is not cycling or stuck in one position.
2. The defrost bi-metal thermostat item 9 above link (stuck closed)
3. The defrost heating element item 5 above link. (open)
And of course internal wiring....
Check the fan motor for continuity... if you attempt to lubricate it which is very difficult on this fan motor make sure you use paraffin based "Turbine oil" and not a regular household or automotive oil. Using any other oil will cause the fan to stop working in as little as 30 days.
Thanks for choosing FixYa,
Kelly
Jul 08, 2011 | Whirlpool 16.7 cu. ft. Upright Freezer...
The Temperature alarm is going off. What does this mean
The unit is not at correct temp, ""unsafe to keep food"". Needs service.
Hope that helps. Russ.
If you remove all the items from the unit and defrost it for 2 days with door open, on restart, should work fine..
Jun 11, 2011 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
I have a Kenmore Frostless Model #: 253.21041104 The temp. alarm keeps going off. The red light blinks and alarm goes off. Owners manual says that it is from warm conditions, but there are no warm...
Best thing to do first is get a thermometer to be sure the temperature is correct. Items still freeze at higher temperatures. If you have ice cream and it is soft, then you have a temp problem.
Jul 05, 2017 | Kenmore Freezer 13.7 cu. ft. Upright...
Defroster get red hot
Kenmore Frostless Upright freezer model# 23971. The alarm sounded, all contents in freezer is frozen solid. We turned the alarm off, but the red light continues to blink. How do you reset the alarm and stop the red light from flashing? It has been 3 days now and every time we have check to see if the contents has started to defrost, there is no signs of defrosting, everything inside of the freezer remains frozen solid.
Sep 01, 2010 | Kenmore Freezer 20.6 cu. ft. Manual...
Sears Ken Elite upright freezer model no 25329082991 temp alarm
alarm should go off when freezer reaches minus 18c or lower.
Feb 05, 2010 | Freezers
I just moved into a home with a kenmore chest freezer. This is a real dumb question, but which symbol means on. Should the circle be showing for "on" or should the line be showing for "on"?
Some freezer models feature a temperature
monitor that provides an audible
alarm. The temperature monitor alarm is
located near the temperature control
The alarm sounds if the temperature in
the freezer rises 10° F (12° C) or more
above normal for selected setting. Alarm
may sound if temperature control dial is
turned to a much colder setting or if a
large amount of unfrozen food is added at
one time. Alarm is controlled by a three
position switch
0 = OFF prevents alarm from sounding
when freezer is warm, such as during
initial start-up or defrosting.
• ✓ = TEST sounds alarm regardless of
temperature. Alarm system should be
tested at least once a month.
1 = ON is proper setting for normal
freezer use. Return switch to 1 after
defrosting.
Jul 07, 2009 | Kenmore Freezers
Kenmore Upright Freezer Alarm
I think problem its not with thetmostat but the compresor work but not correctly not have enought power to create pressure.
May 12, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore Upright Freezer Model 253-9280810
is it possible the door has not been closed at some point?
If so they can build up with ice in the evaporator which the defrost system cannot handle....Try a manual defrost.
Depending on where the unit is installed high ambient temperature can drop the internal temp enough to set the alarm off though they will still freeze sufficiently
Dec 28, 2007 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Aug 10, 2007 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Temp alarm going off
What is the temp in the freezer, sounds like temp is to low..no water should be coming out of freezer, sounds like may be defrosting Need to check the temp to make sure its cold enough.. thats what that alarm is for
Freezers Logo
81 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
