Question about Home
Toilet Bowl fills up EXTREMELY slow
I flushed my toilet and the refilling water is puring in at a very slow drip. The only problem the toilet was giving us before was that the flapper wouldn't go down after flushing.
    Sergeant:
  • 353 Answers
Sediment in the valve
Posted on Jun 25, 2009
Re. Duravit Happy D toilet (tank No. 0929100005)
Remove and clean the flush valve and the flush valve seat(it is the flap that opens up to allow water to flush the toilet). Once the edges of the valve and the seat are cleaned, possibly with "0000" grit bulldog steel wool, it should not leak anymore. To make sure it is not leaking, once tank has refilled completely, put some food die in the tank. If, after 10-15 minutes, the water in the toilet bowl is colored, you have a leak from the flush valve. Replacing the flush valve is very easy - just bring the old one with you to the hardware/plumbing store and ask for a replacement. Blessings and good luck!!
Sep 23, 2017 | Duravit Home
My geberit model number 131.028 dual flush won't shut off with water and leaks into the toilet bowl
How old? Who installed? Any warranty? I'd follow that route first.
If not warranty I'd try to get the installer to be interested. Perhaps he will have a "red face" an help out.
Feb 27, 2015 | Geberit 131.028.SJ.1 Black Glass Monolith...
It takes a long time to fill the tank
There could be partial blockage of the water supply line causing a slow fill.
Feb 20, 2014 | Kohler Cimarron Comfort Height elongated...
The toilet tank takes a long time to fill up
if the water keeps flowing then try replacing the flapper if it still flows then the fill tube gasket or tank to bowl gasket need to be replaced.
Mar 23, 2013 | Home
Water drips from small holes upper sides of toilet
There may be something jamming the shut off control valve This is fully covered if you past this link in your browser; http://www.wikihow.com/Fix-a-Running-Toilet
Mar 08, 2013 | Home
Refill tube constantly detaches from fill valve
A longer piece of tubing may solve the problem. Put the extra down the overflow tube so it won't pop out. Hope this helps.
Dec 29, 2012 | Toto Carlyle 1-piece Elongated Bowl Toilet
Elijer Diplomat toilet flushes perfectly, but after the water in the bowl takes forever to fill up again. You have to wait 10-15 min. before the water is up to normal level and it will then flush...
Pressure assisted toilets have a stainless steel tank that refills under lid,if your refilling bowl it only needs to fill trap for smell,the pressure assist does the rest,thats part of the water saving of the toilet,you don't have a lot of water in the bowl
Jan 28, 2011 | Eljer Aqua-Saver 12" Two-Piece...
The toilet takes a long time to refill after a flush would there be a certain part that is plugged or wore out ?
Is the flapper valve slow to return to the closed postion allowing water to flow through the flush valve? Make sure the toilet flapper is moving freely and is sealing properly against the flush valve. If there is no lengthy or continual water flow in to the toilet bowl then this is not the problem.
Is the water valve on the water fill line to the toilet tank fully open? This may seem silly but it could be this simple.
Check to make sure your fill valve is opening fully. If you have an older toilet there may be some deposits that need to be cleaned way to allow free movement.
If toilet does eventually fill to the desired level, there is no leakage, water valve on fill line is fully open and fill valve is opening fully then recommend you shut off water supply, drain toilet and disconnect water fill line from the water valuve and toilet tanke to make sure there is not a blockage. If the water line and connections are clear you may need to remove the fill pipe in the tank and check for blockage. If this is very old, conisdering the cost and effort, it may be simpler to replace at this time rather than trying to extend the life.
Jan 15, 2011 | American Standard Home
Toilet will not flush
You need to replace the fill valve with a oem replacment valve. You need to use toto parts.
Mar 07, 2009 | Toto Aquia II Dual Flush Toilet
Home Logo
451 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
