Question about Refrigerators
I have an older Antares vending machine that is freezing the canned soft drinks. Is there an adjustment to raise the temperature of the refrigeration unit so that it no longer cools to the point of freezing the product?
Replace with new evaporator coil pn.216701200
Posted on Feb 07, 2011
Why are front three selections vending two cans?
There is an adjustment for the length of the cans. The columns that are not working properly have too much slack. Open it up and look behind the cans. There is a metal plate with spring loaded clips, top and bottom. Squeeze them together and move the plate forward to take out the slack. Do it top and bottom. When properly adjusted the cans will move a little (1/4 to 1/2 inch).
Apr 01, 2016 | Selectivend CB300 Satellite Ice Water Cold...
Tip
Vending Machine Supplier
About Us : <br>Upton vending A largest vending machines company in UK, that provides wide range of vending machines in North Yorkshire at affordable rates,well known for customer satisfaction.Our best services are <b><a href="http://www.uptonvending.co.uk">vending machine companies</a></b>,vending machine, snack vending machine, drink vending machine,commercial coffee machines in UK..<br>Contact Us : <br>The Vivars<br>Selby<br>North Yorkshire<br>YO8 8BE<br>Tel: 0 1757 629112<br>Fax: 01757 294600
on Aug 17, 2013 | Nu-Dell Manufacturing Vending Machines Ad...
Change the thermostat, that's what regulates the compressor.
Nov 28, 2013 | Refrigerators
Genesis go380
how come my Genesis will dispense two chocolate bars at a time? Is this a setting of some sort?
Aug 13, 2013 | Selectivend Combo Vending Machine for 14...
I have an Antaris vending machine that has a frigidare cooling system. It was manufactured in 2006 and has been working fine. Recently the motor kicks on but the cooling system does not and it does not...
the antares is notorious for having evaporator problems. The evaporator is not galvanized and as such rusts after a period of time. Once rusted through the coolant is released. The machine will no longer get cold until the evaporator is replaced and the sytstem charged with coolant... gene
Aug 24, 2010 | Frigidaire Refrigerators
I have the same problem with my Antares vending machine. Do you know what the model number is on that Frigidaire freezer? I want to buy a new evaporator but can't seem to find it.
You need to contact Frigidaire Parts Division. You need an evaporator for their EDINA Model FMR7. The part number is 216701200. It should cost approx. $100.00. This should be all you need. Good luck.
David
Mar 08, 2010 | Refrigerators
My Edina cold soda vending machine which was made by Frigidare is not getting cold. The previous owner (my neighbor who I trust) said it had always worked fine. It had been in his garage, unplugged, for...
I have some of those machines. What happens to them is that the evaporators, which are made out of steel, rust out in approx. 7 years. This allows the R134A to leak out. If you can peek back through to the back wall, you will see where the rust has run down. The solution is to order a new evaporator from Frigidaire at around $100.00 and get someone to change this out and recharge the unit. Before turning it over to the mechanic, you may want to remove the vending module which includes the inner doors and plastic shelves. This can be done in 15 minutes and makes the job easier for the mechanic which can save you money. You should end up with less than $300.00 for the total cost of the repair, but since these machines are rather popular, they can be had on ebay fairly cheap. Sometimes you can pick up new machines for five or six hundred dollars. These are the same as the Antares machines which are made by Edina. I hope this helps.
Jun 18, 2009 | Electrolux Refrigerators
We have a GDM-26 commerical coke machine. Only
If any of your drinks are freezing you need to adjust your temp setting. The suggested setting is 5. changing the temp setting basically tells the refrigerator to stop cooling when the temp hits a low degree, and to start cooling when it hits a high degree. This keeps your drinks not to hot, not too cold, but just right. If this doesn't work I would change the cold control altogether, it might've went bad. If you have a few minutes, locate the condensor fan (bottom) and make sure it is periodically turning on and off like it should.
Jun 08, 2009 | True GDM-12 Refrigerator Commercial
Refrigerators Logo
457 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
