Question about Acer Computers & Internet
On/off button stays on. only fan runs. Computer does not boot up.
  • 221 Answers
You need to replace the power supply unit, or you can digg it deeply to it to find which voltage is missing.
Need more detail, just let me know.
Best of luck
Posted on Jun 25, 2009
Why does gateway model 5310 power button stays on but won't boot
have you done a good clean on the fan if it over heats it will only run for a couple of seconds.i use a very small hoover
May 01, 2014 | Gateway 5310 (1008368) PC Desktop
My Dell Inspiron 530 used to freeze up ever so often. I would have to manually shut it down and restart.After a while I found out that running the AVG scan it wont shut down so often.One day while booting...
This is a system fault error condition, including the power supply. Only the +5VSB rail on the power supply is working correctly.
ports to see if anyare damaged and then try powering on the system to see if you get a green power button.
Feb 23, 2011 | Dell Inspiron 530 Desktop Computer
Inspiron 1100 wont boot up,screen stays black,i can hear the fan running,sounds like hd is starting
STEP: Run the Preboot System Assessment (PSA)
Additional Information
  1. Ensure that the computer is powered off.
  2. Press and hold <Fn> and press the power button to power the computer on.
  3. Release both buttons. The PSA diagnostics sequence begins.
  4. Make note of any PSA beep codes or PSA error codes
Check for PSA Error codes on support.dell.com.
If all Test Passed. Then Perform Dell Factory restore or OSRI.
Jan 20, 2010 | Dell Inspiron 1100 Notebook
Fan runs but no boot
your motherboard is the problem. you should get it checked out at a local computer store.
Aug 22, 2009 | HP Compaq Presario SR2011WM PC Desktop
Computer will not boot up
rest bios by removing battery and holding power button for 1 min.
Jul 07, 2009 | HP Pavilion dv6000z Notebook
Fan is running, power button with blue light is off, cpu won't boot up
Your cpu might have died. As the computer is starting tap F8 and choose last known good configuration to see if you can get it started.
Apr 26, 2009 | Gateway 500GR PC Desktop
Power button stay amber, dont finish booting
Generally, this is an indication of a motherboard failure. Remove any items connected externally and and expansion cards intenally and see if the Power LED indication changes. if not changes, then replace the motherboard
Mar 31, 2009 | Dell Dimension 3100 PC Desktop
Thinkcentre M55 8806 power on off problem
May be your computer motherboard wires connection get loose or getting moisture in wires. Or there may be some earthing problem in ur power switch. First, check the wires connection & tighten up properly. if problem persists, check the earthing by power tester. Check you RAM if it is properly tight in the jack.
Dec 26, 2008 | Computers & Internet
Computer turns on, but does not boot to XP
Generally, fans are controlled by heat readings...something to check is the operating temperature that is shown in your BIOS when you boot up...(access your BIOS by tapping on the delete key, or F2 key while booting)..if it goes over 70C real quick then there is a CPU heat dissipation problem, which would cause the fan to run like this i think that it is more of an issue that your CPU died...has your machine taken any kind of hit or fall that might have loosened things?...or perhaps the heat sink compound between the heatsink and CPU failed.....
but it also could be a dead MB
Jun 06, 2008 | Sony VAIO Digital Studio PCV-RX660 PC...
Computers & Internet Logo
73 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
