Question about Garden
Auto shut off when trigger released does not activate
  • 92 Answers
Dear rbaker2,
Auto shut off is carried out by means of a spill valve or also know as a control valve. When the gun is closed, pressure is built within the machine and within the spill valve. With the pressure the spill valve is compressed and pushes on a microswirch. When this is done the microswitch shhuts the machine down. Now your problem is caused by one of 2 faults. Either the spill valve is faulty or the micro swithch is faulty. Most machines it is the spill valve which mostis the fault. But microswitches are also delicate and also get faulty. A rare reason for your problem is that both the spill valve and the micro switch are faulty. The spill valve and the micro swith, is rarely serviceable. So I advice you change the two of them by new ones. A bit of advice do not leave the machine running with closed gun ...because this as I said builts pressure in the machine and damage is done to internal suction and delivery valves. Sometimes even the high pressure hose can burst. These results can also hurt a person. If you open the machine yourself you often locate the spill valve under a cap with a micro switch and you see a black wire attached to the cap. If you intend to use the old spill valve, this must be lubricated with special silicon grease. The job is very simple. All you have to do is open the cover and locate the spill valve.
Regards,
Fulltech.
Posted on Jun 25, 2009
Karcher G3050OH when trigger is released it can't be depressed again until machine is shut down. Pressure will release after shut down.
It sounds like you're not pulling hard enough. When the machine is running it's under great pressure you have to squeeze the trigger very hard
May 05, 2017 | Karcher Garden
Pressure washer will not shut off when water trigger on wand is released
Sharon, you first should make sure you have no connection/leaks any where. There is a pressure switch inside the pump, which controls when the motor turns on and off. Leaks in pressure causes the pressure switch to activate the motor. Leaks are the biggest contributor to a cycling machine. If no leaks, the pressure switch is defective. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Karcher North America Home Garden Online Help
Frequently Asked Questions about Pressure Washers
Common Pressure Washer Repair Problems Pressure Cleaned
May 18, 2016 | Garden
Gun fires 2 or 3 naiks everytime I pull trigger
Most nailers have two types of triggers available. One is a bump fire and the second is single shot that is activated by releasing the trigger, placing the contact foot against the work, then depress trigger. Bump fire trigger May fire two nails if you place then depress. Check your parts manual to determine which trigger is installed. (Some brands have built-in switch to activate bump) good luck
Jul 13, 2015 | Air Tools & Compressors
Pump will not shut off when the sprayer nozzle trigger is releasd on my McCullogh electric press. washer mdl fhh18a
Likely means you now have a leak in the high pressure area. Could it have been frozen over the winter?
Shutoff is pressure activated...
Jun 20, 2015 | McCulloch Garden
My electric Karcher pressure washer does not shut off.
this can be that you need to bleed the system of air or that there is a problem with your trigger gun sticking when you release the trigger.
These are two things I would check before you go into the machine.
May 14, 2012 | Karcher Garden
The gas won't shut off once I release the trigger, sometimes the wire continues as well.
Hi:The solenoid valve gets the current once the switch is activated (pressed) therefore my opinion is that you have a sticky trigger. or one of the terminals of the cables it's shorting out.Change the trigger or better yet check that the terminals are clear and not touching other parts of the handle.
Dec 06, 2011 | Hobart Handler 140 Mig Welder
How do i turn it on
Depending on what kinda saw it is some have an on/off switch and some you just pull trigger lock and throttle up together and move the lever to choke position which activates switch and pull over till it snorts once then back off the lever 1 click and pull again till it starts, keep in mind when it starts it will be about 1/4 to 1/3 throttle so you will have to squeeze the trigger to release the fast throttle starting position, then to shut off just slide the lever one more click and it turns off, Hope I answered Your Question
Apr 25, 2011 | Garden
Mk500 i want activate scanner at startup
contact me at sonylal85@gmail.com ... i can fix this issue for u
sony
South America
Dec 02, 2010 | Zebra Symbol MK500 Data Terminal
Miller 350p welder gives a "help 3" code.
Code help-3 Indicates that the gun trigger was pulled and held during power up. Release gun trigger and clear fault condition. Also, this display can Indicate no open circuit voltage detected when gun trigger is pulled and no arc detected within 3 seconds, this means that the trigger was held without any metal contact. The machine will shut down in order to avoit the wire to continue to run freely.
To fix:
Turn on the machine without pressing the trigger on the gun. Then increase to the max the wire speed. Then turn off the machine. Press the trigger after the machine was turn off, then without releasing the trigger, turn on the machine and release the trigger after 2 seconds. That will take care of it.
Nov 17, 2010 | Miller Welding Tools
Pressure washer stalls out when wand nozzle is released
common for not starting unless trigger engaged as you are turning the pump as well as engine creating pressure,as for stalling pump has unloader valve which is probably in need of grease(use good silicone grease)this allows water to ciculate when trigger released.
Apr 19, 2009 | Campbell Hausfeld Garden
Garden Logo
269 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
