Question about Sony KV-20M10 20" TV
I want to buy Integrated circuit N° CX A 1465 AS for repare a TV KV20M10 for poor people. Thanks and regards Michel Ruffetta
  • 100 Answers
Bdent.com,in stock.
Posted on Jun 26, 2009
Two codes pop up?
Possible causes P406 include EGR Valve clogged, dirty or leaky
- EGR valve damaged/defective
- EGR volume control solenoid valve
- EGR temperature sensor and circuit
- EGR volume control solenoid valve harness is open or shorted
- EGR volume control solenoid valve circuit poor electrical connection
Possible causes P0108 - Faulty Manifold Absolute Pressure sensor
- Manifold Absolute Pressure harness is open or shorted
- Manifold Absolute Pressure sensor circuit poor electrical connection
- Faulty Engine Control Module (ECM)
May 23, 2014 | 2006 Lincoln LS V8
AT&T Universal remote code
Check these codes: 0103 0189 0217 0135 0133 0116 0167 0456 0029
Aug 11, 2012 | Insignia NS-27 TV TV
How to resolve e00002-0000
E002
The main thermistor (TH1) has poor contact or an open circuit. The thermal
switch has an open circuit (TP1). The fixing heater has an open circuit. The
AC driver PCB is faulty. The DC controller PCB is faulty. The door switch
is faulty.
E002
0000 The temperature of the fixing film is as follows:
1. has exceeded 100°C, but does not reach 115°C within 1 sec thereafter.
2. has exceeded 140°C, but does not reach 150°C within 1 sec thereafter.
3. has exceeded 160°C, but does not reach 165°C within 1 sec thereafter.
Main cause: The fixing film unit is faulty (i.e., the main thermistor TH1 has poor contact,
or the fixing heater is faulty). The main power supply PCB is faulty.
Caution: To clear the error, execute the following in service mode:
COPIER>FUNCTION>FCLEAR>ERR.
Action See the description for E003.
E003
Action
1. State
Turn on the power switch, and clear E002/E003. Thereafter, turn off and
then on the power switch. Does the fixing heater operate?
NO: See "The fixing heater fails to operate."
2. Wiring
Is the wiring from the DC controller PCB to the fixing film unit normal?
NO: Correct the wiring.
3. Fixing film unit, DC controller PCB
Try replacing the fixing film unit. Is the problem corrected?
YES: End.
NO: Replace the DC controller PCB.
Feb 12, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
What is the remote program code for a sylvania tv # SST4324?
hi! i have here a couple of codes for your tv! just try them, 1004, 1007, 1018, 1027, 1047, 1056, 1057, 1059, 1060, 1061, 1103, 1124, 1145, 1150, 1153, 1279, 1296, 1387, 1464, 1483,1046, 1465, 1150, 2092, 1464, 2408, 1465, 2260, 1027, 2064, 3105, 1124, 2078, 3088, 1296, 2213, 3147, 1145, 3095, hope this helps!!!! goodluck!!!
May 06, 2010 | Sylvania SST4322 32" TV
Don't know the universal remote code. Tv did not come with a remote Sylvania LC370SS9
hi! i have here a couple of codes for your tv! just try them, 1004, 1007, 1018, 1027, 1047, 1056, 1057, 1059, 1060, 1061, 1103, 1124, 1145, 1150, 1153, 1279, 1296, 1387, 1464, 1483,1046, 1465, 1150, 2092, 1464, 2408, 1465, 2260, 1027, 2064, 3105, 1124, 2078, 3088, 1296, 2213, 3147, 1145, 3095, hope this helps!!!! goodluck!!!!
Apr 29, 2010 | Sylvania LC370SS9 LCD TV
Im facing one problem if e 004 what is the
VIII. SELF DIAGNOSIS The microprocessor on the copier’s DC controller PCB is equipped with a function that checks the condition of the machine (especially the condition of sensors). It runs checks at such times as programmed, and will indicate any fault it finds in the form of code. A. Copier E000 • The thermistor (TH1, TH2) has poor contact or an open circuit. • The fixing heater (H1) has an open circuit. • The thermal switch (TSW1) has turned on. • The triac is faulty. • The DC controller PCB is faulty. • The thermistor (TH1, TH2) has a short circuit. • The triac is faulty. • The DC controller PCB is faulty. • The thermistor (TH1, TH2) has poor contact or an open circuit. • The fixing heater (H1) has an open circuit. • The thermal switch (TSW1) has turned on. • The triac is faulty. • The DC controller PCB is faulty. • The thermistor (TH1, TH2) has poor contact or an open circuit. • The fixing heater (H1) has an open circuit. • The thermal switch (TSW1) has turned on. • The triac is faulty. • The DC controller PCB is faulty. • The triac has a short circuit. • The DC controller PCB is faulty. • The surface temperature of the fixing upper roller does not reach 40°C within 14 sec after power-on. • The surface temperature of the fixing upper roller exceeded 230°C. • The surface temperature of the fixing upper roller does not reach 60°C within 10 after it exceeded 40°C. • The surface temperature of the fixing upper roller does not reach 80°C within 10 sec after it exceeded 60°C. • The surface temperature of the fixing upper roller does not reach 100°C within 10 sec after it exceeded 80°C. • The surface temperature of the fixing upper roller does not reach 120°C within 10 sec after it exceeded 100°C. • The surface temperature of the fixing upper roller drops to 130°C or less after it reached the target temperature (160°C) for standby. • The triac is identified as having a short circuit. Code Cause Description E001 E002 E004 E003
Oct 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
Can cracked screen be replaced on flat screen tv?
Yes,but It very exspensive not worth reparing.
U could buy a cheap same model take out the damage circuits and replace it over.
Aug 19, 2009 | Televison & Video
Power problem
it’s the problem of main power supply circuit board.on the circuit board any of the capacitor or ic is gone faulty.so when you turn the tv ON the current passess through the board but cannot pass from that particular faulty part and the board gets overheated and tv turns off automatically.as you mentioned the tv turns on for some seconds.it will not be a major costly .but the board needs reparing to solve this problem.
Thanks.
Jul 13, 2009 | RCA D52W19 52" Rear Projection Television
2007 Mazda CX-9 buying
I have only owned the car for 4 months, the only thing that bothers me is poor gas mileage. I am only averaging about 13 miles per gallon in mixed driving.
May 14, 2008 | 2007 Mazda CX-9
Pioneer DVR-540HX DVD recorder Error message 'REPAIRING HDD'
Greeting, I have same problem too, and now recorder is in warranty service. HDD sucks. This recorder is piece of ****. HHD is noisy and poor quality.
Stay in peace
Nov 17, 2007 | Pioneer DVR-540HX DVD Recorder/HDD...
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
