Question about Amana ABC2037SS Air Conditioner
Amana Central Air not working
When I open the air handler the light is flashing red
    Problem Solver:
  • 7 Answers
Blinking red lights on circuit boards usually mean an error has occured. Check all your wiring and connections. Make sure the blower fan spins freely. Check the sensor wiring. Do you smell burnt electrical any place? Are you familiar with pulling the circuit board and checking the solder points on the back side?
Posted on Jun 26, 2009
What does 3 flashes of the red light mean on an amana model ptc153a35ac ?
Here are your Amana flash codes:
Steady On - Normal
Off Controller Failure
1 System Lockout
2 Pressure Sw stuck closed
3 Pressure SW Stuck Open
4 Open - High Limit
5 Flame sense without gas valve
6 Open rollout or open Fuse
7 low flame signal
8 Check igniter or improper ground
continuous flashing - reversed AC polarity
Sep 11, 2014 | Heating & Cooling
Fujitsu ASU18RLQ heater/air conditioner with 2 green and 7 red flashing error lights
Here is a link to the error codes.
http://www.fullyairconditioned.com.au/images/uploaded/files/fujitsu%20fault%20code%2
0split%20system.pdf
Hope you find an answer there.
Feb 15, 2013 | Fujitsu ASU18RLQ Single Zone Wall Ductless...
Amana heat pump/AEPF variable spd air handler system works great, but air flow at the higher speed is just too noisy (ducts are not very wide). Is there a way to limit how fast the air handler / blower...
Open the airhandler -should be a speed selector on the main board. If not -checkt he installation/set-up manual. May be some dip switches you can turn on or off to modify blower speed.
Jan 26, 2011 | Goodman CLQ36AR49 Air Conditioner
What supply house sells haier air handlers in Atlanta ga
any 4 tonnes air handler will fit if you respect de gas for the unit if r22 than than r 22 air handler if r410 than r410 air handler you can put r410 air handler if r 22 not avalable but be sure that expension valve is compatible.
Dec 13, 2010 | Haier HC48C1VAR Central Air Conditioner
My air handler isn't working, red light is flashing so it appears to have power, but the thermostat LED display is blank????
Does the thermostat run off battery power or does the transformer supply power to the thermostat. You can check this by removing the thermostat face and checking for a wire connected to the C terminal. If there is no wire there then it is battery only. Replace the batteries. If you have the brand and model # of the thermostat, you can do a Google search for the owner's manual. Of course there is always the possibility that the thermostat has gone bad.
Sep 06, 2010 | Amana Heating & Cooling
My heat pump will start to light but then goes out the red flash code is 4 long 3 short I checked the temestat and its OK any guess
38CKC is the outdoor unit, we need the model number of the air handler. open the door panel and look for a wiring diagram. Somewhere on it will be a diagnostic chart, look for a code 34.
Feb 26, 2010 | Carrier 38CKC042 Air Conditioner
COMPRESSOR Amana / RCE24C2A Ser #036142440
mfg date are coded into the ser.# useualy fist 4 digits are yr and month of MFG. 0306 would be 2003 june ect. if in doubt call amanna dealer and ask them. Steve
Jul 12, 2009 | Heating & Cooling
Rheem Air Handler will not run. This is a 2006 Rheem model RHLA-HM3617JA Air Handler. I replaced both the condenser and air handler circuit boards. I replaced the motor in the air handler.. The condenser...
Have you hard wired your fan motor to verify that the motor and or the capacitor are good? If you do a continuity test of the motor leads(with electricity off of course) you can see if the motor has open or grounded windings.
Apr 11, 2009 | Ruud Handler Air Conditioner
1997 Amana 2 or 2.5 ton heat pump, 13 seer - air handler only blows 4-5 min
do you have a totaline t-stat. they and some other brands have a fan recirculation setting in the installers menu.
this is assuming that this happens in addition to the heating or cooling normally
Jul 02, 2008 | Amana PTH123B25AJ Heat Pump Air...
Amana AC
Hi, the aircondationer compressor was stuck , the thermal control open the red light on , you may call fixya authorized repair service near you you just enter zip code .
Jan 30, 2008 | Amana AP099R Air Conditioner
Heating & Cooling Logo
442 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
