Question about Dryers
My dryer will only stay hot for a few minutes what can i do The gas ignites but then after about 5 minutes it stops and the dryer gets cold
  • 97 Answers
Hello Friend, Your problem is very simple to fix. You're dryer needs a gas valve coil kit. To replace coils just remove front of dryer body and look below drum you will see the gas valve. The valve coils are located on top of valve (two little round black cylinders). It's simple, just remove the two screws from the little metal bracket that holds them down, unplug the wires from them and just lift them straight up off of the valve. Take notice that one has 3 wires and one has 2 wires. Just replace with new coils and plug wires back in and re-fasten metal bracket. Your dryer will run like new. Happy to help, Tim.
Posted on Jun 25, 2009
    Sergeant:
  • 353 Answers
Check the exhaust vent and duct
lint build up will cause the high limit to trip
Igniter starts to glow for 3-5 sec while making noise every minute or so
Check the thermocouple it is going bad or already has and that is why the gas valve is not staying open.
Jul 08, 2017 | Whirlpool GGW9200L Gas Dryer
Gas Dryer wont stay lit.
It may be your dryer vent piping. If the piping from the dryer to the outside of the house is clogged with lint (which happens periodically) the dryer cannot get rid of the heat generated by the gas burner. When the temperature reaches a certain level the high limit switch opens and shuts the burner off. The switch closes again after the dryer cools down. Check the lint filter and all the vent piping for any obstructions and clean out thoroughly. This should solve your problem. Hope this helps.
Jan 14, 2014 | Whirlpool Cabrio WGD6400SW 7.0 Cu. Ft. Gas...
Heat wont stay on
Replace the 2 gas valve coils, check the link below to have an idea of how they look like.
Maytag Dryer Gas Valve Ignition Solenoid Coil Kit 279834
Jan 14, 2014 | Whirlpool LGB6300 Gas Dryer
Dryer not releasing hot air
if its an all electric dryer then you may have an open heating coil or a bad contact on the timer that supplies power to the heating element .. a few dryers have a fuse that could be blown ..
if you have a gas dryer then you may have a bad solonoid that operates the gas valve .. or more likely a bad igniter .. thats a module that heats up or sparks to ignite the gas .. the igniter is a replacable item mounted near the gas flame. . the heated type fail frequently on some dryers ..
Aug 18, 2009 | Dryers
Gas dryer gets hot for a few minutes then goes cold.
Sounds like you need to replace the coils on the gas valve. Just make sure your venting is clear 1st. If it is, the coils are easy to replace. Remove the front panel and the coils are on the bottom right hand side. Two screws and the bracket for both comes off. One has two terminals and the other has three. Real easy once you get into the dryer.
Jun 15, 2009 | Whirlpool LGB6300 Gas Dryer
Maytag dryer dg712 does not stay lit
Yeah change the coils read my page on intermittant coils HERE
Apr 12, 2009 | Dryers
Dryer not staying hot
gary suspect the coils on the valve are bad the coils come in a kit so change both
May 18, 2008 | Dryers
Whrilpool gas dryer
DISCONNECT THE EXHAUST FROM THE BACK OF THE DRYER AND TRY DRYING ONE LOAD OF LAUNDRY. IF THE DRYER WORKS O.K. WITH THE EXHAUST DISCONNECTED, YOU HAVE A RESTRICTION IN THE EXHAUST DUCT SOMEWHERE.
Apr 22, 2008 | Dryers
Dryers Logo
61 people viewed this question
Top Dryers Experts
